Hello world3
SightLab experiments can be set up with a GUI, with code, or a combination of both. This QuickStart is showing how to test starting a quick session with the GUI. This is just for testing functionality, see creating a new scene and the rest of the documentation for more options.
| Quick Start - GUI | |
| Folder | Create Folder: FromDocuments\SightLab2\Projects make a copy of BlankProject.
| GUI | Launch GUI: Open SightLab_VR.py in your BlankProject copy folder to launch the SightLab GUI.
| Folder | Start Session: Choose hardware and start the GUI experiment setup. For custom start/stop methods, advanced trial options and editing assets, refer to the documentation
| GUI | Start/End Trials: Press "Continue" to save changes and start your session. "Submit" to click past participant info. Default controls use Spacebar to start/stop.
| GUI | Run Session: See controls here. The "p" key toggles viewing the gaze point (off by default). Press Escape or click the top right 'x' to close this window.
| GUI | Replay & Review Data: Use SightLabVR_Replay.py for session replay (use Spacebar to start/stop); view data files in the data folder.
Non-GUI Workflow: For non-GUI see example with code
Customize Scene/Experiment: Creating a new scene
Multi-User Setup: Check the multi-user guide for collaborative experiments
Getting Assets: Need models or media? Check out the Getting 3D Models and Assets page
Examples and More: For more, refer to the SightLab documentation and examples in the ExampleScripts folder.
