Custom Hardware Configurations
Overview
E-Learning Lab supports these default hardware options: Desktop, Meta Quest Pro, Meta Quest 3, Pimax Dream Air, SteamVR, Quest 3 Client, Meta No Eyetracker, Vive Focus Vision, Varjo, and Projection 2D. See also Supported Devices.
Setting Up Custom Hardware
To configure custom hardware, such as a Projection VR setup:
- Open E-Learning Lab and navigate to the Advanced Tab
- Check
Local Hardware Configs - Click the folder button to open the folder for the local vizconnect hardware configs and either modify one of the included ones or replace one with your own
Once enabled, the hardware options are loaded from the E-Learning Lab\local_vizconnect_configs directory. Each option is read from a fixed file name in that folder (for example, Projection loads vizconnect_config_projection.py), so modify that file or replace it with your own under the same name; a vizconnect file with a new name is not added to the list. This folder includes a modifiable Projection VR configuration file called vizconnect_config_projection.py.
Additional Resources
For comprehensive information on vizconnect, consult the Vizconnect Events page and the Vizconnect section of the Vizard documentation.
