Adaptive learning
Adaptive Learning Overview
Two templates showing how to adjust a stimulus parameter (e.g., display duration) based on both success/failure and reaction time (RT). One is a sample for training a machine learning model based on participant success, the other is a simple 1-up/1-down staircase method.
Machine Learning Version
The machine‐learning models update online (i.e., trial by trial) with each new data point. Uses scikit-learn
https://scikit-learn.org/stable/
Note: This example is not enough data for reliable prediction modeling, but it's a great proof-of-concept or starter demo for adaptive behavior.
1. Dependencies & Models
Python Libraries
NumPy (array handling)
scikit-learn
SGDClassifier: simple logistic classifier for “success vs. fail”SGDRegressor: simple linear regressor for “parameter → RT”
How It Works (High Level)
Classifier learns, on every trial:
[parameter] → {0 or 1} (fail or success)so it estimates “If I show for X seconds, what’s P(success)?”
Regressor learns, on success trials only:
[parameter] → RT (in seconds)so it estimates “If they succeed with X, how fast do they react?”
Online Learning: After each trial, both models are updated immediately with the new (parameter, outcome) and (parameter, RT) data.
2. Adaptive Loop (High Level)
- Present Stimulus using the current parameter (e.g., show for 3.0 s).
- Record:
- success = True/False
- rt = measured reaction time (or
Noneif failed) - Update Classifier with
(current_param → success). - Update Regressor (only if success) with
(current_param → rt). - Select Next Parameter:
- Generate candidate values from
MINtoMAXinSTEPincrements. - Filter out any candidate whose predicted P(success) <
SUCCESS_P(e.g., 0.70). - Among the remaining, choose the one whose predicted RT is closest to your
target_rt(e.g., 1.0 s). - Repeat for each trial.
3. Console Printout Example
Each trial prints:
Prev=3.00, Success=True, RT=1.18 → Next=2.50, P=1.00, PredRT=1.00
- Prev=3.00: last trial’s parameter (3 s).
- Success=True: participant succeeded.
- RT=1.18: measured RT (1.18 s).
- Next=2.50: chosen parameter for next trial.
- P=1.00: classifier’s predicted success probability at 2.50 s (≥ threshold).
- PredRT=1.00: regressor’s predicted RT at 2.50 s (closest to target).
4. Extracted Code Snippet
Copy and paste this ML-only logic into your own experiment—replace present_stimulus(...) and measure_rt() with your code:
import numpy as np
from sklearn.linear_model import SGDClassifier, SGDRegressor
# ── 1) Setup ─────────────────────────────────────────────
classifier = SGDClassifier(loss="log_loss", learning_rate="constant", eta0=0.5)
regressor = SGDRegressor(learning_rate="constant", eta0=0.1)
fitted_cls = False
fitted_reg = False
MIN_PARAM = 1.0 # e.g., seconds
MAX_PARAM = 5.0
STEP = 0.25
SUCCESS_P = 0.70 # require ≥70% success
TARGET_RT = 1.0 # desired RT (seconds)
current_param = 3.0 # initial value
# ── 2) Trial Loop ───────────────────────────────────────
for trial in range(total_trials):
# a) Present stimulus for current_param and record outcome
present_stimulus(current_param)
success = get_success() # True/False
rt = get_reaction_time() if success else None
# b) Update Classifier on (current_param → success)
X_cls = np.array([[current_param]])
y_cls = np.array([1 if success else 0])
if not fitted_cls:
classifier.partial_fit(X_cls, y_cls, classes=[0,1])
fitted_cls = True
classifier.partial_fit(X_cls, y_cls)
# c) Update Regressor (only if success) on (current_param → rt)
if success and rt is not None:
X_rt = np.array([[current_param]])
y_rt = np.array([rt])
if not fitted_reg:
regressor.partial_fit(X_rt, y_rt)
fitted_reg = True
# d) Choose next parameter
best_p, best_diff = 0.0, float("inf")
next_param = current_param
chosen_pred_rt = None
for t in np.arange(MIN_PARAM, MAX_PARAM + STEP, STEP):
p_success = classifier.predict_proba([[t]])[0][1]
if p_success < SUCCESS_P:
continue
if fitted_reg:
pred_rt = regressor.predict([[t]])[0]
diff = abs(pred_rt - TARGET_RT)
pred_rt, diff = None, 0.0
# Prefer higher p_success; if tied, smaller |pred_rt - TARGET_RT|
if (p_success > best_p) or (p_success == best_p and diff < best_diff):
best_p, best_diff = p_success, diff
next_param = t
chosen_pred_rt = pred_rt
print(
f"Prev={current_param:.2f}, Success={success}, RT="
f"{rt if rt is not None else 'miss'} "
f"→ Next={next_param:.2f}, P={best_p:.2f}, "
f"PredRT={chosen_pred_rt if chosen_pred_rt is not None else 'N/A'}"
current_param = next_param
present_stimulus(current_param): your code to show whatever you need forcurrent_param.get_success(): returnTrueif participant succeeded, elseFalse.get_reaction_time(): return RT in seconds (only ifget_success()wasTrue).
Paste this snippet into your trial sequence
1-up/1-down staircase Method
On hit: duration decreases by one STEP
On miss: duration increases by one STEP
HUD (statusText) now shows the updated duration and result each trial.
How to Adapt as a Template
- Swap Stimulus: Any object, image, sound, or prompt. Record success and RT accordingly.
- Adjust Ranges: Set your own minimum/maximum and step size for the parameter.
- Set Threshold & Target: Choose a success‐probability threshold (e.g., 0.70) and a target RT (e.g., 1 s).
- Optional RT Model: If you only care about success, skip the RT model and pick the smallest value that meets your success threshold.
Over successive trials, this approach “homes in” on a parameter value that balances high success rates and your desired reaction speed.
Biofeedback-Based Adaptation (e.g., Biopac)
Use Biopac signals (e.g., heart rate, EDA) to influence trial difficulty or flow:
def outputToScreen(index, frame, channelsInSlice):
stress_val = frame[0] # e.g., EDA or heart rate
trial_difficulty = "easy" if stress_val > threshold else "hard"
sightlab.setCustomTrialData(str(stress_val), "Biopac_StressValue")
# Dynamically change object visibility, timing, etc.
This allows adaptive difficulty or trial termination/extension based on real-time physiological markers.
Additional Adaptation Ideas Using Existing SightLab Tools
Facial Expression Input (e.g., Affectiva SDK): Classify emotion (happy, frustrated) → modify task feedback or select appropriate stimulus.
Body Position & Proximity Sensors:
Use
vizproximityto start or end trials. -
Dynamically relocate objects based on user position or posture.
Eye Metrics-Based Adaptation:
Real-time gaze deviation, pupil dilation → adjust time pressure or attention-grabbing visuals.
Combined Gaze + Biofeedback:
Use gaze dwell time and elevated skin conductance to determine stress → branch the learning path.
Adaptive Rating Scales:
Combine with
sightlab.showRatings():yield sightlab.showRatings('How confident were you?', ratingScale=["Low", "Med", "High"]) if sightlab.ratingChoice == "Low": # Trigger simplified explanation or extra guidance
