Release Notes
Changelog
Version 2.8.3 (4/4/26)
New Features & Enhancements
  • New avatar workflow by just adding directly to Inspector
  • Avatars added to Dashboard Asset Library
  • Added avatars in the replay to work from child avatars
  • Updated Adding NPCs examples for new workflow
  • Vizard/SightLab script starts embedded by default if it is a new project on the Dashboard now (can still change this in settings)
  • Clicking back to library on the Dashboard also can do media as a thumbnail
  • Auto-hide search bar when running embedded on dashboard (with checkbox to bring it back)
  • Vizard editor launch button on header of Dashboard
  • Made it so Objects and Scene Objects can't be accidentally replacing the environment when dragging into the preview window in the Dashboard
  • Automatically capture thumbnail when a new project is closed
Fixes & Stability Improvements
  • Fixed issue where couldn't type in the text fields in the Dashboard
  • Fixed issue with F2 not working to go fullscreen when running embedded in the dashboard
  • Fixed issue with the escape key causing issues starting another script in the dashboard
  • Fixed issue where the head only full body avatar option wasn't locking the arms on the server
E-Learning Lab
  • Support for offline Image Generation (mono, stereo and 360) with AI using Stable Diffusion and other offline models
  • Sort options on asset bins
  • Support for avatars (animations, morphs, added to assets library)
  • Added On Media End as an option to transition between slides
  • Ability to convert any mono image to stereo (right click in assets and choose "Convert to Stereo")
  • Ability to set custom scene transitions to all slides
Version 2.8.2 (3/28/26)
Note: This update also requires using the latest SightLab installer, which you can get here
See this page for more information
  • New Updates to the SightLab Dashboard
  • Added assets library browser with ability to add, edit, search and add to project 3d models, 360 media, scene objects and more
  • Added ability to search and download directly from Sketchfab
  • Added ability to launch Vizard and SightLab scripts directly embedded in the dashboard
  • Auto check for updates and notifications if a SightLab update available
  • Moved online asset browser button to assets section in Details page
  • Auto-adding of Project thumbnails
  • Added additional run button (and stop if running an embedded script) to the main details panel
  • Resizing of panels in the Details page
  • Ability to remove individual favorites
Version 2.8.1 (3/24/26)
  • New Sightlab projects and example scripts dashboard
  • New Project workflow using the SightLab dashboard
  • Added Barchart to the GUI and SightLab class to automatically save a barchart of objects viewed to the data folder
  • Added Start and End Instructions buttons to the GUI
  • AI Agent script: If selecting a language other than English, will switch to using that language (edge-tts best tts to use)
  • Multi_agent_interaction uses multiple languages
  • Added edge-tts option for AI Agent and E-Learning Lab
  • Fixed issue with visual search art gallery not properly showing the randomized placement of the object in the replay
  • Adjusted adding avatar example
  • Fixed AI Data Analysis to work with later OpenAI models
  • Fixed issue with External Data Recorder Replay not working if a participant ID is set
  • E-Learning Lab- added auto switching of languages
  • LibreOffice added to installer for a quick and easy way to view .csv files
  • Updated Vizard installer to 8.3.1 in the included SightLab installer
Version 2.7.3 (3/7/26)
  • Support to have multiple languages for GUI text
  • Fixed issue with full body avatars not being seen by head and hands clients
  • Fix Desktop full body avatar right arm starting in a weird location
  • Added a handle to the waiting room lights
  • Added ability to lock upper body of avatar into poses (in addition to seated locked mode)
  • E-Learning Lab
  • Can now add custom content to the AI Agent knowledge (PDFs, markdown and text files), this is in addition to the custom content that can be added in the Presentation Generator. Drag and drop from any Windows explorer window with the tag "_knowledge" added to your file
    Added a “Discussion” slide mode for the Presentation Generator to initiate an open discussion with the AI Agent
    Changed default image model to Nano Banana 2, which will now ground images from online information and provide much better text and diagrams and image content for presentations
Version 2.7.2 (2/13/26)
Version 2.7.1 (2/11/26)
  • Added fastLoad as an option to load either a temp Image or Model for the GUI or SightLab server instead of needing to load the last selected environment. Helpful as a splashscreen or if using a large model that takes a long time to load. (give an image or model to load as sightlab = sl.SightLab(fastload = 'scene.png'))
  • Fixed issue with Multi User Clients failing if using an older sightlab config or no sightlab config
  • Jump To Locations update to set menu off when teleporting
Version 2.7.0 (2/10/26)
  • Mixamo and ReadyPlayerMe limited Full body avatars support (IK with upper body in single and Multi-User)
  • Added seated mode option for full body avatars
  • Set Optimize Intersects to True to increase frame rate (can be toggled off)
  • Added Mumble Client and Server Launch buttons on Multi-user (needs installation)
  • HeyGen Video Avatars partial support (works via screencasting, direct API coming soon)
  • New workflow to convert .osgb models to .glb with textures (requires Blender 3.6 or higher and a separate osgconv download)
  • Fixed issue with StartPoint Objects
  • Added folder to TrackedAvatars in ClientGUI
  • Example Scripts
  • Added offsets to Jump To Points
  • Fixed issue with Jump To Points
  • Fixed issue with running multiple trials external data recorder
  • E-Learning Lab (see here for more). To install E-Learning Lab, make sure the checkbox is checked on the SightLab installer. If the E-Learning Lab is not an option, then request the latest installer here.
