SightLab VR Pro FAQ
1. What headsets and hardware is this compatible with?
SightLab VR Pro works with the following headsets:
For eye tracking:
- Varjo Aero, XR-3, XR-4, VR-3
- Meta Quest Pro
- Vive Focus 3 (with optional eye tracker add-on)
- Vive Focus Vision
- Vive Pro Eye
- HP Omnicept
- Pupil Labs (includes Vive Cosmos, Vive Pro, original Vive)
- StarVR One
- Tobii Pro
- Pimax (through OpenXR)
- SMI
For non-eye tracked headsets you can use head position with these headsets:
- Meta headsets (including the Quest, Quest 2, Quest 3/3S and Quest Pro with Oculus Link)
- All SteamVR compatible headsets (Pimax, Valve Index and much more)
- Windows Mixed Reality headsets
- Pico works with just head position and connected via SteamVR link
- Vive XR Elite - Desktop mode
For additional hardware supported, see the Vizard Supported Devices page.
2. SightLab GUI is just showing a black screen instead of my model, or I'm getting an error when running the SightLab GUI
The first thing to try that can get past a lot of errors is to go into the "sightlab_configs" folder and delete the "recent_config" file. If this doesn't work you can run the main SightLab file in the Vizard python editor and refer to the error message.
3. Can I use SightLab VR standalone?
SightLab VR Pro requires WorldViz Vizard software for its full functionality as SightLab VR Pro is an add-on software to our Vizard software engine. You can although still use a software like Shadow PC to stream via the cloud to a device running in stand alone mode.
