Publishing as an EXE
To publish a lesson as an executable file (so a user running it doesn't need Vizard and SightLab installed), follow these steps:
- Under Options, turn off AI Agent Assistance and Speech Recognition — these do not currently work with exe builds for the E-Learning Lab.
- Choose the Project in the E-Learning Lab and run it once.
- Find the file
E_Learning_Lab_Single_Publish.pyin the E-Learning Lab folder and open it in the Vizard application. - In Vizard, choose File > Publish as exe. This may take a bit of time to finish.
- When it's done, you'll have an exe file in the same folder, which you can rename and send out to other users.
For more information, see the SightLab documentation on Publishing an Executable.