  • Can now upload any documents, images or zip files to generate presentations
  • Added ability to upload powerpoint or pdf slides and have the Presentation Generator use AI vision to automatically generate content
  • Ability to upload custom lesson plan content to the Presentation Generator
  • Fixed issue where creating a new project while one is open didn't clear the preview window
  • Removed description from Projects tab and added ability to input in the Scene Info tab
  • Added feedback bug reporting system
Version 2.6.10 (1/12/26)
  • Updated desktop vizconnect with "ButtonA" event mapped to the "T" key (used for object interactive info on E-Learning Lab)
  • Updated Publish as exe to work properly
  • Example Scripts
  • Fixed Publish as exe
  • Fixed issue with AI 3d Model Spawner failing without Meshy API if choosing MasterpieceX
  • Fixed issue with AI Agent and Offline_Ollama context
  • Fixed issue with AI Agent and Chat GPT 5.2 vision processing
  • Language now an option in the AI Avatar GUI
  • Improved support for multiple languages
  • Presentation Generation will now generate in the language used
  • Changed info button for Desktop to the ‘T’ key
  • Fixed Wikimedia causing cursor to not respond
  • Automatically generated scenes do not override Y position (so user is seated correctly for - Desktop mode)
  • Fixed issue with switching languages
  • Added single user script for Publishing as an Executable
Version 2.6.9 (1/6/26)
  • Fixed issue with highlighter appearing on the ground for the left hand
  • Added button A as an event to certain vizconnects
Added default to not override Y position
Added some extra tooltips
Changed start points for Lecture_Hall
Added ability to drag and drop existing zip files from the online browser and automatically show in the Projects browser
Fixed issue with text panels
Version 2.6.8 (1/3/26)
  • SightLab can now run in a read only folder- data is saved to the user AppData folder, although the Replay will not work in a read only folder. Suggestion is to make a copy before working out of a read only folder.
  • Adjusted docstrings
E-Learning Lab
See here for more. To install E-Learning Lab, make sure the checkbox is checked on the SightLab installer. If the E-Learning Lab is not an option, then request the latest installer here.
  • Interactive Object Info (click on Target objects to have the AI Agent give information automatically)
  • Biofeedback ball added (single user) - ball that will react to physio from Biopac
  • Second screen for Instructor - An instructor facing screen that can show videos/images/slides (can be toggled with the menu or the '3' key)
  • Fixed issue with server playing double audio on 360 videos
  • Per Project Settings
  • Added option for start points to only lock on first slide
  • Added Instructor menu button to toggle freezing the client transports
  • Added instructor menu button to toggle instructor screen
Version 2.6.7 (12/28/25)
  • Added pymupdf and python-pptx to included python libraries
  • Added Lecture Hall dark to included resources
E-Learning Lab
  • Added ability to drag in Power Point or PDF slideshows
  • Added connection to new Presentation Browser
Version 2.6.6 (12/27/25)
  • Rating Scale- Added vertical rating option that will automatically use vertical alignment if the text is too long
  • Two gaze points and gaze rays show in the replay
  • Hand closing animation with full body tracked avatars
Example Scripts
AI Agents
  • Support for Multiple languages
  • Fix for ElevenLabs
  • Offline Ollama selected as the default selection
  • Multi Agent Interaction fixed issue with Piper
E-Learning Lab
  • Direction Integration with Sketchfab to search and download models right into your project
  • Direct integration with AI 3D Model Generation with Meshy and MasterpieceX (use text or image to 3d directly into your project)
  • Direct Integration with Gemini to create 360 videos using Veo3
  • Direct Integration with Gemini to create videos and images using Imagen
  • Direct integration to search Wikimedia for Images and Videos
  • New Presentation/Lesson Generator - Use AI to automatically generate presentations given any topic. Creates environment, audio narration, images, quizzes, AI prompts, slides and more. Outputs suggested media and options for adding additional content
