Mixed Reality
In the Example Scripts folder you will find some examples of using mixed reality (in your SightLab folder under ExampleScripts\- Mixed Reality). Mixed Reality will work through OpenXR support of Mixed Reality (Vive Focus Vision, Meta Quest 3, Meta Quest Pro, Varjo XR-3/XR-4) currently.  As of SightLab 2.8.8 you can now enable passthrough on 360 and 180 video as well (so can show the real world background over video elements)
Viewing Passthrough on Mirrored Desktop View:
To see the overlay of the real world with the mixed reality objects on the mirrored view for Meta headsets, you will need to create a developer account and download the Meta Quest Developer Hub for Windows. Once that is installed, login, connect the Meta Quest Pro and click "cast". You may also need to change the ADB path by selecting the one that comes from the dropdown and clicking "cancel". See this video for more information.
For Varjo, you can use the Varjo Base to see the overlay of the real world and virtual objects in the mirrored view.
https://varjo.com/use-center/get-to-know-your-headset/mixed-reality/
Interacting with the environment
If you want to have objects interact with real world objects you can place a 3D shape (such as one of the "regions of interest" boxes) over the real world object and then set its alpha to "0" in inspector Then you can turn on physics (see this page for how to enable physics).  For instance you can add an object on top of the real world ground.
Mixed Reality with Multi-User:
In order to see other user's avatars while using Mixed Reality- see the example ExampleScripts-SightLabVR_Client_mixedReality.py and run this for any clients using mixed reality.
For the server script you will need to choose "empty" for the environment.
Meta Pro Grabbing XR
Example that shows interacting with physics and grabbing objects with your hands in mixed reality (uses OpenXR hand tracking)
Mixed Reality Eye Tracking with Object ID:
See here  to see the set up steps for collecting eye tracking data on real world objects
Mixed Reality Virtual Screen
View a virtual screen on top of your real environment
Varjo Chroma Key
For information on how to have something like a green screen be replaced by the digital world using Varjo's Chroma Key feature see this page, and the section "Chroma Key"
Mixed/Augmented Reality/Passthrough with 180 and 360 Video
See this page for information on how to use passthrough with 360 and 180 videos
Mixed Reality (Simple Example)
To add Mixed Reality to any script just add this code (AFTER sightlab experiment has started, especially if using the GUI):
For SightLab 2.8.8 this is now a simple one line method (add this after sightlab has started the trial)
sightlab.setPassthrough()
Example:
sightlab = sl.SightLab()
def sightLabExperiment():
    yield viztask.waitEvent(EXPERIMENT_START)
    viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
    for trial in range(sightlab.getTrialCount()):
        yield viztask.waitEvent(TRIAL_START)
        yield viztask.waitEvent(TRIAL_END)
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
Prior to SightLab 2.8.8 (need to add a little more code manually):
import openxr
xr = openxr.getClient()
if sightlab.getConfig() == "Meta Quest Pro":
    passthrough = xr.getPassthroughFB()
elif sightlab.getConfig() == "Meta Quest 3":
elif sightlab.getConfig() == "Varjo":
    passthrough = xr.getPassthroughVarjo()
elif sightlab.getConfig() == 'Vive Focus Vision':
            passthrough = xr.getPassthroughHTC()
# Set transparent background color to pass through to video
viz.clearcolor(viz.BLACK, 0.0)
# Enable passthrough
if passthrough:
    passthrough.setEnabled(True)
