Known Issues
  • Number of avatars needs to be the same on all clients or else you will get a “list index out of range” error
  • The same goes for environment models when using the GUI interface (needs to have the same environment models and number of models on all clients)
  • Adding an underscore "_" in the participant info name will cause errors
