SightLab Code Reference
  • For help with coding in SightLab, can also use the custom SightLab GPT, details here
  • To see how to import SightLab into an existing project see this page
  • For more information on the additional modules and code available with Vizard see the Vizard Documentation. Or  the Vizard Command Index
  • This page does not include all code available with SightLab. Also see the rest of the documentation or the examples page
Importing and Initial Setup
You no longer need to import vizconnect, viz, vizfx, or viztask separately as these are automatically included in the settings file.
To initialize SightLab, use the following:
# Create a SightLab instance
sightlab = sl.SightLab()
# Disable GUI
sightlab = sl.SightLab(gui=False)
Example Usage
#Import SightLab Module and Settings File
# Initialize SightLab without GUI
# Set up environment
env = vizfx.addChild('sightlab_resources/environments/dojo.osgb')
sightlab.setEnvironment(env)
# Add scene objects
soccerball = env.getChild('soccerball')
sightlab.addSceneObject('soccerball', soccerball, gaze=True, grab=True)
# Set trial count and start the experiment
sightlab.setTrialCount(3)
#Run main SightLab loop for data collection
def sightLabExperiment():
    yield viztask.waitEvent(EXPERIMENT_START)
    for i in range(0, sightlab.getTrialCount()):
        yield sightlab.startTrial(startTrialText="Look around!\n\n Press Trigger or Left Mouse to Start")
        yield viztask.waitTime(3)
        yield sightlab.endTrial()
#Schedule Tasks
viztask.schedule(sightLabExperiment)
viztask.schedule(sightlab.runExperiment)
Note: For multi-user use sightlab = sl.SightLabServer() or sightlab = sl.SightLabClient()
Class Overview
The SightLab class initializes a visual experiment environment with attributes for controlling the experiment settings.
Attributes:
  • gui (bool): Enables the graphical user interface.
  • pid (bool): Enable or disable the participant ID.
  • biopac (bool): Enables integration with Biopac systems.
  • timer (bool): Enables the timer.
  • fadequad (bool): Enables the fade quad.
  • headlight (bool): Enables the headlight.
  • mouselock (bool): Locks the mouse cursor.
  • gazepathvisible (bool): Makes the gaze path visible at the end of a trial.
  • console (bool): Enables the console display.
  • screenrecord (bool): Enables recording of the screen.
  • gazepointvisible (bool): Makes gaze points visible on the mirrored view.
  • trackingdatalogging (bool): Logs tracking data.
  • replaydatalogging (bool): Logs replay data.
  • experimentdatalogging (bool): Logs experiment data.
  • timelinelogging (bool): Logs timeline data.
  • continuekey (bool): Enables the continue key (default: spacebar).
  • trialcount (int or None): Number of trials or None if unlimited.
  • configPath (str or None): Path to the configuration file created with the GUI. Use to run from this config with no GUI.
  • repetitions (int): Number of repetitions for trial blocks.
  • datafilesaving (str): PER_TRIAL or COMBINED for saving data files.
  • hardwareconfig (str or None): Specify hardware configuration (e.g., "Desktop").
  • vizconnectconfig (dict or None): Specify custom vizconnect configuration from a dictionary.
  • vizconnectconfiglist (list or None): Specify what to show in the hardware dropdown from built-in options.
  • highlighttool: Enable the highlighter tool
  • title: Rename the title shown on the menus and GUI for custom applications
  • Server/Client Only: avatarintersect (bool): Enables avatar intersection tracking (default: True). Only used when serverMode is enabled.
  • individual_eye_intersect = False: Enables saving orientation (yaw, pitch and roll) values from the individual eyes.
  • oldHeaders: Set to True to set the data file headers to be the ones from SightLab 2.4 and earlier (False will keep it with the updated ones)
  • optimizeintersect: True: improves frame rate by doing faster intersection tests
  • fastload = False: Load the GUI without loading the preview environment and choose instead an image or a different environment. Can be used for a GUI splashscreen, or if using a very large model to avoid long load times.
Setting the Environment
To configure the environment for your experiment, such as loading 3D models or 360 media:
env = vizfx.addChild("sightlab_resources/environments/dojo2.osgb")
Method Parameters:
  • env: The environment object to be used.
  • trial (str): The trial type, default is 'DEFAULT'.
  • mode (str): The mode of the experiment, e.g., 'MODEL_3D' or 'MEDIA_360'.
