Adding Avatar Agents (NPCs)
Avatars in SightLab can represent non-player characters (NPCs), animated agents, conversational AI characters, or tracked representations of participants. This page focuses on adding NPC-style avatars to a scene, positioning them, animating them, and ensuring they appear correctly in data collection and replay.
Avatars can be imported in .osgb,.fbx, .glTF, or .cfg formats and work with most common avatar pipelines.
What Are You Trying to Do?
Use this table to jump to only what you need:
Goal Read These Sections
Show a person in the scene Quick Start → Adding & Placing Avatars
Play animations on an NPC Animating the Avatar
Add facial morphs Quick Start → Animating the Avatar
Collect gaze or interaction data on an avatar Data Collection & Replay
Add a conversational AI character AI-Enabled Avatars
Represent the participant's body Tracked / Full-Body Avatars
Quick Start (Minimal Working Example)
The simplest way to add avatars is to place them directly in your scene using Inspector, then either use the GUI to set their animation state orreference them by name in code. No hard-coded positions or extra placement utilities needed.
Step 1 – Add an avatar to your scene in Inspector
  1. Open your environment/scene in Inspector (can click "Edit" in the GUI to open your scene in Inspector or use the shortcut to the Inspector App)
  2. Use File → Add or drag and drop an avatar file into the scene
  3. Position and rotate the avatar using the translate and rotate tools
  4. If referencing in the code, note the avatar's file name (right-click → copy name)
💡 Tip: Built-in avatars are available in the Avatars tab of the SightLab Dashboard asset browser, or you can drag and drop your own avatar files directly into Inspector.
Note: For E-Learning Lab you can drag and drop avatars and choose the animation state and morphs using the built-in E-Learning Lab GUI
Using the GUI - Avatars ending in .cfg will show up in the SightLab GUI (as of SightLab 2.8.4)
Example included avatars
Note: The avatars need to have their name end in .cfg in Inspector for the GUI to find them. If you rename the avatar make sure to keep ".cfg" at the end. Also, this only works for the Rocketbox, Mixamo or avatars that end in .cfg. For other avatar libraries such as Reallusion, see "Loading Avatars in Code or the Stand In Method (see below)". For Mixamo you may need to add ".cfg" to the end of the avatar name in Inspector.
Using code – Reference the avatar in your script
sightlab = sl.SightLab()
def sightLabExperiment():
    yield viztask.waitEvent(EXPERIMENT_START)
    viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
    for trial in range(sightlab.getTrialCount()):
        yield viztask.waitEvent(TRIAL_START)
        #Copy and paste just these 4 lines into your project, changing the name and animation state you want
        env = sightlab.getEnvironment()
        avatarObject = env.getChild('CC2_f001_hipoly_A0_v2.cfg')
        avatarObject.state(1)
        sightlab.addSceneObject('avatarObject', avatarObject, gaze=True, avatar=True)
        yield viztask.waitEvent(TRIAL_END)
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
That's it — the avatar is already placed in the scene, so there's no need to set positions in code.
Supported Avatar Sources
SightLab works with avatars from many common libraries:
Source Description Link
Mixamo Free rigged characters and animations mixamo.com
Ready Player Me Customizable avatars from photos Workflow Guide
Reallusion Character Creator & ActorCore library reallusion.com
RocketBox Microsoft's research avatar library GitHub
Avaturn / MetaPerson AI-generated avatars Avaturn / MetaPerson
📦 Browse more resources at the WorldViz Asset Browser
Included Avatars
Built-in avatars can be found in the Avatars tab of the SightLab Dashboard asset browser. From there you can drag and drop them directly into your scene in Inspector.
Sample avatars also ship with SightLab in these locations:
Path Contents
sightlab_resources/avatar/full_body Full-body rigged avatars
sightlab_resources/avatar/Complete Character Complete character models
sightlab_utils/resources/avatar Utility avatars
Adding & Placing Avatars in Inspector
The recommended workflow is to add avatars directly to your scene in Inspector (the 3D model editor tool). This gives you visual control over placement without writing any positioning code.
Step 1 – Add the Avatar
  1. Open your environment in Inspector
  3. Use avatars from the Avatars tab in the SightLab Dashboard asset browser, or any .osgb``.fbx / .glTF / .cfg file
  4. The avatar will appear in the scene graph
Step 2 – Position the Avatar
  1. Select the avatar's transform node in the scene graph
  2. Use the translate and rotate tools to place the avatar where you want it
  3. Save the scene
Stand-in avatar placement in Inspector
Step 3 – Reference in Code
Use env.getChild() with the avatar's file name to access it at runtime (if it is one of the .cfg avatars). You can find the name by right-clicking the avatar in Inspector and copying it.
avatarObject = env.getChild('MyAvatar.cfg')
From there you can set animations, facial morphs, and register it for data collection — all without needing to set positions in code.
