Visual Search Sample Guide
This guide walks you through customizing a Visual Search Task in SightLab VR, where participants locate a target among distractors using gaze-based detection. The script records reaction time per trial and allows for either feature or conjunction search.
⚙️ Editable Parameters
Customize these settings at the top of the script:
# Enable conjunction search (target shares features with distractors)
CONJUNCTION_SEARCH = False
# Set how many distractors per trial
NUM_DISTRACTORS = 11
# Total number of trials in the experiment
TRIALS = 3
# Choose your environment
ENVIRONMENT = 'sightlab_resources/environments/RockyCavern.osgb'
🎯 Target & Distractor Models
By default, this script uses .osgb models for objects:
- If
CONJUNCTION_SEARCHisFalse: - Target: Red cube
- Distractors: Blue cubes
- If
True: - Target: Red sphere
- Distractors: Red cubes and blue spheres
You can swap models using:
TARGET_OBJECT = vizfx.addChild('path/to/your_model.osgb', color=viz.RED)
You can also adjust distractors via:
DISTRACTOR_FACTORIES = [
lambda: vizfx.addChild('your_model_path.osgb', color=viz.BLUE)
🗺 Object Placement Settings
Objects spawn randomly in a 3D volume defined by:
X_RANGE = (-2.0, 2.0) # left/right
Y_RANGE = (1.2, 2.0) # up/down
Z_RANGE = (-2.0, 3.0) # forward/back
MIN_DISTANCE = 0.5 # minimum distance between objects
This ensures spatial separation between target and distractors.
✅ Gaze-Based Detection
Gaze is automatically tracked on the TargetCube and distractors. The trial ends once the participant looks at the target long enough.
sightlab.addSceneObject('TargetCube', target, gaze=True)
Gaze events are handled with:
def gazeOnTarget(e):
if e.object == sightlab.sceneObjects[GAZE_OBJECTS]['TargetCube']:
# Save reaction time and end trial
🔁 Trial Flow
The script sets up trials like this:
- Show instructions:
"Find the red cube!"(customizable). - Wait for trigger press.
- Randomly place objects.
- Wait for gaze detection on the target.
- Log reaction time.
- End trial.
🧪 Output & Summary Data
After each trial, the time to locate the target is saved:
sightlab.setExperimentSummaryData('Time to Find Target', time_to_find_target)
SightLab automatically logs this to CSV under your project’s data folder.
🧱 Extending It
You can expand this experiment in several ways:
- Add target-absent trials
- Vary the number or type of distractors
- Include a rating scale after trials (see SightLab's
showRatings()in the rating scale doc) - Use
sightlab.showInstructions()for multi-step instructions
Visualizations
Use the Session Replay to replay gaze paths, walk paths, heatmaps and more using SightLab’s built-in tools.
Biopac Integration**
Send markers using:
sightlab = sl.SightLab(gui=False, biopac = True)
