Truck Pre-Trip Inspection VR Walkthrough
Overview
This proof of concept implements an FMCSA/CVSA-aligned pre-trip inspection checklist for a 2-axle cargo truck. It supports both single-user and multi-user modes with synchronized inspection checklists, horn/headlight interactions, and teleportation.
- Interactive 3D checklist panel with proximity-based navigation
- Touch-based inspection — touch spheres to check/uncheck items, confirm with YES/NO
- Horn and headlight verification — physical interaction required before marking those items complete
- Teleport navigation — jump between predefined inspection locations around the truck
- Shared checklist (multi-user) — all clients update a single server-managed checklist
- Progress tracking — saves to CSV and generates text reports per session
- SightLab integration — eye-tracking, gaze analytics, and session replay
File Structure
Truck_Walkthrough/
├── Truck_Inspection.py # Single-user inspection script
├── Truck_Inspection_Server.py # Multi-user server script
├── Truck_Inspection_Client.py # Multi-user client script (locations set 1)
├── Truck_Inspection_Client2.py # Multi-user client script (locations set 2)
├── Truck_Inspection_Replay.py # Session replay viewer
├── inspection_checklist_manager.py # Checklist data management
├── proximity_inspection_system.py # 3D touch-based inspection UI
├── data/
│ ├── pretrip_inspection_checklist.csv # Checklist template (do NOT edit during sessions)
│ └── <timestamp>__experiment_data/ # Session output folders (created per run)
│ ├── pretrip_inspection_checklist.csv # Working checklist copy
│ ├── <timestamp>__pretrip_inspection_checklist.csv # Final checklist snapshot
│ ├── <timestamp>__inspection_report_trial_N.txt # Text report
│ ├── <timestamp>__experiment_summary_client_N.csv # SightLab summary
│ ├── trial_data/ # Gaze/tracking CSVs
│ └── replay_data/ # Session replay files
├── locations/
│ └── locations.txt # Teleport positions (Client 1 / single-user)
├── locations2/
│ └── locations.txt # Teleport positions (Client 2)
├── sightlab_configs/ # SightLab configuration files
└── Resources/
└── environments/
└── Truck_Showroom.osgb # Truck environment model
Running the Application
Single-User Mode
- Run Truck_Inspection.py
- Press SPACE to start the inspection trial
- Complete the checklist using touch interactions
- Press SPACE to end the trial and save progress
Multi-User Mode
Multi-user mode uses a server–client architecture. The server is the source of truth for the checklist — all item checks, clears, and resets from any client are sent to the server, which updates the master checklist and broadcasts changes to all connected clients.
- Open Truck_Inspection_Server.py and run it
- Open Truck_Inspection_Client.py on the first client machine and run it
- Open Truck_Inspection_Client2.py on the second client machine and run it
- Client2 uses a separate set of teleport locations (
locations2/) so that users don't overlap with each other at the same positions - Each client connects to the server via the SightLab GUI
- Start the experiment from the server GUI — all clients begin simultaneously
- Any client (or the server operator) can check items, sound the horn, or toggle headlights — all actions sync across all participants
Teleportation in multi-user mode:
- Number keys (1–9) — teleport only the individual user who pressed the key to that location
- Panel teleport buttons (touching a location sphere on the menu) — teleport all clients and the server view to the selected location
Other key behaviors in multi-user mode:
- The checklist CSV is saved only on the server, in the session's experiment_data folder
- Horn sound and headlight toggle sync to all clients instantly
- The template file in data/pretrip_inspection_checklist.csv is never modified
Controls
Inspection Panel
| Key | Action |
M |
Reposition panel in front of you |
LEFT / RIGHT |
Navigate to previous / next item |
C / V |
Navigate to previous / next item (alternative) |
N |
Jump to next unchecked item |
B |
Clear (uncheck) current item |
G |
Clear all items (reset entire checklist) |
U |
Toggle debug visualization (show proximity sensors) |
VR Interactions
| Action | How |
| Check item | Touch the blue sphere, then touch YES (green) to confirm |
| Cancel check | Touch NO (red) to cancel |
| Sound horn | Move hand near the horn object and press trigger |
| Toggle headlights | Move hand near the headlights switch and press trigger |
| Teleport | Touch a location sphere on the panel |
Other Keys
| Key | Action |
SPACE |
Start / End trial |
H |
Toggle horn proximity debug |
L |
Toggle headlights proximity debug |
Save current position as teleport location and take screenshot |
1–9 |
Quick teleport to numbered locations |
Session Replay
Use Truck_Inspection_Replay.py to review completed sessions. You must run at least one experiment session before replay data is available.
Starting Replay
- Open Truck_Inspection_Replay.py in Vizard and run it
- Select a session from the list
- Choose Desktop Mode or a headset configuration for viewing
Replay Controls
| Key | Action |
SPACE |
Start / Stop playback |
R |
Reset playback to beginning |
C / V |
Scrub backward / forward (or use the slider) |
B / N |
Step frame-by-frame |
W / A / S / D |
Move free camera |
Z / X |
Move camera down / up |
Q / E |
Rotate camera |
. or F1 |
Hide / show menu |
Take screenshot |
I |
Show instructions |
ESC |
Exit |
Replay Features
- Trial Selection — choose any trial to replay
- Client ID (multi-user) — view visualizations for a specific client
- Avatar Visualization — toggle head and hand display
- Gaze Visualizations — gaze ray, gaze point, dwell spheres (per eye or combined)
- Fixation Spheres — view fixation points statically or sequentially numbered
- Heat Map — dynamic (over time) or static (aggregated); supports occlusion and gradient modes
- Scan Path — gaze path and dispersion path visualization
- Walk Path — directional arrows showing movement with velocity indication
- First/Third Person View — toggle camera perspective
- Open Data Folder — quick access to session files
The replay uses a free camera mode — use WASD/ZX to move around, or walk freely if viewing in a headset.
Inspection Categories
- Driver & Documentation — License, registration, logs
- Engine Compartment — Fluids, belts, hoses
- Front of Vehicle — Lights, mirrors, wipers
- Steering & Suspension — Linkage, springs, shocks
- Brakes — Air system, brake components
- Wheels & Tires — Tread, inflation, lug nuts
- Side & Cargo — Doors, cargo security
- Rear of Vehicle — Tail lights, reflectors
- Exhaust & Frame — Exhaust system, frame rails
- Emergency Equipment — Fire extinguisher, triangles
- In-Cab Safety — Seat belt, gauges, controls
- Final Walk-Around — Overall vehicle check
Data Output
All session data is saved to a timestamped folder under data/, e.g.:
data/02-09-2026-15-14-18__experiment_data/
Inspection Checklist CSV
The working checklist (pretrip_inspection_checklist.csv) tracks all 66 inspection items with columns:
| Column | Description |
category |
Inspection category (e.g., "Engine Compartment") |
item_id |
Unique identifier (e.g., DRV001, CAB001) |
item_name |
Display name |
description |
Detailed description |
inspection_type |
gaze / proximity / visual / interaction |
checked |
0 or 1 |
timestamp |
ISO timestamp when checked |
location |
Optional teleport location (e.g., location1) — see Adding Teleport Locations |
A final snapshot is also saved with the session timestamp prefix (e.g., 02-09-2026-15-14-18__pretrip_inspection_checklist.csv).
Inspection Report (Text)
A human-readable report saved as <timestamp>__inspection_report_trial_N.txt containing:
- Overall progress percentage
- Category-by-category breakdown
- Timestamp for each checked item
Eye Tracking & Movement Data (SightLab)
SightLab automatically generates several data files per session in the trial_data/ subfolder. These capture eye tracking, head movement, and gaze analytics.
