Adding Instructions
Located in ExampleScripts \Instructions
Overview
Here is how you can add instructions that will show up in a headset (wherever the user looks) and on the mirrored desktop view. This can be triggered using any event (such as a yield viztask.WaitTime ). This code is also under the "ExampleScripts" folder. The default for skipping past the instruction is either with the left mouse click or controller trigger.
Basic Instructions (GUI-Based)
As of 2.8.0 you can now set start and end instructions directly in the GUI. Click "Start Text" and enter the text you want in the text field and "End Text" for the text that shows at the end of the session.
For earlier than 2.8.0 this is how you can set instructions when using the GUI. Set your start key or condition in the GUI, then use this code:
def sightLabExperiment():
yield viztask.waitEvent(EXPERIMENT_START)
#Just add this one line before TRIAL_START
yield sightlab.showInstructions('Look Around the Room')
for trial in range(sightlab.getTrialCount()):
yield viztask.waitEvent(TRIAL_START)
Start and End Text
Use startExperimentText for instructions that show at the start of the experiment or startTrialText for text that shows at the start of each trial.
yield sightlab.startTrial(startExperimentText="test", textContinueEvent="triggerPress")
End Experiment Text
yield sightlab.endTrial(endExperimentText="Done")
Example (note: \n will create a new line, creating two here for an extra space)
startExperimentText="Look Around the Room \n\n Press Trigger when Ready"
Example: Note, have the startCondition set to 'None' in the GUI for the first trial if using startExperimentText, as the trigger will be used (can be changed to another condition in the code). Subsequent trial start and stop conditions can be set in GUI or code.
#Add this code to the SightLabExperiment Function:
if sightlab.getTrialNumber() == 1:
'Look Around the Room \n\n Press Trigger when Ready')
yield sightlab.endTrial()
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
One Other Method for using code
if i != 0:
#event to start every subsequent trial
# — start trial once, with instructions only on trial 1 —
if i == 0:
startExperimentText = "Press Spacebar to Start",textContinueKey = ' ')
yield sightlab.startTrial()
Additional Instruction Methods
Basic Instructions that can be brought up anytime.
yield sightlab.showInstructions('test', pauseTimer = True)
yield viztask.waitEvent('triggerPress')
yield sightlab.hideInstructions()
yield sightlab.setDataLoggingState(1)
For instructions to show at the start, place showInstructions and waitEvent before sightlab.startTrial() . In this case you don't need hideInstructions or pauseTImer
yield sightlab.showInstructions('Do Something.\n\n Click Trigger or Left Mouse Button To Start')
for i in range(0, sightlab.getTrialCount()):
Can also use the same start condition as the trials, such as spacebar in this example
yield sightlab.showInstructions("Press 'a' to toggle basketball \n\n Press Spacebar to Continue")
Image Based Instructions
while True:
#Press spacebar to cycle image instructions before first experiment starts
sightlab.instructionsImageQuad.setScale([1,1.5,1])
yield sightlab.showInstructions(image = 'sightlab_resources/sightlab_controls.jpg')
yield sightlab.showInstructions(image = 'sightlab_resources/sightlab_controls_oculus.jpg')
sightlab.instructionsImageQuad.setScale([1.5,1,1])
while True:
if not sightlab.getTrialNumber() == 1:
Find also examples for adding multiple images or instruction text slides in the ExampleScripts
Another option for adding instructions at specific times and after certain conditions is to use a STIM file
You can also download a .jpg of an instructions (such as creating a slide in Google slides and downloading as a .jpg) then adding that .jpg to your 3d scene by using File-Add. You can then move the image by right clicking and choosing "Add-Transform" to use the move tools. This model with the instructions can then be added as a trial with tracking turned off.
