Model Converter Guide
Standalone tool for converting OpenSceneGraph (.osgb, .osg, .ive) models to GLB format.
Requirements
| Tool | Purpose | Required? |
| Python 3.8+ | Runs the converter script | Yes |
| osgconv | Converts OSGB/IVE → OBJ and extracts textures | Yes |
| Blender 3.6+ | Converts OBJ → GLB with texture embedding | Yes |
Where osgconv is found (checked in order)
- Download from here (Note: if you download from the link above the bin folder with osgconv will already be in your project folder)
- Place next to the model_converter script
/bin/osgconv.exe(next to the script)
Where Blender is found (checked in order)
C:\Program Files\Blender Foundation\Blender *\blender.exe(newest version)- System PATH
Conversion Pipeline
┌──────────┐ osgconv ┌──────────┐ Blender ┌──────────┐
│ .osgb │ ──────────────► │ .obj │ ──────────────► │ .glb │
│ .osg │ + texture │ .mtl │ import OBJ │ │
│ .ive │ extraction │ images/ │ export GLB │ │
Step-by-step:
- Direct attempt —
osgconv input.osgb output.glb(works if OSG has a glTF plugin) - OBJ intermediate —
osgconv input.osgb temp.obj, then Blender convertstemp.obj → output.glb - Blender fallback — For formats Blender supports natively (
.fbx,.obj,.dae)
Intermediate files (.obj, .mtl) are cleaned up automatically on success.
Textures
If textures don't automatically copy over you may need to manually extract them: For osgb models need to first manually save the textures
right click on the texture - go to Properties - left click on the gear icon - save as .dds in the textures folder
Once they are in the textures folder run the converter script and the .glb model will be saved into output_folder\output_folder\webxr\models folder
Usage — Python Import (convert_models.py)
No terminal needed. Call directly from any Python script (including Vizard scripts) Note: it is highly suggested to have one model per folder, as multiple models in the same conversion folder could cause issues:
from model_converter import convert, batch_convert, check_tools
# Check if osgconv and Blender are available
tools = check_tools()
print(tools)
# {'osgconv': 'D:\\...\\bin\\osgconv.exe', 'blender': 'C:\\...\\blender.exe'}
# Convert a single file (output defaults to same name with .glb extension)
convert("myScene.osgb")
# Convert with explicit output path
convert("myScene.osgb", "output/myScene.glb")
# Convert with a textures folder
convert("myScene.osgb", "output/myScene.glb", textures_dir="textures/")
# Batch convert a whole directory
results = batch_convert("models/", "converted/")
print(f"Succeeded: {len(results['succeeded'])}, Failed: {len(results['failed'])}")
Usage — Command Line (PowerShell / Terminal)
Convert a single model
python model_converter.py scene.osgb
Output: scene.glb in the same directory.
Specify output path
python model_converter.py scene.osgb -o output/scene.glb
python model_converter.py scene.osgb -t textures/
Batch convert all models in a directory
python model_converter.py models/
Converts all .osgb, .osg, and .ive files found in the directory.
Batch convert with output directory
python model_converter.py models/ -o converted/
Check available tools
python model_converter.py --check-tools
Output:
Available conversion tools:
osgconv: D:\...\bin\osgconv.exe
blender: C:\Program Files\Blender Foundation\Blender 4.2\blender.exe
Verbose logging
python model_converter.py scene.osgb -v
All CLI flags
| Flag | Description |
input |
Input model file or directory (positional) |
-o, --output |
Output .glb file path or directory |
-t, --textures-dir |
Path to folder containing textures to embed |
-v, --verbose |
Enable verbose/debug logging |
--check-tools |
Check which tools are available and exit |
API Reference
| Function | Description |
convert(input_path, output_path=None, textures_dir=None) |
Convert a single model to GLB. Returns True/False. |
batch_convert(input_dir, output_dir=None, extensions=None, textures_dir=None) |
Convert all models in a directory. Returns {'succeeded': [...], 'failed': [...]}. |
check_tools() |
Returns {'osgconv': path_or_None, 'blender': path_or_None}. |
Texture Handling
Textures are resolved in this priority order:
--textures-dir/textures_dirparameter — Explicitly provided folder of texturestextures/folder next to the input model — Auto-detectedimages/folder next to the input model — Auto-detected- Automatic extraction —
osgconv -O OutputTextureFilesextracts embedded textures from.osgb/.ivefiles
If automatic extraction fails
Some compressed textures (e.g., DDS with GPU-specific compression) can't be extracted without an OpenGL context. In that case, manually export textures from Vizard Inspector:
- Open Vizard IDE → Utilities → Inspector
- File → Open your
.osgbfile - In the Textures panel, click on a texture
- Right-click → Properties → gear icon → Export
- Save all textures to a
textures/folder next to your model - Run the converter — it will auto-detect and embed them
Expected folder structure
my_project/
├── my_model.osgb
├── textures/
│ └── ceiling.dds
Then simply run:
python model_converter.py my_model.osgb
The textures will be found automatically and embedded into the output .glb.
Supported Formats
Input formats
| Format | Extension | Conversion Path |
| OpenSceneGraph Binary | .osgb |
osgconv → OBJ → Blender → GLB |
| OpenSceneGraph ASCII | .osg |
| OpenSceneGraph IVE | .ive |
| FBX | .fbx |
Blender direct |
| Wavefront OBJ | .obj |
Blender direct |
| COLLADA | .dae |
Blender direct |
| glTF | .gltf, .glb |
Blender direct |
Output format
- GLB (Binary glTF) — single-file format with embedded textures, widely supported
Troubleshooting
| Problem | Solution |
osgconv.exe not found |
Place osgconv.exe + its DLLs in ./bin/ next to the script, or install OpenSceneGraph |
Blender not found |
Install Blender and ensure it's in the default location or on your PATH |
| Missing textures in output | Provide a textures/ folder via -t flag or place it next to the model |
Blender conversion timed out |
Very large models may exceed the 5-minute timeout — try converting smaller pieces |
| DDS textures not extracted | Use Vizard Inspector to manually export textures (see Texture Handling above) |
osgconv stderr: write error |
Compressed textures can't be auto-extracted — use manual texture export |
