Located in ExampleScripts- Walk the Plank (Multi-User version also available in the same folder)
Use the '1' and '2' keys to raise and lower the plank and drop the floor
Spacebar or trigger to start
F12 to toggle center for pit
For the multi-user version choose "pit2" on the server environment selection and trigger the plank with the 1 and 2 keys on the server
With the latest update you can configure the Walk the Plank settings using the "Config_Walk_The_Plank.py" file with these options:
NUMBER_OF_TRIALS=1#Set to true if using Biopac Acqknowledge, must have running and enable NDTBIOPAC_ON=False#Set to 1 to save video recording alongside session replay (will have to compress after trial)RECORD_VIDEO=0KEY_TO_LOWER_PIT='1'KEY_TO_RAISE_PLATFORM='2'AVATAR_HEAD=AVATAR_HEAD_RESOURCE_PATH+'GlowManBlue.osgb'USE_FOOT_TRACKING=FalseVIVE_TRACKERS=False#To use the barchart, must install matplotlib and numpy using tools-Package ManagerSHOW_BARCHART=FalseENABLE_TRANSPORT=True
Other built in keys-
Start experiment- trigger or spacebar
End experiment- spacebar
Reset position- 'r'
Hide/Show desktop overlays - 'h'
Hide/Show desktop view gaze point - 'i'
Show/Hide gaze point in HMD - 'p'
Toggle center location of plank - F12
See SightLab documentation for specific navigation controls for hardware
For more settings/adjustments see settings.py file and SightLab documentation
