Sharing Multi User Resources
Enable Network Discovery & File Sharing
Control Panel → Network and Internet → Network and Sharing Center → Change advanced sharing settings
Under your active profile (Private or Domain), turn on:
Network discovery
File and printer sharing
Save changes.
Can also turn off the need for a password
Make sure firewall is turned off on all machines
Optionally, could just allow sharing through the firewall
- Settings → Update & Security → Windows Security → Firewall & network protection → Allow an app through firewall
Create and share a network folder (SightLab Multi User folder)
On one PC (the “server”), navigate to your SightLab project folder in File Explorer.
Right-click the Sightlab2 folder → Properties → Sharing → Advanced Sharing…**
Check Share this folder, give it a share name (e.g. SightLab), then click Permissions and grant your network users (or “Everyone”) Read/Change as needed.
Apply and close.
Map the network share on each machine
On each client and on the server itself, open File Explorer → This PC → Map network drive.
Choose a drive letter (e.g. Z:) and set the folder to your shared foldet (i.e. \\ServerName\Sightlab2)
Copy and paste or type the name directly (Browse does not seem to work for this)
Check Reconnect at sign-in and finish.
When ready the server will show up like this
Lastly, go to the shared folder from the server, right click Properties → Security tab → Edit… Add, then type “Everyone” in here and click Apply and OK to apply.
Run both server and clients from the shared folder
Store your experiment script(s), Resources, and project files all together in the shared folder
SightLab
Launch SightLab_VR_Server.py (on the server) and SightLab_VR_Client.py (on each client) from that mapped drive.
Because everyone is using the exact same directory tree, any new objects add , changes you make, or new projects created will be visible to all users immediately.
With this setup, the folder acts like a live repository: add or overwrite any assets there, and both the GUI editor and code-driven runs on every machine will see those updates in real time.
Troubleshooting
If you get something like "An Extended Error Has Occured":
Open PowerShell as an administrator and run the following command to disable SMB signing and restart your computer to see if you can fix the problem:
Set-SmbClientConfiguration -RequireSecuritySignature $false