  • Added name of project to quiz response csv files
  • Loop video option
  • Audio text files read from text to speech with ability to interrupt
  • Support for stereo images as well as video
  • Transitions and timer values added per slide
  • Toggle Transport for client and single user
  • Add check for correct or incorrect result on Quiz
  • Multilingual support - can modify the AI agent to use any language
  • Added separate animation checkbox to trigger animations on objects that contain them
Driving Example
  • Now includes larger city and freeway maps by default
AI Image Spawner
  • Support for GPT-Image 1.5
Version 2.6.5 (12/15/25)
  • Fixed issue causing double avatar heads in session replay
Version 2.6.4 (12/8/25)
  • Added placeholder head and hands avatar for full body tracking replay sessions
  • Fixed issue with Full Body Tracking for Mocopi and Vive Trackers having wrong joints on the server view
  • Adjusted vizconnect configurations for full body Mocopi and Vive Trackers
AI Agent
  • Added ability to interact with multiple agents at once (with multi_agent_interaction.py script)
  • Added event manager to multi-agent script
External Application Data Recorder
  • Fix for crash on longer runs
  • Fixed FFMPEG use
AI 3D Model Spawner
  • Fix for AI 3D model spawner
Scene Builder
  • Added Scene Builder Example (Drag and Drop models, move and store locations)
360 with 3D Models
  • Added replay script
Driving
  • Fixed issue with third person view distorting viewpoint
  • Added viewpoint reset
  • Removed gazepoint from showing if in Desktop mode
Version 2.6.3 (12/2/25)
  • Fixed index error in sightlab
  • Fixed issue with being able to open vizconnect full body avatar configurations directly
  • Adjustments to Vive Ultimate Trackers configuration
Version 2.6.2 (12/2/25)
  • Added ability to scale ROIs for 360 media in individual X,Y,Z
  • Fixed issue with replay and a large number of trials
  • Added GUI to automatically show avatar if selecting full body
  • Fixed issue with midTrial full body avatars
  • Fixed bugs and made optimizations related to full body avatars
  • Fixed issue with lower body not sending and receiving over network
  • Color for fixation spheres based on length
Version 2.6.1 (11/27/25)
Core Platform
- SightLab Replay can now directly control the playback graph in Biopac Acqknowledge (requires Acqknowledge 6.02)
- Added support for full-body avatars in Multi-User mode.
- Added full-body avatar selection to the single-user GUI.
- Session Replay now includes:
- Left and right eye gaze points
- Gaze rays (Left/right originate from each eye of the avatar)
- Added support for Pupil Labs Quest 3 Neon XR.
- Improved eye-pitch convention (negative = down, positive = up).
Older sessions can be regenerated to match the new convention.
- Added flipEyePitch option for regeneration.
- Updated default fixation sphere scale0.023.
- Improved mirror module with better parenting support.
- Individual eye intersection is now the default.
- Added average FPS to data files.
- Fixed Replay’s “Revert to Defaults” button.
- Fixed custom data saving.
- Fixed issues with individual eye intersection data.
- Fixed issue with infinite gaze point values.
- Fixed issue with auto-start clients not showing up.
- Fixed headers not writing to experiment summary when using practice trials.
- Improved individual eye position accuracy.
Data & Logging Updates
- Added frames per second (FPS) to trial data file.
- Included mumble in installer for voice communication.
Driving Module Updates
  • Added gear shift system with mirrored-view HUD indicator (Reverse/Drive).
  • Fixed engine audio.
  • Added ability to turn while coasting.
  • Prevented turning while fully stopped.
  • Added dynamic controls for VR headset configurations.
  • Added ADD_TRAFFIC config option to enable traffic in any scene.
  • Added Regions of Interest (ROIs) for dashboard & mirrors.
  • Fixed velocity saving and added average MPH to summary data.
Image Viewer
- Fixed scaling issue.
Educational AI Interaction Tool
- Fixed highlighter not working.
- Highlighter now enabled by default.
Eye Tracker Tests
- Fixed Spatial Accuracy Example.
Randy Pausch Visual Search
- Fixed error with saving trials.
BioFeedback Ball
- Updated to 2 trials:
1. Fear of heights
2. Calm scenario
Memory Experiment
- Updated instructions.
