Quick check
SightLab experiments can be set up with a GUI, with code, or a combination of both. This QuickStart is showing how to test starting a quick session with the GUI. This is just for testing functionality, see creating a new scene and the rest of the documentation for more options.
Quick Start - GUI Description
Folder Create Folder: From Documents\SightLab2\Projects make a copy of BlankProject. This includes a sample 3D model and 360 media. To add more assets, place in the resources/environments or resources/media folder. See this page for some places to gather assets.
Folder Add Assets: To add more assets, place in the resources/environments or resources/media folder. See this page for some places to gather assets.
GUI Launch GUI: Open SightLab_VR.py in your BlankProject copy folder to launch the SightLab GUI and choose hardware.
GUI If have any existing projects loaded, click "New."
Next, name Project and click "Save Project"
GUI Click Modify to open the Experiment Options editor where you can edit and open your 3D models or 360 media, as well as set up all your individual trial options (start/stop conditions, tracking, etc.)
GUI Choose a 3D Model or 360 Media Here is where you can also set many more experiment options or click "Edit" to open a model for editing (see creating a new scene). Click "Done" when ready.
GUI Start/End Trials: Press "Continue" to save changes and start your session (Check "BIOPAC Markers" checkbox if running with BIOPAC Acqknowledge). Click"Submit" to click past participant info.
GUI Run Session: Default controls use Spacebar to start/stop.. See full controls here. The "p" key toggles viewing the gaze point (off by default). Press Escape or click the top right 'x' to close this window.
GUI Replay & Review Data: Use SightLabVR_Replay.py for session replay (use Spacebar to start/stop); view data files in the data folder.
Non-GUI Workflow: For non-GUI see example with code.
Customize Scene/Experiment: Creating a new scene.
Multi-User Setup: Check the multi-user guide for collaborative experiments.
Getting Assets: Need models or media? Check out the Getting 3D Models and Assets page.
Examples and More: For more, refer to the SightLab documentation and examples in the ExampleScripts folder.
