Presentation Mode - Multi User
Presentation Mode allows you to run a multi user session with advanced tools, such as being able to change trials, reset other users, use a highlighter tool, playback media, jump to locations, and close a session. This can be done either through key presses or using a built-in 3D menu.
How to Run
- Find the Example in Multi User ExamplesScripts\Presentation Mode
- Run SightLab_Server.py to start the server and set options, such as environment used, trial configuration (see this page for more details)
- Run SightLab_Presenter.py to start the Presenter client
- Run SightLab_VR_Client.py for all other clients
Controls
These controls are in addition to the standard controls used in SightLab
Desktop Controls
HMD Controls
Additional Keys:
- /: Capture screen shot
- 1: Toggle Media Playback
- ';': Toggle Mouselock
- F2: Toggle Fullscreen
- TAB: See currently connected clients (desktop mirrored window)
How to Use the Virtual Menu
Set USE_SCENE_CONTROLLER = True on both the presenter and server to use the Virtual Menu
The Virtual Menu can be modified according to the instructions on this page
For Desktop:
- Step 1: Press 'm' to toggle bringing up the menu
- Step 2: Press the Right Mouse Button to bring up the highlighter.
- Step 3: Move the highlighter over the desired menu button.
- Step 4: Click the Left Mouse Button to select the highlighted option.
- Alternative: Place your cursor over the menu and click the Left Mouse Button directly.
For Headset:
- Step 1: Press the RH Thumbstick to toggle bringing up the menu
- Step 2: Press and hold the Right Hand Grip Button to bring up the highlighter.
- Step 3: Point the highlighter at the desired menu button.
Step 4: Press the Right Hand Trigger to select the highlighted option.