E-Learning Lab
- Added Full Body Multi-User Avatars (with SightLab 2.6).
- Added link to download new lessons in Projects tab
(URL can be customized in globalConfig).
- Added Brain Lesson for online download.
- Added ability to toggle start point visibility.
- Added navigation toggle (Orbit ↔ Walk mode).
- Added Reset View using the ‘R’ key in the GUI.
- Removed extra Anatomy lessons (AI and Quiz); now available via the online lesson downloader.
- Added start points at 0 origin.
- Added start points at classroom origin.
- Enabled Toggle Controls function.
- Added new lab classroom model.
- Fixed issue with highlighter not positioned correctly.
Version 2.5.15 (11/5/25)
  • Made fastheatmap the default
  • Gradient Fixation Spheres that fade over time
  • Scale adjustment for fixation spheres
  • Fixed issue with client start points showing as scene objects in the GUI
Example Scripts
- AI Agents
Added vision to all included models, including offline Gemma3, OpenAI, Claude and Gemini
Fixed issue where Piper TTS would sometimes not work and interrupt was not set
Fixed issue where it was not finding the Claude model
Added taking and processing a screenshot as an automatic event
Ability to automatically add events to every prompt
  • 3D Tablet Menu
    Highlighter can automatically come up when you hover in front of the menu
  • Driving
    Fixed issue with Driving Meta and Driving OpenXR no Eyetracking to work with proper stering and acceleration
  • E-Learning Lab
    Added Piper TTS for faster speech interactions with the AI Agent
    Added Faster Whisper for faster speech interactions with the AI Agent
    Added Multi-User synchronization of speech animations and audio output
    AI Agent side to side head animation when addressing groups
    Added AI Prompts and Audio to Scene Panel in Projects Window
    Auto highlighter for 3d Menu
Version 2.5.13 (10/31/25)
  • Added faster heatmap option replay = Replay.SightLabReplay(fastHeatmap = True) which vastly increases the speed of loading and frame rate on longer replays. This fades faster over time and works different for occlusion. Choose which one works better for your use case.
Version 2.5.12 (10/29/25)
  • Ability to set custom Client Start Points without code (drag and drop client start point object)
  • Added a “Suffix” to client GUI to set which start point can be used
  • Choose with stlb project file to load from the GUI in a custom experiment
  • Added ability for clients to have an "Auto-Start" mode (no need to choose server, hardware, avatar, etc.)
  • Fixed Auto-assign issue in clients
Example Scripts
- AI Intelligent Agent -
Added offline Text to Speech model Piper
  • Mutli User Full Body Avatars Example Fix
  • Updated Gaze Based Interactions, Instructions and Choice Comparison to load correct stlb project files
Version 2.5.11 (10/20/25)
  • Updated icons for E-Learning Lab
  • Added Shared Folder to main Project Folder
Version 2.5.10 (10/16/25)
  • Switched to orjson for saving the replay json to improve performance
  • Multi User stability fixes and improvements
  • Fixed bug with dispersion path in replay
  • Fixed bug where Auto assign avatar would not stick
  • Fixed issue where sometimes grab Objects would throw an error for mid-Trial clients
  • Fixed issue where multi user biopac clients would toggle the server off
  • Added client IDs for multi user biopac
Example Scripts
  • AI Agent
    Support for custom events, including expressions, animations, interactions
Fixed Issue with multi agent interactions speaking over each other and from the wrong prompt
  • External Data Recorder
Added option for additional video recording methods (open-cv would sometimes crash after 10 minutes)
Real Time Streaming Adjustments for Vive Focus Vision
No longer need to select video in addition to data file on the replay
Fixed bug where session would continue for a few seconds over the timer
Added ability to adjust screen location with keypresses
Improved support for multiple trials
Synchronized with Acqknowledge graph playback (needs Acqknowledge 6.02)
Profile Matching system (no longer have to uncomment and comment out hardware profiles in the config)
Ability to start session with a network call from an external application
Desktop first person gaming option
Stand-Alone as dropdown option
  • Multi User Gaze Based Events
Updated to support new Multi-User code
  • Virtual Screencast
Fixed issue where replay was not saving recorded video of screencast
Fixed issue of window being resized
Fixed issue where casting would continue after quitting the script
Version 2.5.9 (10/06/25)
  • Added Placeholder object for Session Replay for vizshape objects
  • Fixed issue with session replay flags not working
  • Fixed issue with slider scrubber to work with video playback
  • Session Replay screenshots saved to “screenshots” folder in replay
