Virtual Screencasting into SightLab
SightLab supports capturing and displaying real-time content from other applications or browser windows directly into your VR/AR environment. This is useful for a range of research and presentation purposes.
See ExampleScripts/ScreenCasting_Examples or for Multi-User in Multi User ExamplesScripts\Virtual_Screencast
Note: Using the full desktop casting will slow down frame rate if your desktop resolution is high. Casting a specific window that is resized to smaller than your desktop is preferred for performance.
🔧 Setup Requirements
If casting browser based content, before starting, make sure you disable hardware acceleration in your browser (if using browser-based sources):
Python Libraries
Requires installing these additional python libraries (via. Tools-Package Manager in the Vizard IDE). These are now included with SightLab, so should not be necessary to install manually.
pip install opencv-python
pip install pillow
pip install pywin32
Disable Hardware Acceleration in Chrome:
- Open
chrome://settings - Scroll to System
- Toggle Use hardware acceleration when available → OFF
- Restart Chrome
🎬 What You Can Do
- Display live application windows (e.g., Psychopy, PowerPoint, browsers) inside your VR/AR scene
- Record these streams automatically for replay or analysis
- Capture specific windows or the entire desktop
- Scale, reposition, and rotate the virtual screen in VR
- Enable pass-through for mixed reality setups
- Automatically save AVI and MP4 video versions for each trial
📁 Required Modules
The main functionality is provided by the following modules:
WindowCapture– Captures a user-selected window.ScreenCapture– Captures the entire desktop.convert_avi_to_mp4()– Transcodes recorded trials to MP4.get_experiment_video_filename()– Auto-generates unique filenames.
Trial Integration in SightLab
Select Window to Capture
screen_capture = WindowCapture(ask_user=True, flip_code=1, record_screen=True)
Or use a specific title:
screen_capture = WindowCapture(window_title="My App", flip_code=1, record_screen=True)
Note: If using on another project, you will also need to copy the blank.jpg file from the example project.
Add Virtual Screen and Link Texture
screen = viz.add('video_screen_object/3D_Video_Screen.osgb')
screen.texture(screen_capture.get_texture())
Optional: Enable Pass-through (for XR devices)
passthrough.setEnabled(True)
viz.clearcolor(viz.BLACK, 0.0)
Control Scale of Virtual Screen
Easiest method is to scale the virtual screen object you are using in the Inspector 3d model editor, or if using the example script can use these keys to dynamically change the scale in the scene.
vizact.onkeydown('m', scaleVideoUp)
vizact.onkeydown('n', scaleVideoDown)
Optional: View Screen Properties
vizact.onkeydown('t', getScreenPosition)
⏺️ Recording per Trial
If record_screen is set to "True", SightLab automatically starts/stops screen recording per trial:
screen_capture.start_recording()
screen_capture.stop_recording()
MP4 is created automatically at the end of the trial using the correct naming scheme:
<timestamp>_<participantID>_experiment_data_trial_<trialNumber>.mp4
This is useful for the replay to be able to view heatmaps, fixations on top of the content that was viewed.
💼 Use Cases
- Run web-based experiments, Psychopy experiments or surveys within VR
- Project video calls or webcams into immersive space
- Conduct slide presentations or lecture playback
- Show live data dashboards or coding IDEs
- Cast a phone screen to a virtual phone
🔁 Replay Support
Captured videos are compatible with SightLab’s replay tools and visualizations. Recordings can be reviewed with:
- Heatmaps
- Scan paths
- Gaze point overlays
- Fixation spheres
📂 File Output
Recordings are saved into a recordings folder, and are accessible automatically via the replay system or file browser.
Tips
- Always scale or reposition the screen for optimal placement in your scene or attach to a 3D model of a monitor for instance
- For multi-user setups, use a screenshare meeting application such as Zoom or GoogleMeet
- Cast from a specific window and resize this window to a smaller size to improve performance
- Playing YouTube content may require to keep the YouTube window not in the background (might need to play side by side with your mirrored VR window)
📱 Casting from Mobile Devices
SightLab supports casting a phone screen into VR, which is ideal for experiments simulating smartphone use, live mobile camera feeds, or interacting with mobile content inside a 3D environment. To do this, use the following tools:
✅ Android – Using Scrcpy
Scrcpy is a free, open-source tool to mirror your Android screen to your PC over USB.
🔧 Requirements
- Android phone with Developer Mode and USB Debugging enabled
- USB cable
- Windows PC
🛠 Setup Steps
Enable USB Debugging on your Android:
Settings > About phone > Tap “Build number” 7 times
Then go to System > Developer options > Enable USB debugging
Download and install Scrcpy:
Extract the ZIP file (e.g.,
scrcpy-win64.zip) -
Connect your phone via USB
Approve any on-screen prompts to allow debugging
Launch Scrcpy
Double-click
scrcpy.exe -
Your phone screen appears in a new window
Use with SightLab
Pass
"scrcpy"as the window title inWindowCapturescreen_capture = WindowCapture(window_title="scrcpy", flip_code=1, record_screen=True)
🍎 iPhone – Using AirPlay (LonelyScreen)
Install LonelyScreen on your PC
Open the app
On your iPhone, open Control Center
Tap Screen Mirroring → Select LonelyScreen
Use:
screen_capture = WindowCapture(window_title="LonelyScreen", flip_code=1, record_screen=True)
🧪 Example Script
A full working example is available in:
ExampleScripts/Virtual_Screencast/Virtual_screencast_Phone.py
This script shows how to:
- Mirror a phone screen into VR
- Attach the video texture to a phone-shaped model
- Record the session trial-by-trial
📱 3D Smartphone Model
To enhance immersion, use the included model:
Resources/Virtual_Screencast/smartphone.osgb
Example placement in the scene:
phone_model = vizfx.addChild('Resources/Virtual_Screencast/smartphone.osgb')
phone_model.texture(screen_capture.get_texture())
phone_model.setPosition([0, 1.5, 1.2])
You can rescale, rotate, or parent this to a hand/controller as needed.
