Carla Data Recorder Instructions
Setup
- “Run the latest SightLab installer, selecting both K-Lite Codec Pack and Extra Libraries when prompted.
Alternatively, you can manually install K-Lite Codec Pack if missing.” - SRanipal - Search in Steam for "Vive Console for SteamVR" or use this link.
- Unzip and place
Carla Data Recorderon each machine. Download it here. - To view the data files recommended to install "WPS Office", which is a free spreadsheet reader.
How to Run
Setup Hardware: Make sure hardware/headset are connected, boundary is set and controllers are on (if using controllers) |
Run 1_EYE_TRACKER_TEST_RUN_FIRST.py on the Simulation Rig. Agree to the SRAnipal pop-up. You will then see a white room and can verify the green gaze point is moving with your eyes. |
Launch Carla |
Launch Carla_Data_Recorder.py |
Select recording length (seconds). You can end early by closing the window or pressing Space. |
When the gray recording window appears, click it once to bring it into focus, then press Spacebar to start recording. |
Put on the headset and run Carla. A mirrored window will show a live gaze point |
Finish & save: When the timer ends you’ll hear a beep. Data goes to the /data folder. Close the recorder window. |
View a replay with visualizations by launching the Carla_Data_Recorder_Replay.py file and choose your session. |
Use the scrubber in the replay to scrub through the playback. This will show a gaze point overlay by default. |
Press the Data button to open the data files (click on date and time folder and view trial_data to see raw data) |
Note: if using Biopac, press the 1 and the 2 keys to sync with the Acqknowledge server. |
Replay Controls (Highlights)
Toggle overlays: scan path, fixations, dwell spheres, heatmap
Follow camera: keep this on
Scrub: hotkeys B/N or C/V to step; drag slider to set time (video frame jumps follow hotkeys)
Record gaze video: 4 start / 5 stop → saves to
/replay_recordings -
Restart Playback: Press r to restart the playback
Hide Menu: Press the period "." key to hide the side menu
What Gets Recorded
See here for full list.
Eye/Gaze
- Combined & per‑eye gaze origin/rotation; gaze point overlay
- Fixations & counts
- Saccades (state, amplitude, velocity, peak/avg stats)
- (Experimental) AI‑derived View Counts & Dwell
Physiology (when available)
- Biopac AcqKnowledge Physiological Data (when connected to Biopac) (i.e. heart rate, EDA, ECG, EEG, FNIRs, Respiration)
- Facial expressions (with face tracker)
- Biopac AcqKnowledge markers & sync; AcqKnowledge playback can be driven by the SightLab Replay slider (6.02+)
Events & Timing
- Custom flags, interaction triggers, timestamps (trial‑relative & UNIX).
Configuration Settings
# ----- Biopac & Network Sync -----
BIOPAC_ON = True # Communicate with Biopac Acqknowledge
LOCK_TRANSPORT = True # Lock the transport
NETWORK_SYNC_KEY = 't' # Key to send event marker to Acqknowledge
NETWORK_SYNC_EVENT = 'triggerPress' # Event trigger for marker
USE_NETWORK_EVENT = False # Send network event to external app
NETWORK_START = False # if True, use a network event to start (instead of START_END_SESSION_KEY)
# Network host/port and JSON event names (must match Unity/Unreal sender)
NETWORK_HOST = 'localhost'
NETWORK_PORT = 4950
NETWORK_START_EVENT_NAME = 'start_trial'
# ----- Data Recording -----
RECORD_VIDEO = True # Enable video recording
RECORD_VIDEO_OF_PLAYBACK = True # Record during replay
RECORD_GAZE_MAT = True # Save gaze matrix data
RECORD_FACE_TRACKER_DATA = False # Save facial expression data
OLDER_SIGHTLAB_PID = False # Use older participant ID format
# ----- Video Recording Method -----
# "OPENCV" = Compressed videos (~50MB/min), may crash after ~10min
# "VIZARD_BUILT_IN" = Uncompressed (~400MB/min), stable for hours, records Vizard window only
# "SIGHTLAB_BUILT_IN" = Vizard built in with compression - Can take some time to compress
# "IMAGEIO_FFMPEG" = External window capture via imageio-ffmpeg, may crash after ~10min
SCREEN_RECORDER_TYPE = "IMAGEIO_FFMPEG"
# ----- Video Quality Settings -----
VIDEO_RECORDING_WINDOW_HEIGHT_NEW = '1920'
VIDEO_RECORDING_WINDOW_WIDTH_NEW = '1080'
# ----- Timer & Session Control -----
USE_TIMER = True # Use timer instead of keypress to end trial
USE_TIMER_DROPDOWN = True # Show dropdown to select timer length
DEFAULT_TIMER_LENGTH = 10 # Default timer length (seconds)
START_END_SESSION_KEY = ' ' # Spacebar to start/stop trial
PLAY_END_SOUND = True # Play sound at end of trial
TRIAL_CONDITION = 'A' # Default trial condition label
SET_NUMBER_OF_TRIALS = 1
# REAL-TIME STREAMING SETTINGS (During Recording)
REAL_TIME_STREAMING = True # Show live window capture in VR during recording
# ----- Texture Alignment (if video appears offset) -----
# Use keyboard controls to adjust, then copy values here:
# Arrow Keys: Move texture | Numpad 4/6/8/2: Scale texture
# P: Print values | R: Reset to defaults
TEXTURE_OFFSET_X = 0.0 # Horizontal offset
TEXTURE_OFFSET_Y = 0.0 # Vertical offset
TEXTURE_SCALE_X = 1.0 # Horizontal scale
TEXTURE_SCALE_Y = 1.0 # Vertical scale
TEXTURE_ADJUSTMENT_STEP = 0.05 # Adjustment increment per keypress
# REPLAY SETTINGS (During Playback)
HIDE_REPLAY_GUI = False # Hide SightLab's replay GUI
FOLLOW_ON = True # Enable first-person view in replay
REPLAY_SECOND_GAZE_POINT_OFF = True # Default True
override_screen_position = True # Flag to control whether we override replay position
override_real_time_position = False # Default False
# ----- Screen Position & Size -----
# Adjust these if the replay video appears misaligned or wrong size
# Use keyboard controls during replay to find perfect values:
# Arrow Keys: Move | PgUp/PgDn: Depth | +/-: Width | [/]: Height
# K: Print values | L: Reset | O: Toggle override
# ----- Viewpoint Adjustment -----
# Fine-tune camera position/rotation for optimal replay viewing
# PROFILE MAPPING AND PRESET CONFIGURATIONS
See the Config file for the full profile mapping list you can adjust
