Basic setup vizard
Basic Scene Setup with Code
Start with creating a new folder
Create new Vizard script
Save into folder
Run with viz.go()
import vizfx
#Set environment
env = vizfx.addChild('piazza.osgb')
Set up with SightLab
sightlab = sl.SightLab(gui = False, pid = False, fadequad = False)
sightlab.setStartText(' ')
viztask.schedule(sightlab.runExperiment)
Add this to run with the sightlab data collection and playback
sightlab = sl.SightLab(gui = False, pid = True, fadequad = True)
sightlab.setStartText('Press Spacebar to Start')
#Set environment
sightlab.setEnvironment(env)
#Schedule SightLab loop (note that yield is needed before start and end trial and events that trigger them)
def sightLabExperiment():
yield viztask.waitEvent(EXPERIMENT_START)
for trial in range(sightlab.getTrialCount()):
yield sightlab.startTrial()
yield sightlab.endTrial()
viztask.schedule(sightLabExperiment)
Create a script and call it myScene_Replay.py and add this code to view a replay
from sightlab_utils import replay as Replay
from sightlab_utils.replay_settings import *
replay = Replay.SightLabReplay()