  • Added ability to save equirectangular 360 screen captures (experimental feature)
  • Fixed bug with saving custom trial data
Example Scripts
- Driving
Major overhaul with expanded version available for download (including endless road, additional city maps, freeway onramps)
Support for driving wheels
Dynamic trigger based acceleration
Xbox and game controller optimizations (note this is now first in the list)
Toggle multiple viewpoint
Improved turning
Movable MPH and RPM gauges
Added wheel spinning (on main session but not replay)
Performance increase
Bug fixes
  • AI Intelligent Agent -
    Integrated avatar placer, fixed issue with elevenlabs animation starting before speech and mouth morphing continuing
    Reduced end to end latency
    Increased accuracy with speech recognition
  • AI 3d model spawner
    Added transform/translate/scale/save and load
  • Educational_Application_AI
    Reduced latency significantly
  • Virtual 2d Screen
    Fixed cycle videos example
Version 2.5.8 (9/16/25)
  • Fixed error when quitting multi user
  • Fixed issue with not being able to set scene objects after the trial has started in the code
  • Changed Vizard log level to viz.setLogLevel(viz.LOG_ALWAYS) to avoid spamming the interactive window with unnecessary loading information
Example Scripts
- Real World Objects example support for 360 video
- Fixed issue with error when disabling video recording on external data recorder
Version 2.5.6 (8/26/25)
  • Fix for Virtual Screencast to work with browsers again
  • Starting and Stopping Data Logging example update
  • Fixation timeline added to sightlab.startTrial and Server
  • Syncthing included in utils folder for multi-user synchronization
Version 2.5.5 (8/20/25)
  • Experiment summary now shows saccade averages instead of delta averages
  • If an object is intersected during an entire saccade, will show that object on the fixation saccade timeline
  • Added naming of columns in fixation saccade timeline to include “Delta” for delta metrics
  • Added updateRate flag to choose between collecting data on frame rate update or on a timer
  • Keyboard shortcuts for replay (scrubbing, etc.) now work whether CAPS lock is on or off
  • Example Script Updates
  • External Data Recorder – Added new ability to view gaze point in realtime. Fixed crash in Replay.
  • Bug fixes for the following example scripts: Virtual Screencasting, AI 3d model spawner, video compressor
Version 2.5.4 (8/14/25)
  • Fixed error with mid-trial clients data and replay
  • External Data Recorder – Added option of saving of average biopac data
  • AI Agents – AI Agents latency adjustment (reduced latency from avg. 8-10 seconds down to 2-3 seconds). Fix for AI Agent frame rate issue
Version 2.5.3 (8/11/25)
  • Fixed issue causing long waiting times for trials to save or multi user scripts to finish
  • Added sightlab.getClientName() to get access to the client name from a client script
Version 2.5.2 (8/8/25)
  • Fixed issue where multi user scripts would get stuck when ending
  • Fixed issue with experiment summary writing multiple headers and columns with custom data
Version 2.5 (8/7/25)
Fixation & Gaze Processing Enhancements
  • Centroid-based fixations – Fixations are now calculated using the centroid method rather than the previous start-point algorithm.
  • Growing-window dispersion – Fixation range is determined with a dynamically expanding window instead of a fixed moving window.
  • Immediate fixation onset – Fixations are logged as soon as an intersection begins, decoupling them from the dwell-time threshold.
Data File Regeneration
- Re-calculate past sessions – You can now re-run and recalculate data from previously recorded sessions with updated thresholds.
Additional Analytics and Data Files
- Fixation and Saccade Timeline export – New Fixation Saccade Timeline data file includes detailed metrics on each fixation and saccade (duration, dispersion angle, velocity, amplitude, etc.).
- Additional data fields:
- Trial length
- View status over the full trial (which item was viewed when)
- Time to first fixation on each object of interest
Terminology Changes
- “View counts” renamed to Dwell Visits
- “Fixated on” renamed to Dwell Onset
- Note: Can revert to 2.4 headers with a flag
- Header changes:
- Added (secs), (degrees), etc. to values
- Changed View CountsDwell Visits
- Saccade amplitudeDelta Angle
- Saccade velocityDelta Gaze Velocity
- See full list in sightlab_config
- Note: Can revert with SightLab(oldHeaders=True)
⚠️ Potential Breaking Changes
- When referencing participant info:
- p.id is now just p
- participantData is now participantData[ID]
- Header changes may affect parsing (can revert using the above flag)
Synchronize Resources for Multi-User
- Added ability to synchronize resources for Multi-User using syncthing.