  • mediaType (str): Type of media, default 'video' or 'image'. (only applicable if using MEDIA_360)
  • mediaFormat (str): Format of the media, default 'stereo'. (only applicable if using MEDIA_360)
  • headlightIntensity (int): Intensity of the headlight, default 0.
Managing Trials
Setting Trial Count:
sightlab.setTrialCount(5)
Starting a Trial:
You can start a trial using keyboard/button events or programmatically within a script:
Note that it is best practice to add this before the trial starts so everything can properly load
Using Keyboard Events:
vizact.onkeydown(" ", sightlab.startTrial)
Programmatic Start:
yield viztask.waitTime(0.1)
    trialLength=60, trialLabel="A", startTrialText="Beginning Trial"
Parameters:
startTrial(
    condition=NO_CONDITION,
    trialLength=-1,
    trialLabel="A",
    startTrialText=None,
    startExperimentText=None,
    textContinueEvent="triggerPress",
    textContinueKey=None,
    trackingDataLogging=True,
    replayDataLogging=True,
    experimentSummaryLogging=None,
    timeLineLogging=None,
    startPoint=None,
    startEuler=None,
  • condition : Can choose what starts the trial (options are KEY_PRESS, TIMER, ON_MEDIA_END, ON_GAZE_TIME and CUSTOM_EVENT). Note this can also be left to None and use a yield viztask like "yield viztask.waitKeyDown" or this can be set up in the GUI (example condition = [KEY_PRESS, ' '])
  • trialLength (int): Duration of the trial in seconds. -1 means no time limit.
  • trialLabel (str): Sets the trial label.
  • startTrialText (str): Optional text to display at the start of the trial.
  • startExperimentText (str): Optional text to display at the start of the experiment.
  • startRatings: Set up a start rating scale
  • textContinueEvent(str): event to close starting text and start the trial (i.e. 'triggerPress')
  • textContinueKey: key to close starting text and start the trial (i.e. ' ')
  • trackingDataLogging(bool): track data logging on or off
  • replayDataLogging(bool): track logging for the replay
  • experimentDataLogging(bool): track logging for the experiment summary
  • timelineLogging(bool): track logging for the timeline
  • startPoint: change the starting position
  • startEuler: change the starting rotation
Ending a Trial:
vizact.onkeydown("e", sightlab.endTrial)
Parameters:
endTrial(
    endTrialText=None,
    endExperimentText=None,
    textContinueTimer=None,
    endRatings=None,
  • condition = NO_CONDITION: Choose what ends the trial. (options are KEY_PRESS, TIMER, ON_MEDIA_END, ON_GAZE_TIME and CUSTOM_EVENT)
  • endTrialText (str): Optional text to display at the end of the trial.
  • endExperimentText (str): Optional text to display at the end of the experiment.
  • endRatings : Set up an end rating scale
Direct Event Trigger:
To directly send an event to end a trial from within a function:
viz.sendEvent(INITIATE_TRIAL_END)
Use this method when you need to trigger the end of a trial based on specific logic or external conditions.
Scheduling SightLab
viztask.schedule(sightlab.runExperiment())
Setting Condition Based on Hardware Setup
You can set up specific conditions based on the hardware configuration being used. For instance, to check if the hardware is a "Meta Quest Pro" and adjust your experiment setup accordingly (making sure this is added AFTER the sightlab experiment starts)
if sightlab.getConfig() == "Meta Quest Pro":
# Add conditional logic for Meta Quest Pro hardware
Adding and Managing Scene Objects
Adding Scene Objects
To add objects to the scene, use the addSceneObject method. This allows you to track gaze, grab interactions, and set visibility for the objects. Note: you only need to add the parameters you need. If you only add the name and sceneObject it will just be tracked for replay, but not gaze or grab data and interactions.
sightlab.addSceneObject(name, sceneObject, gaze=True, grab=False, visible=True, avatar=False)
Parameters:
  • name (str): Name identifier for the scene object.
  • sceneObject: The instance of the scene object to add.
  • gaze (bool): Enable gaze tracking for the object.
  • grab (bool): Enable grab interactions for the object.
  • visible (bool): Visibility of the object (default: True).
  • avatar (bool): Treat the object as an avatar if True.
