AI Object Detection — Documentation
AI Agent
Overview
AI Object Detection brings automatic object identification to VR eye tracking studies by combining real-time YOLOv8 object detection with SightLab gaze data collection. During a session, the script captures the Vizard render window, runs YOLO on each frame to identify objects in the scene, and creates invisible 3D collision volumes at the approximate positions of detected objects. These volumes are registered as SightLab sceneObjects with gaze=True, so dwell time, view count, and other gaze metrics are collected automatically per object — no manual scene object setup required.
This allows researchers to run VR eye tracking studies where participants look around a virtual environment and the system automatically records what they looked at, for how long, and how many times — all without having to pre-label every object in the scene.
Desktop testing: The script also works in desktop mode without a headset, which is useful for testing and validating detection settings before running a full VR session.
Architecture
Vizard renders 3D scene (e.g. homeOffice)
        v
Render window (or desktop mirror in HMD mode)
        v
WindowCapture (finds window by title from config)
        v
grab_yolo_frame()  -- Win32 PrintWindow -> numpy RGB array
        v
YOLODetector (background thread, ultralytics YOLOv8)
        v
DetectedObjectManager
   - Creates vizshape.addBox() collision volumes
   - Registers each as sightlab.addSceneObject(key, node, gaze=True)
   - Matches detections across frames to maintain persistent keys
   - Removes stale objects after OBJECT_PERSISTENCE_TIME
        v
SightLab collects gaze/dwell data on each tracked object
Requirements
Software
Requirement Notes
Vizard 8 WorldViz Vizard with Python 3.x
SightLab sightlab_utils must be on the Python path
ultralytics YOLOv8 — pip install ultralytics
opencv-python Image processing — pip install opencv-python
numpy Array handling — pip install numpy
pywin32 Window capture — pip install pywin32
Installing Dependencies in Vizard
Use Vizard's built-in Package Manager (Tools → Package Manager) or run pip directly from Vizard's Python:
"C:\Program Files\WorldViz\Vizard8\bin\python.exe" -m pip install ultralytics opencv-python numpy pywin32
Note: The first time ultralytics runs, it will download the YOLOv8 model file (~6 MB for yolov8n.pt). This requires an internet connection.
Files
File Purpose
AI_ObjectDetection_Config.py All tunable settings (model, thresholds, visuals, capture, environment)
AI_ObjectDetection.py Main script — run this in Vizard
How to Run
  1. Open AI_ObjectDetection_Config.py and verify settings (model, environment, confidence, etc.)
  2. CAPTURE_WINDOW_TITLE must match the Vizard render window title (default: "AI_ObjectDetection"). Set to None to be prompted with a window picker at startup
  3. Open AI_ObjectDetection.py in Vizard and press F5 (or use the "Run WinViz on Current File" task)
  4. The script loads the configured environment (default: homeOffice.osgb)
  5. Press Spacebar to start the trial — YOLO detection begins automatically
  6. The participant looks around the VR scene; detected objects appear as semi-transparent boxes with labels
  7. Press Spacebar again to end the trial
  8. SightLab saves gaze data (dwell time, view count, etc.) per detected object to the data/ folder
Runtime Keyboard Controls
Key Action
Space Start / stop trial
d Toggle debug bounding boxes on/off
i Toggle YOLO overlays in HMD (keeps them on desktop mirror for researcher)
o Toggle origin direction arrow
r Reset viewpoint position
p Toggle SightLab gaze point visibility
Configuration Reference (AI_ObjectDetection_Config.py)
YOLO Detection
Setting Default Description
YOLO_MODEL 'yolov8n.pt' Model size. Options: yolov8n.pt (nano, fastest), yolov8s.pt (small), yolov8m.pt (medium, most accurate)
YOLO_CONFIDENCE 0.4 Minimum confidence threshold (0.0–1.0). Lower = more detections but more false positives
DETECTION_INTERVAL 0.5 Seconds between YOLO inference runs. Lower = more responsive, higher = less CPU
YOLO_CLASSES None COCO class IDs to detect. None = all classes. Example: [56, 62, 63] for chair, tv, laptop
MAX_TRACKED_OBJECTS 15 Maximum simultaneous tracked objects
3D Mapping
DEFAULT_OBJECT_DEPTH 2.0 Distance (meters) in front of the view where collision volumes are placed