Heatmap Improvements
  • Added adjustable time-based gradient heatmap that can fade over a set range.
- External Data Recorder – Tag regions of interest in third-party applications and collect eye tracking.
- Lab Streaming Layer example – Stream any data (e.g., eye tracking metrics) into Biopac AcqKnowledge or other EEG/physio software.
- Hand-grabbing physics – Enhanced grab interactions for Vive Focus Vision controllers.
- AI Intelligent Agent - Updated to work with gpt-5. Fixed issue with ElevenLabs
- Scripted Avatar Agent- No longer needs vlc player. Fixed issue with ElevenLabs
Bug Fixes and Optimizations for the following Examples
- Multi-User Public Speaking
- Walk the Plank Multi-User (now working)
- Choice Comparison
- Heatmap Visualizer
- Driving Simulator
- 3D Menu
- 360 Moving Regions of Interest (multiple regions support)
- Tossing Objects
- Vive Trackers example
- Mocopi trackers example
- Many more small fixes and updates
Additional Updates
- Added Projection VR to dropdown.
- Fixed issue with combined/per trial option not saving.
- Other data files now use combined method if selected.
- Updated .showInstructions to automatically work with GUI scripts.
- Fix for loading SightLab 1.x replays.
- Fix for errors on switching trials in the GUI.
- Fixed issue with setStartText not working.
Bug Fixes & Stability
- Corrected various minor bugs across data logging, UI callbacks, and replay modules to improve overall stability.
Version 2.4.3 (7/1/25)
Revert back to this version, click here to download sightlab_utils 2.4.3 and place in C:\Program Files\WorldViz\Vizard8\bin\lib\site-packages\ (overwriting current folder and files)
  • Fixed issue with onMediaEnd not working
  • Added text for GUI to show Left Shift to toggle navigation
  • Fixed issue with ROI tags showing duplicate in replay
Version 2.4.1 (6/20/25)
  • GUI now shows both Experiment Options and Trial Options on startup
  • Updated default sizes for GUI, Mirrored Window, and Replay
  • Replay enhancements: object visibility, scaling, and Model Viewer integration
  • Fixation Sequences added to replay
  • Time to first fixation added to replay
  • 360 ROIs and names added to replay
  • Updated moving regions of interest example to make the process simpler
  • Fixed bug with experiment summary
  • Added "Check for Updates" button to the GUI to check for the latest version
  • Replay data added to Biofeedback Ball example
  • Spatial tracking improvements: RMS and angular error metrics, glow effect when within threshold
  • Spatial Scanning with Audio example added
  • Mocopi tracker support added
  • Vive Tracker issue fixed for latest SightLab compatibility
  • New Environment Swapping example for experiment and replay use
  • Virtual 2D Screen: config-based screen object and hardware-aware positioning
  • Image Viewer passthrough mode and hardware positioning support
  • Mirror module and example updated
  • Glaucoma example rendering/interaction bug fixed
  • Adaptive Learning example now includes scikit-learn and staircase method support
  • View Percentage example tracks and logs time spent per region
  • External Data Recorder now supports OpenAI via environment variable
  • Added new AI-based data analysis tools and examples
Version 2.3.9 (5/29/25)
  • Virtual Screencasting from Desktop or phone to VR
  • AI Agent fixes and updates, also no longer requires vlc
  • New Shopping Visual Search Demo (by request)
  • Updated Visual Search Sample Conjunction vs. Feature
  • Publish exe example fix
  • Updated Mirror demo for Vive Face Tracker
  • Eyetracker tests updates
  • Spatial Scanning update
  • Updated Art Gallery Randomize Visual Search
  • Fixed issue with Jump to Locations
  • Video screen updates
  • TriggerPress3 updated to be correct controller
  • Image instructions update
  • Added vizshape to automatically imported modules
  • Quest 3 hand vizconnect option
  • Slowed down transport on Quest 3 vizconnect
Version 2.3.7 (5/3/25)
  • Increased resolution to get rid of warping on 360 media
  • Fixed stereo 180 video
  • External Data Recorder Screen Based eye tracker support
  • Updated External Data Recorder to use environment variables for AI
  • Environment Variables for AI agents and APIs
  • Scripted Avatars update
  • AI Image Spawner update
  • Vizconnect for using mark avatar hands
  • Fixed speech recognition example
  • Updated AI Content Spawner
  • Updated Visual Search Single Object
  • Updated Rating Scale Example
  • Added maze model to resources
Version 2.3.6 (4/14/25)
  • Offline AI Agents from Ollama (Gemma, Deepseek, Llama, etc.)