Multiple Objects:
You can add multiple objects in bulk:
sceneDict = {'Soccerball': [True, True], 'Baseball': [True, True]}
for item in sceneDict:
    sightlab.addSceneObject(item, env.getChild(item), gaze=sceneDict[item][0], grab=sceneDict[item][1])
Session Replay
The SightLabReplay class allows for replaying sessions, interacting with objects, and retrieving trial and gaze data. For more information and all the relevant code with the replay, see this page
Import and Setup:
from sightlab_utils import replay as Replay
from sightlab_utils.replay_settings import *
replay = Replay.SightLabReplay()
Session Replay Methods:
  • Set Replay Position:
replay.transportNode.setPosition([x, y, z])
  • Accessing Environment in Replay:
env = replay.getEnvironmentObject()
  • Access Scene Objects:
screen = replay.sceneObjects[GAZE_OBJECTS]["screen"]
avatarObject = replay.sceneObjects[AVATAR_OBJECTS]["avatar"]  #avatars added to scene
gazePointObject = replay.sceneObjects[GAZE_POINT_OBJECT]["1"]
avatarHead = replay.sceneObjects[AVATAR_HEAD_OBJECT][client]
avatarRightHand = replay.sceneObjects[AVATAR_RIGHT_HAND_OBJECT][client]
region_1 = replay.sceneObjects[REGIONS_OF_INTEREST]["nameOfRegion"]
region_1.alpha(0.5) #Code if wanting to see the regions in the replay
  • Get Trial Number:
trial_number = int(replay.currTrial)
  • Perform action when trials are changed (this can be useful for more dynamic experiment playbacks)
def ontrialchanged():
    print("change: ", trial_number)
viz.callback(TRIAL_LOADED_EVENT, ontrialchanged)
  • Access folder where trial is running from
dataFile = replay.dataFolder
Replay Attributes
noiseFilter (bool, optional)
Indicates whether to apply a noise filter to the replay data, which can be useful for reducing noise in eye-tracking or motion data.
trialNumber (int or None, optional)
Specifies the trial to replay. If None, the replay will include all trials available in the dataset.
sightlab_1_9 (bool, optional)
A compatibility flag to replay data from older versions of SightLab, particularly version 1.9.
dataDirectory (str, optional)
Specifies the directory where the experimental data is stored. Defaults to 'data', but this can be adjusted for custom datasets or project folders.
headlight (optional)
Turn the headlight on or off for the replay.
Custom Replay Flags and Events in Replay
Set custom flags during an experiment session and visualize them in the replay (for instance to keep track of the state of an object like color change and play that back in the replay at the correct time). See also ExampleScripts\Replay_Events
Example
#Visibility
def changeVisibility():
    Les_Paul.visible(viz.TOGGLE)
vizact.onkeydown("a", changeVisibility)
def getVisibility():
    visibilityFlag = Les_Paul.getVisible()
    sightlab.setCustomReplayFlag("visible", visibilityFlag)
vizact.onupdate(0, getVisibility)
#Replay Side
def applyReplayFlag():
    Les_Paul = replay.sceneObjects[GAZE_OBJECTS]["Les_Paul"]
    flag_data = replay.getCurrFlag()
    if "visible" in flag_data:
        print(flag_data)
        Les_Paul.visible(flag_data["visible"])
vizact.onupdate(0, applyReplayFlag)
Ratings and Instructions
Ratings:
yield sightlab.showRatings('How are you feeling?', ratingScale=scaleList, pauseTimer=True)
  • scaleList: Can be a custom list (e.g., "A", "B", "C" or "Yes", "No").
  • sightlab.ratingChoice: Get the selected rating value.
