Gaze Based Interactions
To create a gaze-based interaction in SightLab, you can follow these steps. SightLab already has built-in support for gaze tracking, so you only need to configure it by setting up gazeable objects and adding optional callbacks for when gaze events occur.
Basic Gaze Interaction Setup
Import SightLab and necessary modules:
import vizshape # if using basic shapes
Initialize SightLab:
sightlab = sl.SightLab(gui=False)
Add your environment (if not using GUI):
env = vizfx.addChild('sightlab_resources/environments/complete_scene.osgb')
sightlab.setEnvironment(env)
Add an object and enable gaze interaction:
object1 = vizshape.addCube(size=0.2, color=viz.RED)
object1.setPosition([0, 1.6, 2])
sightlab.addSceneObject('CubeObject', object1, gaze=True)
Define what happens when gaze events are triggered:
def gazeActionStart(e):
if e.object == sightlab.sceneObjects[GAZE_OBJECTS]['CubeObject']:
print('Gaze started on CubeObject!')
def gazeActionEnd(e):
print('Gaze ended on CubeObject.')
vizact.addCallback(sightlab.GAZE_TIME_EVENT, gazeActionStart)
vizact.addCallback(sightlab.GAZE_END_EVENT, gazeActionEnd)
Create the experiment loop:
def sightLabExperiment():
yield viztask.waitEvent(EXPERIMENT_START)
for i in range(sightlab.getTrialCount()):
yield sightlab.startTrial(startTrialText="Look at the red cube to trigger a gaze event.")
# Allow some time for the gaze to occur
yield viztask.waitTime(10)
yield sightlab.endTrial(endTrialText="End of trial. Thanks!")
## Scheduling the experiment
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
GAZE_START_EVENT for your event to be triggered as soon as a gazeObject is seen
GAZE_END_EVENT to trigger something to happen when a user’s gaze point is no longer intersecting with that object
GAZE_TIME_EVENT to trigger something that happens only when an object is being focused on over the set threshold
🔍 Notes
You don’t need to code gaze tracking logic manually — just set gaze=True in addSceneObject.
Gaze events are triggered when gaze dwell time meets a threshold (can be modified with code or in the GUI).
Full Code
import vizshape
# Initialize SightLab without GUI
# Set environment
sightlab.setStartText(' ')
# Add a gazeable object (a red cube)
cube = vizshape.addCube(size=0.2, color=viz.RED)
cube.setPosition([0, 1.6, 2])
sightlab.addSceneObject('CubeObject', cube, gaze=True)
# Define callback functions for gaze events
print("👁️ Gaze started on CubeObject!")
cube.color(viz.BLUE)
print("❌ Gaze ended on CubeObject.")
cube.color(viz.RED)
# Register gaze event callbacks
# Define the experiment logic
yield sightlab.startTrial(startTrialText="Look at the red cube to begin tracking gaze.")
# Let the participant gaze around for 10 seconds
yield sightlab.endTrial(endTrialText="Trial ended. Good job!")
# Schedule experiment
Gaze Based Events using the GUI
There is also an end condition in the GUI for gaze based events that allow you to trigger ending the current trial or progressing to the next one using an onGazeTime event. For additional gaze based triggers see below.
Multi-User
On SightLabVR_Server.py script:
Add Network events then create a function for gazeActionstart and for gazeActionEnd, add the code for whatever you want to have happen (i.e. a print statement) inside the function. Callback the functions with the network event.
#Generate IDs for events
def id(name):
"""Generate unique ID for use over viznet"""
return f'viznet:{name}'
FIXATION_NETWORK_KEY_EVENT = id('FIXATION_NETWORK_KEY_EVENT')
FIXATION_STOPPED_NETWORK_KEY_EVENT= id('FIXATION_STOPPED_NETWORK_KEY_EVENT')
if e.name == "creature1":
creature1.setScale(1,1,1)
print('stopped looking')
if e.name == "chick1":
chick1.setScale(1,1,1)
creature1.setScale(1.5,1.5,1.5)
print('saw creature')
chick1.setScale(1.5,1.5,1.5)
vizact.addCallback(NETWORK_GAZE_TIME_EVENT, gazeActionStart)
vizact.addCallback(NETWORK_GAZE_END_EVENT, gazeActionEnd)
On SightLabVR_Client.py script:
def id(name):
if e.gazeData.name == "creature1":
if e.gazeData.name == "chick1":