  • Generative AI 3D models
  • Generative AI Image Spawner
  • Drawing Tool Example
  • Multi User Drawing Tool
  • 2D Screen GUI Update
  • 360 video with 3D object example
  • Hand Path Tracking
  • Randy Pausch Visual Search Example
Version 2.3.5 (3/28/25)
  • Added modules for easy import of Vive Focus Vision hand and face tracking
  • Updates to External Application Data Recorder
    • AI Data Analysis
    • Convert video to frames and ask questions can be used for any session
    • Added optional beep sound when recording done
  • Multi-User Barchart added
  • AI Agent Updates
    • Dropdown menu for selections
    • Fixed Anthropic library error
  • New simplified examples for gaze based interactions and Visual Search
  • Changed comparison_label_TTFF to “comparison_label”
Version 2.3.4 (3/13/25)
  • Fix for multi user synchronization
  • Updated External Application Data Recorder
    • Added support for Vive Focus Vision (requires using SRAnipal Driver)
    • Added Experimental AI auto tagging of view counts, asking questions about the data
    • Optimized Replay with gaze point now showing properly
    • Optimized all supported hardware devices with gaze point, eye tracking data
    • Added ability to record video of replay
    • Testing of using stand alone apps (eye tracking not supported in this mode)
  • Updated Reaction Time Example
  • Added scene_objects to built in sightlab_resources
Version 2.3.1 (2/21/25)
  • Walk Path added in Replay
  • Grab and Release Events added to Trial data and Acqknowledge markers
  • Acqknowledge now shows Gaze start and Gaze end as well as trial start and end
  • Adjustment for gazewindow to be removed if affecting frame rate (sightlab.removeGazePointWindow())
  • Dragging an environment object in the GUI adds a copy to current folder
  • Folder to open resources on the Modify Window
  • MainWindow FOV matches gazepointwindow FOV
  • Removed ‘Default’ trial (default settings are now associated with trial 1)
  • Fixed error in Driving HMD configurations related to transport
  • Fixed error when pressing ‘p’ key before trial starts
  • Rating and instruction fadequad no longer blinks on and off between ratings
  • GUI shows Trial 1 instead of Default before starting trial
  • Updated Randomize Blocks example
  • Local_vizconnect folder for Model and Media Viewer
  • Updated Projection vizconnect
  • Option to create Rating Scales/Questions/Surveys from a csv file
  • Fixed avatar head to not be visible in the avatar view Example
  • Input Dialogs example
  • Surveys example added to Ratings
  • Updated Scripted Avatar Agent (fixed timing issues).
  • Updates to Driving Simulator
  • Updated car model to fix lighting
    • Added moveable steering wheel to standard car model
    • Fixed issue with car off of ground in replay
    • Consolidated scripts
    • Optimized starting positions
    • Vive Focus Vision Support
    • First Person Viewpoint in Replay option (set to on by default)
  • Changed name of Data Recorder in Example Scripts to “External Application Data Recorder”
  • Image Viewer Sample
  • Spatial Scanning Example
  • Updated speech recognition example
Version 2.2 (1/31/25)
  • Support for Vive Focus Vision (Eye Tracking, Passthrough, Hand Tracking, Face Tracking)
  • Fixed an issue where eye tracked headsets may not have been tracking in the GUI version
  • Added Gemini and Vision capabilities to AI agent scripts (avatar can be "aware" of scene)
  • Fixed performance issue with individual eye gaze points (made those a flag)
  • Asset Browser to download individual procured assets (environments, objects, avatars, 360 media), along with links to additional asset libraries and AI creation tools (found in main folder)
  • Reaction Time updates and reaction time with selector tool
  • Proximity Area Placer helper module
  • Fixed issue with not being able to override the position resetting on every trial
  • Example showing saving Biopac Data to Data files (added this also to Biofeedback example)
  • Speech Recognition Example (changing state of objects with voice)
  • Shared State Multi User example
  • Updated all Mixed Reality, Face Tracking, Eye tracking, and basic hand tracking scripts to support Vive Focus Vision
  • Synchronize states of any data with multi-user
  • Fixed Biofeedback example to support multiple trials
  • Updated Analysis Comparison to more easily modify measure value and label
  • Server option to view in headset
  • Waiting Room and whiteroom added to default resources
  • Fix for error when deleting default environment
  • Pressing refresh on avatar list selects Glowman Blue
Version 2.1 (1/14/25)
  • Hardware chooser now shows up after pressing Continue on GUI instead of right away
  • Ability to fine tune regions of interest with 360 media
