Pupil Labs Neon Integration for SightLab
This guide covers connecting and configuring the Pupil Labs Neon eye tracker with SightLab/Vizard.
Quick Start
Add Quest 3 eye tracking to your SightLab Experiments with Neon
  1. See instructions here https://docs.pupil-labs.com/neon/neon-xr/
  2. pip install pupil-labs-realtime-api (in Vizard - Tools- Package Manager - CMD)
  3. May need to also run this after pupil-labs-realtime-api: install --upgrade protobuf==3.20.3
  4. Make sure the Neon Device mount is attached to your Quest 3 according to instructions
  5. Download the Companion App for Neon
  6. Plug the USB-C cable from the Neon mount to your smartphone
  7. Start the Companion App on your phone
  8. Ensure both devices are on the same network
  9. Find your device IP in the Companion app (Settings → Device Info)
  10. Run your SightLab experiment using the Pupil Labs Neon Quest 3 config
Connection Settings
Edit these in vizconnect_quest_3_pupil_labs.pypostInit():
pupil = PupilLabsEyeTracker(
    device_address="10.24.0.22",    # Your phone device's IP address
    device_port="8080",              # Default port (usually unchanged)
    verbose=True                     # Print connection status
Parameter Description
device_address IP address from Companion app. Set to None for auto-discovery
device_port Usually "8080" (default)
verbose Print discovery/connection messages
Calibration & Accuracy
Adjust if the gaze point is consistently offset from where you're looking:
pupil.pitch_offset = 0.0   # Vertical adjustment (degrees)
pupil.yaw_offset = 0.0     # Horizontal adjustment (degrees)
Problem Solution
Gaze too high Increase pitch_offset (e.g., 2.0)
Gaze too low Decrease pitch_offset (e.g., -2.0)
Gaze too left Increase yaw_offset (e.g., 2.0)
Gaze too right Decrease yaw_offset (e.g., -2.0)
Smoothing
Controls the trade-off between responsiveness and jitter:
pupil.smooth_alpha_dir = 0.4   # Direction smoothing
pupil.smooth_alpha_pos = 0.4   # Position smoothing
Value Effect
0.1 - 0.2 Very smooth, noticeable lag (best for heatmaps)
0.3 - 0.4 Balanced (recommended)
0.5 - 0.7 Responsive, some jitter
1.0 No smoothing (raw data)
Mount Calibration
The Neon scene camera is tilted 12° downward. This is compensated automatically:
mount_rotation=(-12.0, 0.0, 0.0)   # (pitch, yaw, roll) in degrees
Only adjust if using a non-standard mount.
Debugging
Enable debug output to verify data is flowing:
pupil.debug = True   # Print gaze data every second
Console output will show:
[PupilLabs Tick #60]
  Matrix Euler: yaw=5.23°, pitch=-3.12°, roll=0.00°
  Raw Left Axis: (0.091, -0.054, 0.994)
  Raw Right Axis: (0.088, -0.051, 0.995)
Set to False for production use.
Troubleshooting
Issue Solution
"No device found" Check IP address, ensure Companion app is running
Gaze not moving Verify pupil.debug = True shows changing values
Very laggy Increase smooth_alpha_dir to 0.5+
Too jittery Decrease smooth_alpha_dir to 0.2
Connection drops Check WiFi stability, try phone hotspot
Files in Sightlab_Utils
File Purpose
pupil_labs_sightlab_converter.py Main converter class
vizconnect_quest_3_pupil_labs.py VizConnect configuration