You can also add a start or end rating scale within the trial using the startTrial or endTrial methods. See here for more information
Instructions:
yield sightlab.showInstructions("Press Space to Continue")
yield viztask.waitEvent("triggerPress")
yield sightlab.hideInstructions()
Can also add a start or end instructions or use images (see here for more information)
To show instructions before trial starts
    yield sightlab.showInstructions('Look Around the Room')
        yield sightlab.startTrial()
Gaze-Based Interactions
You can trigger events based on gaze interactions within your scene. For example, detecting when a participant finds a target object: see here for more information
This is how you check which object is being viewed
if e.object == sightlab.sceneObjects[GAZE_OBJECTS][TARGET_PAINTING]:
Example
def gazeActionEnd(e):
    if e.object == sightlab.sceneObjects[GAZE_OBJECTS]['target_object']:
        print('item found')
vizact.addCallback(sightlab.GAZE_TIME_EVENT, findItem)
Start and Stop Events
def gazeActionStart(e):
    if e.object == sightlab.sceneObjects[GAZE_OBJECTS]['creature1']:
        creature1.state(6)
        print('saw creature')
        creature1.state(4)
        print('stopped looking')
vizact.addCallback(sightlab.GAZE_TIME_EVENT, gazeActionStart)
vizact.addCallback(sightlab.GAZE_END_EVENT, gazeActionEnd)
Adjusting Thresholds
Note: these need to be set after .startTrial()
sightlab.setDwellTimeThreshold(dwellTime = DWELL_THRESHOLD)
sightlab.setFixationSaccadeThresholds(dispersionThreshold = 1, durationThreshold = 0.1)
Setting Position
Reset Position
viz.callback(viz.getEventID("ResetPosition"), sightlab.resetViewPoint)
This will reset your position back to the origin relative to your physical location. To change this point to a different value, will need to manually add the resetPosition code.
Disabling Position Reset Between Trials
lastPos = sightlab.transportNode.getPosition()
sightlab.setStartPoint(lastPos)
Changing Starting Position
SightLab (can also add a Starting Point object in the GUI (see Creating a New Scene), or when calling sightlab.startTrial()
sightlab.transportNode.setPosition([0, 0, 0])
# or can use this
sightlab.setStartPoint((2, 0, 0))
Session Replay Starting Point
replay.transportNode.setPosition([0, 0, 0])
Getting position
def printUserPosition():
    userPos = sightlab.transportNode.getPosition()
    print(userPos)
vizact.onkeydown('v',printUserPosition)
Miscellaneous
  • Change Default Folder:
sightlab.setEnvironmentDirectory("path_to_resources_folder")
  • Disable Transport
sightlab.setTransportState(viz.OFF)
#or
vizconnect.getTransport('main_transport').setEnabled(viz.OFF)
FF)
  • Set Starting Text:
sightlab.setStartText("Press Spacebar to start")
  • Turn FadeQuad on or off
yield sightlab.hud.fadeQuad.fade_in()
  • Run a Loop for Each Trial:
for i in range(sightlab.getTrialCount()):
# Custom logic for each trial
  • Set Objects as Invisible:
sightlab.addSceneObject("wall2", wall2, gaze=True, visible=False)
  • Getting Access to the Eye Tracker:
sightlab.getEyeTracker()
  • Working with STIM Files
To work with STIM files, initialize the StimReader: see here for more information
from sightlab_utils import stim_reader
SR = stim_reader.StimReader(STIM_FILE_LOCATION)
SR.fillStimFileEntryList()
  • Getting Child Object Position:
If you are using env.getChild to access your objects you need to use a .getTransform to access the object's position:
targetTransform = env.getTransform("targetTransform")
Alternatively, use env.getChild on the object's GEODE
or use a boundingBox
node3d.getBoundingBox(viz.ABS_GLOBAL).center
  • Get Current Time
sightlab.hud.getCurrentTime()
  • Setting Maximum Distance for Gaze Intersection:
sightlab.setMaxDistance(1000)
  • HeadLight On or Off
sightlab.setHeadLight(state, intensity=None, color=None)
  • Trial End Event: The TRIAL_END_EVENT is now simply TRIAL_END.
  • Vizconnect Config: VIZCONNECT_CONFIGS is now VIZCONNECT_CONFIG.
  • Environment Constant: Use "ENVIRONMENT_MODEL" instead of "ENVIRONMENT".
