quick start Copy
SightLab experiments can be set up with a GUI, with code, or a combination of both. This QuickStart is first showing starting a quick session with the GUI. For running a session with code see the non-GUI example
| Quick Start - New Scene (2.8.0 and higher) | Earlier versions see below |
On the Projects tab in the Dashboard click New Project and give it a name |
Add Assets: Drag and drop from the Assets library to the preview window to add 3d Models or 360 Media. See this page or the asset browser for some places to gather assets. Can add more assets by dragging in to the Assets browser or directly searching Sketchfab. Note: If you don't see the editor window click "Edit and Run", but should launch by default. |
| Earlier Versions (before 2.8.0) | First 3 steps for versions earlier than 2.8.0, skip to "Choose Assets" if using 2.8.0 or higher |
Create Folder: From Documents\SightLab2\Projects make a copy of BlankProject. (note: can also click the folder icon in the top right of the dashboard to go to the SightLab2 folder directly). |
Add Assets: To add assets, place 3D models in the resources/environments or 360 media inresources/media folder. See this page or the asset browser for some places to gather assets (Can also access built-in ones or copy from the sample project). |
Launch GUI: Open SightLab_VR.py in your BlankProject copy folder to launch the SightLab GUI and choose hardware. |
Choose Assets: Can choose from the dropdown list (will show the resources already added) or drag and drop into the editor. Click "360 Media" if using 360 media. Press the Left Shift key to look around (WASD and XZ to move if in 3D model mode). Note: need to click "Modify" to get here if using SightLab 2.3 or earlier. |
Open Scene Editor: - For 3D models, set up your scene, add ROIs and objects in the scene editor "Inspector" by clicking on the Edit button. |
Scene Editor: - You can use the built in 3D model editor Inspector to edit the model, add regions of interest, set a starting point, check scale, set lighting and more (if needed). Use File-Add or drag and drop to add new objects. When done click File- Save to save the scene. See this page for more details. |
For SightLab 2.8.4 or earlier, make sure to click the "refresh" button if changes were made to a 3D model or you added a new one (as of SightLab 2.8.5 this happens automatically) |
Tag Objects: - Objects can be tagged for extra data collection, visibility as well as interactions, such as grabbing. |
360 Media: - Add 360 Media to the media folder and choose format. Press Shift (in Desktop Mode) to enter ROI mode, then set ROIs by moving the virtual gaze point and pressing 1. |
Generate Trials: Enter a count and click Generate or click the "+" symbol to add more trials if desired. Use Start/End Conditions (Keypress, Timer, Event, Gaze). Can choose different environments or media per trial if desired. |
Adjust Options: Set additional options on the main page such as eye tracking thresholds, randomization, per trial or combined data files, screen recordings, start and end instructions (2.8 or higher) and synchronizing with BIOPAC Acqknowledge. |
Start Session: Press "Continue" to begin the session and choose your hardware (Note: if running an actual study and using eye tracking, make sure to calibrate first according to your hardware), then choose hardware. |
Start/End Trials: Enter Participant info (unless set to bypass). Default controls use Spacebar to start/stop. See all controls here. Press the "p" key to toggle viewing the gaze point (off by default) |
Replay & Review Data: Use SightLabReplay.py (or click "Replay' in the SightLab Dashboard page) for an interactive session replay (use Spacebar to start/stop playback); view data files in the data folder. |
Edit Code: Click to edit the code by clicking the "Edit" button or just open in the included Vizard python editor (can also click "Edit Script" from the Dashboard Details page. |
SightLab script: See this page for SightLab code attributes and methods. |
For more, refer to the SightLab documentation and examples in the ExampleScripts folder to see how to add much more functionality and use templates, such as adding instructions, rating scales, using AI agents and much more. |
Hardware Setup: For help with setting up your VR hardware, such as the Vive Focus Vision, Meta Quest Pro/3, Varjo, Tracking systems and much more see this page. |
Non-GUI Workflow: For non-GUI see example with code.
Customize Scene/Experiment: Creating a new scene.
Multi-User Setup: Check the multi-user guide for collaborative experiments.
Getting Assets: Need models or media? Check out the Getting 3D Models and Assets or the Asset Browser page.
Running with BIOPAC: See this page for the workflow using BIOPAC to synchronize physiological
See also this additional video tutorial with Biopac
