Example Scripts/Templates
See the folder “ExampleScripts” for examples you can copy and paste into your project. See the instructions for each one. The ExampleScripts are located in your Sightlab2 projects folder (by default in your Documents folder)
Visual Search
Examples of 4 different Visual Search tasks using STIM files and saving data
Virtual 2D Screen
Use 2D videos displayed on a virtual screen. Analyze and playback user interactions. Also supports stereo video playback.
Gaze Based Interactions
Elements in the scene react to your gaze.
Driving Example
Use a car or other vehicle in your eyetracking simulation
Walk the Plank
Challenge Fear of Heights in the Walk the Plank demo. Capture fixations and heatmaps and send signals to Biopac Acqknowledge
Mirror
Demonstrates adding a virtual mirror to a scene and swapping head and hands, or can use tracked avatar
Physics
Turn physics on in your application
Adding avatars/NPCs
See how to add avatars in your application
Proximity Sensors
Add proximity sensors for location based interactions
Visual Analytics Examples.
Generate bar charts, histograms, box plots using Matplotlib, Numpy, PANDAs, Plotly and Seaborn
Adding to an existing Vizard script
See how to import into an existing Vizard script
Shared Gaze
Multi-user sample showing time spent in shared gaze
Media Viewer
Template for displaying 360 Media Stimulus in a randomized order
Memory Experiment
Investigate human spatial memory with this example of a behavioral research experiment.
Setting flags using controller trigger or keypress
See how to set flags using a controller or keyboard press.
Omnicept Heart Rate/Additional Data
Track and playback heart rate using the Omnicept headset
3D Tablet/ VR Menu
Use and modify a 3D menu for interacting with the scene
Using with Biopac Acqknowledge
See how to connect and send markers to Biopac's Acqknowledge software
Pupil Diameter baseline
Establish a baseline for pupil diameter using various light intensity values.
Instructions
Add instructions for a participant (accessible via the "settings.py" file)
Rating Scale GUI
Adding a GUI to allow users to choose from a set of responses
Pigeon Hunt
Follow the sound of hooting pigeons and catch them before they fly away.
Audio Recording and Transcriptions
Add audio to the replay captured from your microphone. Can also save an audio transcript
STIM Files
See how to use a STIM file to setup independent variables
Eye Tracker Tests
Run tests to evaluate Eye Tracker hardware performance
Model/Stimulus Swapping
Cycle through models, videos, images, and audio collections with single or multi-user setups
360 Moving Regions of Interest
Mixed Reality
Examples of using Mixed and Augmented Reality
XR/AR Eye Tracking
Perform eye tracking studies on real world objects
Upper Body Tracking
Examples for using upper body tracking with the Meta Quest Pro
Using a Timer for Experiment
Example for running experiments on a timer or using different start/stop events
AI Agent
Interact with a virtual agent enabled with ChatGPT or Claude
Educational Application with AI
Set up an educational experience with audio and visual annotations on objects
Selector/Highlighter Tool
Use a selector tool to interact with the scene
Hand Tracking - Grabbing and Physics
Use Meta Quest Pro’s Hand Tracking for object interaction using physics
Images for Instructions
Using an image to instruct participants
Biofeedback Ball
See how feedback from physiological sensors can change the appearance of a ball in VR/AR
Collisions/Gravity
Move over elevations, ramps, and enable falling in your simulations
Jump To Locations
Jump to various scene locations with arc teleport, virtual menu, or keypresses
Face Tracking
View, save, and analyze face tracking data
Movement Limiter
Restrict user movement in a large space within a defined boundary
Convert 360 Media to Equirectangular
Convert 3D cartesian data points to an equirectangular format
Full Body Multi-User
Use full-body avatars with saved audio, transcripts, video, and replay
Avatar Body
Use a seated, standing, or tracked full-body avatar
Video Compressor
Compress video for smoother playback with 360 VR video
Measuring Tape
Tool for measuring objects in AR or VR
Feet Tracking
Track feet in VR using controllers or Vive Trackers
Vive Trackers
Track objects or full body with Vive Trackers
Real World Objects in VR
Display real-world objects overlaid in VR
Grab Events
Save data on object grab and release events
Distance Perception
Experiment to measure Distance Perception and user performance
Choice Comparison
Template for comparing choices between objects using input methods
Presentation Mode MultiUser
Present a Session with Presenter Tools, such as controlling trials for clients, etc.
Hand Tracking Gesture Control
Control scene aspects using gestures
Glaucoma Simulation
Add a moving object that simulates Glaucoma-type artifacts
Rotoscoped Avatars
Enable seamless integration of live-action actors
Scripted Avatar Agent
Add avatars that can read and interact using text from a file
Screen Based Eyetrackers
Connect to screen based eye trackers from Tobii and Eyelogic
Reaction Time
Measure Reaction Time in 4 various tasks, including threat/neutral targets
Additional Examples Available (Contact Sales@Worldviz.com to inquire about how to get access)
Driving 360
360 video integrated with 3D models in a New York City drive-through demo
Shopping Visual Search
A visual search task to find a grocery item
Virtual Cockpit
Flying demo inside a virtual cockpit
Phobia Stimulus Presentation
Measure response to objects like spiders while assessing control object awareness
Apartment/Building Review
Examples of various apartments and buildings
External Application Data Recorder
Record data from external applications outside of Vizard
Digital Twin/ Data Visualization
Example demonstrating pulling real time data from an online source and mapping it to a 3D town
Head Anatomy
Reveal layers of a head anatomy model
Phobia - Elevator
Phobia exposure with BIOPAC for elevator
Phobia - Airplane
Phobia exposure with BIOPAC for airplane
Virtual Theater
A virtual theater to display standard or stereoscopic videos on a virtual screen