Working with 360 Media
  • Get Media Object (this gets access to the video file used, so can then use things like .play(), etc.):
sightlab.getMediaObject()
#Example
mediaFile = sightlab.getMediaObject()
mediaFile.pause()
* Get Sphere object (to be able to rotate, scale or perform actions on the underlying sphere object)
media360 = sightlab.getEnvironment()
media360.setEuler(180,0,0)
  • Accessing Regions of Interest for 360 Media:
region1 = sightlab.getRegionOfInterest("tire")
Accessing Environment Object
env = sightlab.getEnvironment()
Using the environment object in context
#Access after EXPERIMENT_START
    global env
#If need access to it before use env = None, and put inside a function that can be called after it is set in the trial
def initialize_environment():
    target = env.getChild(name)
  global env
Changing Models to use for Avatar/Hands/Gaze Point
head = vizfx.addChild(AVATAR_HEAD_RESOURCE_PATH+'/Male1.osgb'))
sightlab.setAvatarHead(head)
Note that for Multi-User you will also need to add the object as a sceneObject on the server and clients and may also need to set the added object to not be visible for the local client (so it doesn't show up in front of your viewpoint)
head = vizfx.addChild('basketball.osgb')
head.visible(viz.OFF)
sightlab.addSceneObject('head', head)
avatarModel = sightlab.setAvatarHead(head)
#On server
#for additional clients
head2 = vizfx.addChild('soccerball.osgb')
sightlab.addSceneObject('head2', head2)
head2.visible(viz.OFF) #seat only the head you're using to not be visible
avatarModel = sightlab.setAvatarHead(head2)
Other way
#Setting Head
sightlab.setAvatarHead(head=vizfx.addChild(AVATAR_HEAD_RESOURCE_PATH + "/Male1.osgb"))
# Setting Hands
sightlab.setAvatarRightHand(
    rightHand=vizfx.addChild(AVATAR_HANDS_RESOURCE_PATH + "/empty.osgb")
#Setting new gaze point object model
newGazePoint = vizfx.addChild('resources/gaze_point1a.osgb')
sightlab.setGazePointObject(newGazePoint)
#Note need to disable intersections and shadows
newGazePoint.disable(viz.SHADOW_CASTING)
newGazePoint.disable(viz.INTERSECTION)
Toggling Visibility of Overlays
sightlab.toggleHUD()
Data Logging
For more information see this page
addCustomFlagColumn(self, columnName)
addTrackingTrialDataColumn(self, columnName, trackedObject, dataType="SIXDOF", mode=4)
sightlab.setExperimentSummaryData("condition", condition)
sightlab.addToTimeline(objectName = "basketball", dwellTime = 0.75)
Adding a Custom Flag
sightlab.setCustomTrialData('name of flag')
Changing Data Directories
sightlab.setDataDirectory()
Setting Condition/Label
yield sightlab.startTrial(trialLabel="A")
Adding additional file to the Data folder
fileName = '{d}_{p}_experiment_data._trial_{t}.pdf'.format(d=sightlab.dateTime, p=sightlab.participantData[ID], t=sightlab.trialNumber)
fullPath = os.path.join(sightlab.getExperimentDataFolderPath(), fileName) drawChart(fullPath, sightlab.getPlotData())
Settings File
See here for information on the settings file located in the sightlab installation folder
Multi User
For code relevant to Multi User see this page
Hardware Events
Hardware button and keyboard mappings can be accessed to trigger functions. See the page on the Vizconnect Hardware Configurations page for a list.
Method Reference
Environment and Setup:
  • setEnvironment(env, trial='DEFAULT', mode='MODEL_3D', mediaType="video", mediaFormat="stereo", headlightIntensity=0): Sets the virtual environment for the experiment (e.g., 3D models, 360 videos).
  • getEnvironment(): Retrieves the current environment object.
  • setEnvironmentFolder(): Specifies the folder containing the environment assets.
  • setEnvironmentDirectory(path): Sets the directory for environment files.
  • getCurrentEnvironmentName(): Returns the name of the current environment.
Trial Management
  • setTrialCount(count): Sets the total number of trials for the experiment.
  • getTrialCount(): Returns the total number of trials.
  • setTrialLength(seconds): Defines the length of each trial.
  • startTrial(trialLength=-1, ...): Begins a trial, optionally specifying trial length, conditions, and starting text.
  • endTrial(endTrialText=None, endExperimentText=None): Ends a trial and optionally displays text at the end of the trial or experiment.
  • resetTrial(): Resets the current trial.
  • getTrialNumber(): Retrieves the current trial number.
  • runTrial(): Runs a trial based on pre-configured settings.
  • getCurrentTrialDirectory(): Returns the directory where the current trial data is stored.
  • getCurrentRepetition(): Returns the current repetition number for repeated trials.
  • setStartText(text): Sets the text displayed at the start of the trial.
Object Management
  • addSceneObject(name, object, gaze=False, grab=False, visible=True, avatar=False): Adds an object to the scene for gaze, grab, or tracking interactions.
  • removeSceneObject(objectName): Removes a previously added scene object.