  • Support for screen based eyetrackers from Tobii and EyeLogic
  • New Scripted Avatar Example
  • Updated Driving Example
    • Car is now an encapsulated class that can be more easily added to any script
    • Moving steering wheel added
    • Speed increase and decrease can now be incremental while holding gas or brake
    • Engine audio pitches up or down based on speed
    • Saving of velocity and position data
    • Added Jeep model
  • Updates and optimizations to the following other examples
  • STIM file and Visual Search randomized variables now playback in correct order on session replay and choice is saved to data files
  • Updated Virtual Screen STIM to properly replay chosen videos
  • GUI version of visual search highlighter example
  • Added comparison for Memory Experiment
  • Updated Art Gallery visual search
  • Rotoscoped Avatars example
  • AI Agent SpeechRecognition now works without the need to modify core python files
  • Access to avatar head folder for swapping out multi-user avatars
  • Additional bug fixes and optimizations to many example scripts
Version 2.0.6 (12/26/24)
  • Fixed issue that caused some multi user replays not to work
Version 2.0.5 (12/13/24)
  • Fixed issue with removing scene objects in the replay
Version 2.0.4 (12/11/24)
  • Fixed bug that affected Session Replay
  • Added headlight option to replay class
Version 2.0.3 (12/11/24)
  • Fixed error with scrubbing forward while at the end of the replay
  • Minor Bug fixes
Version 2.0.2 (12/4/24)
  • Fixed moviepy code to work with latest version for compressing videos
  • moviepy and psutil libraries included in installer
  • SightLab doctor utilities to check system (in "Util_Files")
  • Trial version doesn't freeze when timer runs out, closes window instead
  • AI Intelligent Agent Update
    • Multiple Agent Interactions (AI Agents can speak with each other, even if using different LLM models, such as Anthropic and OpenAI)
  • External Application Data Recorder Update
    • Given the window title the recorder will now automatically select the other application's window (requires install of pywin32 python library)
    • Video recordings now saved in the 'recordings' folder with same name as session
    • Replay can select recording with same name as session
    • Re-adjusted replay screen size to better fit HMD view
    • Adjustable replay screen
    • Version added using GUI
    • Sync event also can use events such as a triggerPress
  • Heatmap Visualizer (All Trials) now supports 360 media as well
  • Small bug fixes and updates on Gaze Based Events and Selector Tool Examples
Version 2.0.1 (11/18/24)
  • Removed python files from showing in avatar, controllers and gaze point choice lists
  • Fixed issue where custom data was not being saved to timeline data file
  • Fixed error when closing client script before pressing "Continue" while server already running
  • Updated Mirror Demo:
  • Added "reset" key 'r'.
  • Added adjustment for Mixamo avatars' position.
  • Added settings for different avatar libraries.
Version 2.0 (11/12/24)
  • Upgraded GUI functionality, including multiple condition setups and more advanced experiment design
  • Improved organization of code and class structure
  • Ability to store and load custom experiment setup project files
  • New folder and project based structure (all data, recordings, replays stored per folder)
  • New options for directory management within the GUI
  • A unified script for 3D models and 360 media
  • Updated heatmap visualization, including dynamic playback and aggregated heatmap
  • Fixation and dwell sphere visualizations
  • Improved scan and dispersion paths
  • Optimizations and general improvements on Session Replay
  • Enhanced algorithms for fixations and saccades
  • Saccade amplitude, velocity and peak velocity (trial data and experiment summary)
  • Better performance and lower memory usage
  • Enhanced rating system and participant instructions (including custom images)
  • Detailed data collection for specific objects of interest
  • Providing of raw data and summary data files
  • Individual eye data for intersect points and eye rotation
  • Simplified data toggling per trial
  • Avatar animations in session replay
  • Improved setup for 360 regions of interest
  • Improved experiment paradigms and flow control using GUI, STIM Files or code
  • Noise reduction algorithm
  • Ability to publish experiments as executables
  • Save data files as combined or per trial
  • Jump To Navigation Menu
  • Updated 3D Menu Tool
  • Traffic flow and collision example (in Driving Example)
  • Memory Task
  • Choice Comparison experiment
  • And much more
Version 2.0 Beta 2 (10/2/24)
  • Multi User improvements and updates
  • Bug fixes
  • Removed need to add multiple lines for saving custom data
Version 2.0 Beta 1 (7/18/24)
