GUI Overview
Using the GUI Editor
Note: If the GUI you are using looks different, you may be on SightLab 2.3 or earlier. Download latest version here.
  1. Open the SightLab VR Script:
    • Click on the Details page to run your primary script or double-click SightLab_VR.py in your project folder
    • This will launch the GUI editor.
    Note: If other Python editors are installed on your system, ensure that the file opens in the Vizard Python environment. If the GUI doesn't load, right-click on the script and choose "Open With - Vizard 7" or "Vizard 8" (found at C:\Program Files\WorldViz\Vizard\<versionNumber>\bin\winviz.exe).
  2. Create a New Project: (note: for project management it is suggested now to just use the SightLab Dashboard)
    • Click New.
    • Enter a name for your project.
    • Click Save Project.
    Additional Options:
    • Load existing .stlb files (SightLab experiment files).
    • Edit your Python script by clicking Edit [filename].
    • Open your project folder by clicking the folder icon.
Managing 3D Models and Media
  1. View Available Models and Media:
  2. Click the Environment dropdown to see available 3D models.
  3. Select 360 Media for 360 media files.
  4. Change Working Environment:
  5. Click Change to switch the directory within your project.
  6. Click Built-In to use SightLab's included assets.
Note: to get to this screen with SightLab 2.3 or earlier need to click the "Modify" button
Editor Controls Overview
  • Left Shift: Toggle scene lock/ROI selection mode (360 media).
  • . (Period)/F1: Hide/show the menu.
  • Mouse: Look around.
  • WASD/Arrow Keys: Move (left/right/forward/backward).
  • Z/X: Move down/up (or PageUp/PageDown).
  • Q/E: Rotate left/right.
  • R: Reset viewpoint.
  • /: Take screenshot.
  • ;: Toggle mouse lock.
  • ,: Toggle scene display.
  • F2: Toggle fullscreen.
  • F3: Toggle rendering/wireframe modes.
  • F4: Show frame rate/performance metrics.
  • Escape: Exit.
  • Ctrl + F6: Dock/undock with code.
  • Spacebar: Toggle media playback (360 media).
  • 1: Select ROIs (360 media).
  • IJKL: Move virtual gaze point (or use mouse).
  • Alt + I: Float window and activate Vizard IDE interactive input.
Editing Models
  1. Open Models in Inspector:
  2. Click Edit in the Experiment Options editor to open a model in Inspector.
  3. Use Inspector to add objects, tag ROIs, set starting points, adjust lighting, etc.
  4. For Inspector workflow see this page
Saving Changes
  • File > Save your work in Inspector.
  • Refresh in SightLab to apply changes.
Working with 360 Media
Switching to 360 Media Mode
  • Select 360 Media in the Experiment Options editor.
Selecting Media
  • View media in the resources/media folder.
  • Use Change to switch directories.
  • Use Built-In for default 360 media.
Media Options
  • Choose media type (video/image).
  • Select stereo or mono format.
Adding ROIs to 360 Media
  • Press Add or Left Shift to enter ROI mode.
Tip: Press ; to lock the mouse cursor.
Placing and Customizing ROIs
  • Move the virtual gaze point and press 1 to set ROIs.
  • Customize region name, scale, opacity, and color.
  • Use the i,j,k,l,u & o keys to move the region or fgh and Shift FGH to scale in x,y or z (use the slider to scale in )
Tip: Lower opacity to hide ROIs during the experiment.
Refer to this YouTube Tutorial for more information.
Configuring Trials
  1. Generate Trials: Enter a count and click Generate.
  2. Current Trial: Use the dropdown to edit individual trials.
Trial Parameters
  • Label: Enter trial-specific labels.
  • Start/End Conditions:
    • Key/button press
    • Timer
    • Custom Event
    • Media end
    • Gaze Event (specify object name)
    • None (specified in code)
Experiment Options
  1. Use Randomize to randomize the trial order.
  2. Choose combined or per-trial data file saving.
  3. Set Start and End Text (2.8.0 or higher)
Note: For advanced randomization, use the code.
Thresholds and Options
  • Dwell Time Threshold: Default 500ms (modifiable).
  • Fixation Duration: Default 100ms.
  • Dispersion Angle: Default 1 degree.
  • Noise Reduction: Adjust frame averaging.
Options
  • Screen Record: Records session videos.
  • BIOPAC Markers: Synchronize with Biopac's AcqKnowledge.
  • Barchart: Save a barchart of objects viewed, average view time and total view time
Running the Project
Click Continue to test your project. See "Running a Session Single User" or "Running a Session Multi-User"
Choose Your Hardware Mode:
