Connecting with the Cobi Modern fNIR Imaging Software
Cobi Modern Software for use with Biopac fNIR Systems
Cognitive Optical Brain Imaging (COBI) Studio is a hardware integrated software platform designed for functional Near Infrared (fNIR) Spectroscopy imaging systems.
https://www.biopac.com/upgrade/cobi-fnir-imager-software/
See list of FNIRs systems here:
https://www.biopac.com/product-category/research/fnir-optical-brain-imaging/fnir-systems/
Note: connecting SightLab to Cobi Modern Software requires the cobibiopac module
This example will save the oxy and deoxy values to the experiment_summary.csv file as well as send event markers to Cobi Modern that can be used to synchronize SightLab data with the FNIR signal in Cobi Modern.
See also this tutorial on setting up Cobi Modern to connect with SightLab and Vizard.
https://www.worldviz.com/post/tech-tip-connecting-fnir-to-vizard
Simple Script example to print and save oxy and deoxy values
import cobibiopac
import csv, atexit, Chart
import socket
TCP_IP = "localhost"
TCP_PORT = 6343
sightlab = sl.SightLab()
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Create FNIR device object
dev1 = cobibiopac.fNIR()
# Connect to device (defaults to localhost)
# Run this only once COBI is ready to broadcast:
dev1.connect(port=TCP_PORT, timeout=2.0)  # make sure the port matches COBI
fnir_data = dev1.getHemoglobinData()
if fnir_data:
    oxy1 = 0
    i = 0
    channel = 0  # select which channel to graph and then obtain data from that channel:
    oxy1 = fnir_data[channel][1]
    deoxy1 = fnir_data[channel][0]
for data_column in ["oxy", "deoxy"]:
    sightlab.addCustomTrialDataColumn(data_column)
def sightLabExperiment():
    while True:
        yield viztask.waitKeyDown(" ")
        def get_additional_data():
            if fnir_data:
                oxy1 = 0
                i = 0
                print(deoxy1)
                print(oxy1)
                print("No data yet")
            sightlab.setCustomTrialData(str(oxy1), "oxy1")
            sightlab.setCustomTrialData(str(deoxy1), "deoxy1")
        update_action = vizact.onupdate(0, get_additional_data)
        yield sightlab.startTrial()
        yield sightlab.endTrial()
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
viz.callback(viz.getEventID("ResetPosition"), sightlab.resetViewPoint)
Adding sending of events on gaze time and gaze end
import cobibiopac
import socket
TCP_PORT = 6343
s.bind((TCP_IP, TCP_PORT))
s.listen(1)
conn, addr = s.accept()
conn.sendall(b"1")
if fnir_data:
    oxy1 = 0
    i = 0
for data_column in ["oxy", "deoxy", "cobi_flag"]:
    while True:
            if fnir_data:
                oxy1 = 0
                i = 0
                print(deoxy1)
                print(oxy1)
        gazeFixatedmessage = "gaze fixated: " + e.name
        gazeStoppedmessage = "gaze ended: " + e.name
        gazeStartedmessage = "gaze started: " + e.name
        def onGazeFixated(e):
                conn.sendall(b"/" + gazeFixatedmessage.encode()), "cobi_flag"
        def onGazeStopped(e):
                conn.sendall(b"/" + gazeStoppedmessage.encode()), "cobi_flag"
        def onGazeStarted(e):
                conn.sendall(b"/" + gazeStartedmessage.encode()), "cobi_flag"
        vizact.addCallback(sightlab.GAZE_TIME_EVENT, onGazeFixated)
        vizact.addCallback(sightlab.GAZE_END_EVENT, onGazeStopped)
        vizact.addCallback(sightlab.GAZE_BEGIN_EVENT, onGazeStarted)
Inquire with sales@worldviz.com to see how Sightlab VR can be combined with FNIR data
Was this page helpful?