  • removeGazeObject(objectName): Removes an object from gaze tracking.
  • removeGrabObject(objectName): Removes an object from grab tracking.
  • removeInvisibleObject(objectName): Removes objects that were set as invisible.
  • setGazePointObject(): Defines an object that represents the participant's gaze. Need to add model first
  • getGazePointObject(): Retrieves the current gaze point object.
Avatar Management
  • setAvatarHead(head): Sets the head model for an avatar. Need to add model first
  • getAvatarHead(): Retrieves the current head model of the avatar.
  • setAvatarLeftHand(): Sets the left-hand model for an avatar. Need to add model first
  • setAvatarRightHand(): Sets the right-hand model for an avatar. Need to add model first
  • getAvatarLHand(): Gets the current left-hand model of the avatar.
  • getAvatarRHand(): Gets the current right-hand model of the avatar.
Gaze and Tracking
  • setDwellTimeThreshold(seconds): Sets the amount of time a participant needs to gaze at an object for it to be logged as a "dwell."
  • getCurrentGazeEventData(): Retrieves the current gaze data.
  • getGazeTimeObject(): Returns the current object being gazed at.
  • setFixationSaccadeThresholds(): Sets the thresholds for defining fixations and saccades in the eye-tracking data.
  • showGazePath(): Displays the path of the participant's gaze over time.
  • toggleGazePoint(): Toggles the visibility of the gaze point in the scene.
Data Logging
  • setDataDirectory(path): Sets the directory where data logs are saved.
  • setExperimentSummaryData(column, value): Adds custom data to the experiment summary log.
  • addTrackingTrialDataColumn(name): Adds a new column to the tracking data logs.
  • setCustomTrialData(value, column): Sets a custom value in a specified trial data column.
  • setDataLoggingState(state): Enables or disables data logging.
  • getPlotData(): Retrieves data for creating visual plots from the trial data.
  • getExperimentDataFolderPath(): Gets the folder path where experiment data is saved.
  • showRatings(text, options): Displays a rating scale for participants to provide feedback during a trial.
  • hideRatings(): Hides the rating scale from the view.
  • showInstructions(text): Displays instructional text during the experiment.
  • hideInstructions(): Hides the instructions currently shown to the participant.
Recording and Replay
  • compressRecording(): Compresses the recorded session for playback.
  • screenCapture(): Captures a screenshot of the current scene.
  • storeReplayExecCode(code): Stores executable code during replay mode.
  • setCustomReplayFlag(flag): Sets a custom flag for replay purposes.
  • getMediaObject(): Retrieves media objects for replay.
  • addToTimeline(event): Adds an event to the trial timeline for later reference.
  • getTimeLineData(): Returns timeline data captured during the trial.
Control and Transport
  • resetViewPoint(): Resets the participant's viewpoint to a default position.
  • setStartPoint(position): Sets the starting position for the participant in the scene.
  • setTransportPosition(position): Sets the position for the transport object (if using one).
  • setTransportState(state): Enables or disables transport mechanics (e.g., walking, teleporting).
HUD and Console
  • toggleHUD(): Toggles the visibility of the heads-up display (HUD).
  • setConsoleState(state): Enables or disables the console display.
  • togglePoint(): Toggles the display of point markers in the scene.
  • setHeadlight(intensity): Sets the intensity of the headlight (lighting attached to the participant's viewpoint).
Region of Interest (ROI)
  • addRegionOfInterest(name, object): Adds a region of interest (ROI) to the scene for tracking focus.
  • getRegionOfInterest(name): Retrieves a specific ROI object from the scene.
Experiment Control
  • runExperiment(): Starts the experiment loop.
  • resetExperiment(): Resets the experiment to its initial state.
  • conditionEventManager(): Manages condition-based events for the experiment.
  • experimentSetupCompleteStatus(): Checks if the experiment setup is completed.
Miscellaneous
  • getConfig(): Retrieves the hardware configuration (vizconnect) of the experiment.
  • setConfigDirectory(path): Sets the directory where configuration files are stored.
  • setRecordingsDirectory(path): Sets the directory where recordings are saved.
  • setMaxDistance(distance): Sets the maximum distance for collecting gaze data.
  • setConditionName(name): Sets the name for the current condition of the experiment.
  • getConditionName(): Retrieves the current condition name.
  • setHighlighter(object): Enables a highlighter on the specified object to make it visually stand out.