Trial Data
*__trial_data_N_client_N.csv — Per-frame tracking data recorded at the headset update rate (e.g., 90 Hz for a 90 Hz headset). Includes:
- Timestamps (session-relative and Unix)
- Trial label and average frame rate
- Gaze intersect coordinates (combined and per-eye)
- Eye Euler angles (combined and per-eye)
- Head position and orientation (6DOF)
- Fixation/saccade status, saccade amplitude, velocity, average amplitude, peak velocity
- Pupil diameter and eye openness (if supported by hardware)
- Grab/release events and custom flags
Experiment Summary
*__experiment_summary_client_N.csv — Per-trial summary statistics including:
- Dwell view count, fixation count, and dwell time per object
- Average view time and time to first fixation
- Per-trial saccade calculations
- Trial length and any additional custom measurements
Trial Timeline Dwell
*__trial_timeline_dwell_N_client_N.csv — Timeline of gaze dwell events showing:
- When each object was viewed, for how long, and how many fixations occurred per object
- Custom flags added during the session
Trial Timeline Fixation & Saccade
*__trial_timeline_fixation_saccade_N_client_N.csv — Timeline of individual fixations and saccades including:
- Fixation and saccade duration
- Average fixation dispersion angle and average saccade velocity
- Delta angles and velocity between events
Customization
Teleport locations are stored in locations/locations.txt (or locations2/locations.txt for Client 2). Each location consists of a position and orientation pair:
location1=1.333,0.0,-0.523
orientation1=0.0,0.0,0.0
location2=0.715,0.903,2.819
orientation2=-166.93,0.0,0.0
To add a new location at runtime:
- Start the application and begin a trial
- Navigate to the desired position in the scene (walk there in VR or use the keyboard)
- Press
/— this saves your current position and orientation as a new numbered location, appended tolocations/locations.txt - The new location is immediately available via its number key (e.g., press
3to teleport tolocation3) - You can also assign it to checklist items in the CSV (see below)
To edit locations manually, open locations/locations.txt in a text editor. Each location needs two lines:
- locationN=x,y,z — the 3D position
- orientationN=yaw,pitch,roll — the facing direction
Where N is a sequential integer starting from 1.
Adding New Inspection Items
Inspection items are defined in the template CSV file: data/pretrip_inspection_checklist.csv. Edit this file before starting an experiment session (a working copy is created per session at trial start).
To add a new item, append a row to the CSV with these columns:
| Column | Required | Example | Notes |
category |
Yes | Engine Compartment |
Must match one of the predefined categories (see Inspection Categories) |
item_id |
Yes | ENG007 |
Unique ID — use the category prefix + sequential number |
item_name |
Yes | Turbo Charger |
Short name shown on the 3D panel |
description |
Yes | Inspect turbo for oil leaks or damage |
Detailed description shown below the name |
inspection_type |
Yes | visual |
One of: visual, functional, gauge, auditory |
checked |
Yes | 0 |
Always 0 in the template |
timestamp |
Yes | (empty) | Leave empty in the template |
location |
No | location2 |
Optional — if set, the user auto-teleports to this location when navigating to the item |
Example — adding a new item with a teleport location:
Engine Compartment,ENG007,Turbo Charger,Inspect turbo for oil leaks or damage,visual,0,,location2
When a user navigates to this item (via arrow keys, touch navigation, or "next unchecked"), they will automatically teleport to location2 as defined in locations/locations.txt.
Tips:
- Items appear in the inspection panel in the same order as the CSV rows
- The location column is optional — items without a location value work as before (no teleport)
- Location values must match entries in locations/locations.txt (e.g., location1, location2, location3)
- To reorder items, rearrange the rows in the CSV
- Do not edit the working copy inside a session's experiment_data folder — always edit the template in data/
Requirements
- WorldViz Vizard 8
- SightLab VR (sightlab_utils)
- Truck_Showroom.osgb environment model
