Media Viewer
Download Advanced Version with Streamlined GUI
To run a series of videos or images in a row  you can set this up in the GUI (and additionally, run repetitions for blocks of trials)  or see the MediaViewer in the folder ExampleScripts- Model and Media Viewer
For the MediaViewer, you can just drop any media (360 videos, images, stereo or mono) into the mediaPath folder. For stereo videos and images add the tag "_stereo" to the end of the file.
This folder location can also be changed where you want to store your media collection under mediaConfig.
Options to change in mediaConfig are:
mediaFolderPath = 'mediaPath'
BIOPAC_ON = False
videoRecording = 0
Timer = False #Choose to have videos advance on a timer or use a keypress, set to True for the timer
TimerValue = 5 #set how many seconds the timer runs before the media changes
swapMediaKey = 'v' #set which key will advance the media if not using a timer
cycleMedia = True
startExperimentKey = ' '
endExperimentKey = ' '
If you enable Biopac in settings an event will be sent to Acqknowledge when the media is changed (this will also include the media name), a flag will also be sent to the sightlab tracking data file.
You can also use a STIM file to control the playback of multiple 360 videos