COLLISION_BOX_SIZE [0.2, 0.2, 0.15] Width, height, depth (meters) of each collision volume. Thicker depth = easier gaze intersection
OBJECT_PERSISTENCE_TIME 5.0 Seconds an object survives after YOLO stops detecting it. Must be > SightLab's dwell threshold (500ms) or dwell data won't accumulate
MATCHING_DISTANCE_THRESHOLD 0.5 Max normalised screen-space distance to match a new detection to an existing tracked object of the same class. Higher = more forgiving when the user moves
Visualization
SHOW_DEBUG_BOXES True Show green semi-transparent bounding boxes over detected objects
DEBUG_BOX_ALPHA 0.25 Opacity of debug boxes (0.0–1.0)
SHOW_LABELS True Show 3D text labels (class name + confidence) above each object
SHOW_OVERLAYS_IN_HMD True Whether overlays render in the HMD at startup. Toggle with i key at runtime. When off, overlays still appear on the desktop mirror
Gaze Tracking
ENABLE_GAZE_TRACKING True Register detected objects as SightLab gaze targets
USE_GAZE_BASED_ID True Print console messages and show labels when gaze dwells on an object
Window Capture
CAPTURE_WINDOW_TITLE "AI_ObjectDetection" Window title to capture. Must match the Vizard window title. Set to None to be prompted with a window picker at startup
CAPTURE_FLIP None Flip captured frame: 0 = vertical, 1 = horizontal, -1 = both, None = no flip
Other
SCREEN_RECORD True Enable SightLab's built-in screen recording
ENVIRONMENT_MODEL 'sightlab_resources/environments/homeOffice.osgb' 3D environment to load
INSTRUCTION_MESSAGE (see config) Text shown at trial start
Common COCO Class IDs
For use with YOLO_CLASSES:
ID Class ID Class ID Class
0 person 56 chair 66 keyboard
39 bottle 57 couch 67 cell phone
41 cup 58 potted plant 73 book
46 banana 59 bed 74 clock
47 apple 60 dining table 75 vase
49 orange 62 tv/monitor 76 scissors
51 carrot 63 laptop 77 teddy bear
55 cake 64 mouse
Full list: COCO dataset classes
How Dwell Time Collection Works
SightLab tracks gaze on registered scene objects automatically. For dwell data to accumulate on a YOLO-detected object:
  1. The object must persist with the same key across multiple frames (e.g. yolo_chair_3 stays yolo_chair_3)
  2. The object must survive long enough for the user's gaze to exceed SightLab's dwell threshold (default 500ms)
  3. The collision box must be thick enough for the gaze ray to intersect it
If objects are being removed and recreated too quickly (new keys each time), dwell time resets to zero. This is controlled by:
  • OBJECT_PERSISTENCE_TIME — how long an object survives after YOLO stops detecting it (default: 5s)
  • MATCHING_DISTANCE_THRESHOLD — how aggressively detections are matched to existing tracked objects (default: 0.5)
  • COLLISION_BOX_SIZE depth — thicker boxes are easier to hit with gaze rays (default: 0.15m)
Output Data
SightLab saves standard experiment data to the data/ folder, including per-object:
  • Dwell time — total time gaze rested on each detected object
  • View count — number of times gaze entered each object
  • Average dwell time — mean gaze duration per view
  • First view time — when the user first looked at each object
  • Gaze timeline — temporal sequence of gaze events
Each YOLO-detected object appears in the data with its key (e.g. yolo_chair_3, yolo_laptop_7).
Troubleshooting
Issue Solution
No detections appearing Check that CAPTURE_WINDOW_TITLE in the config matches the Vizard window title. Try setting it to None to use the window picker
Detections flicker / constantly reset Increase OBJECT_PERSISTENCE_TIME and MATCHING_DISTANCE_THRESHOLD
Dwell time only recorded on one object Same as above — objects are being recycled before dwell accumulates
DeleteDC failed error The script already calls screen_capture.stop_capture() to prevent this. If it still occurs, ensure only one capture source is active
ultralytics not installed warning Install with: pip install ultralytics using Vizard's Python
Vizard autocomplete spamming errors The script uses __import__() for third-party packages to avoid this. If it persists, ensure no standard import ultralytics lines exist
Boxes appear but no gaze data Verify ENABLE_GAZE_TRACKING = True and that the collision box depth is sufficient (≥ 0.1m)
Low frame rate Increase DETECTION_INTERVAL, use yolov8n.pt (nano model), or reduce MAX_TRACKED_OBJECTS