Verifying an Avatar in Inspector
Before adding an avatar to your scene, you can verify it standalone in Inspector:
What to Check
  • Scale (meters)
  • Root transform
  • Available animations
  • Facial morphs (if present)
To open an avatar on its own:
  • Right-click the avatar file → Open with Inspector
  • Or open Inspector and use File → Open
To verify scale:
  • Select the top root node
  • Confirm height is reasonable (≈1.6–1.8 meters)
If scaling is needed:
  1. Right-click the root node
  2. Choose Insert Above → Transform (if there is not already a transform)
  3. Adjust scale using the transform gizmo
Inspector showing avatar scale and root node
You can also preview animations in the Animations tab.
Once you have a reference to the avatar via env.getChild(), you can set animations and facial morphs directly:
# Get the avatar by name
# Set animation state - change number to the animation you want
# Add facial morph - first number is morph to use, second is strength
avatarObject.setMorph(0, 1)
Animation indices depend on the avatar and can be previewed in Inspector's Animations tab.
Animation Examples
# Loop an animation
# Play animation once
avatarObject.execute(1)
# Blend between animations
avatarObject.blend(1, 2, 0.5)  # 50% blend between state 1 and 2
# Set animation speed
avatarObject.speed(1.5)  # 1.5x speed
Changing Animation with a Keypress
def setStateAvatar():
    avatarObject.state(2)
vizact.onkeydown('v', setStateAvatar)
Animation Triggers
You can trigger animations based on:
  • Events – Gaze enter/exit, proximity, button press
  • Time – After a delay or at specific trial moments
  • AI Logic – Dynamic responses from intelligent agents
Collecting Data on Avatars
Avatars can be treated like any other SightLab scene object for data collection:
Metric Description
Gaze Where participant is looking on the avatar
View counts How many times avatar was viewed
Dwell time Total time spent looking at avatar
Interaction events Grabs, clicks, proximity triggers
To add an avatar to the tracked SightLab replay and track gaze data, register it with addSceneObject:
⚠️ Important: Setting avatar=True ensures the avatar appears correctly in replay. Without this flag, the avatar may not be visible during session playback.
No additional gaze-event code is required.
Creating or Capturing Animations
Animation Tools
Tool Best For
Kinetix AI-powered animation from video
DeepMotion Motion capture from video
Rokoko Affordable mocap suits & gloves
Motionbuilder Professional animation editing
Mocopi Sony's portable mocap sensors
High-End Motion Capture
System Description
Xsens Inertial mocap suits
OptiTrack Optical tracking systems
Vicon Industry-standard optical mocap
Helpful References
Troubleshooting
Common Issues & Fixes
Issue Cause Fix
Avatar too large/small Incorrect export scale Add transform above root in Inspector and use scale tool
Avatar missing in replay Missing flag Ensure avatar=True in addSceneObject()
Animation not playing Wrong index or incompatible skeleton Verify animation index in Inspector; check skeleton compatibility
Avatar in T-pose Animation not applied Call avatarObject.state(n) after getting the child reference
Avatar facing wrong direction Rotation offset Rotate the avatar in Inspector, or use avatarObject.setEuler(180, 0, 0)
Avatar floating/underground Y-position offset Adjust position in Inspector, or fix root transform
Animations jittery Frame rate or blending issue Check animation FPS matches; avoid rapid state changes
Avatar not receiving gaze data Not registered Ensure gaze=True in addSceneObject()
Complete Example Script
Here is a full working example with multiple avatars, animations, facial morphs, data collection, and a keypress-triggered animation change:
        # Add Avatar - get name from Inspector by right clicking and copying
        # Set animation state - change number to animation you want
        # To add to the tracked SightLab Replay and track gaze data
        avatarObject2 = env.getChild('CC2_m001_hipoly_A0_v2.cfg')
        avatarObject2.state(1)
        sightlab.addSceneObject('avatarObject2', avatarObject2, gaze=True, avatar=True)
        # Change animation state with a keypress
            avatarObject2.state(2)
An additional example is included at:
ExampleScripts/Adding_NPCs.py
Alternative: Loading Avatars in Code
If you prefer to load avatars programmatically instead of placing them in Inspector, you can still do so:
avatar = vizfx.addAvatar('sightlab_resources/avatar/full_body/RocketBox_Male1.osgb')
avatar.setPosition(0, 0, 2)
avatar.state(1)
sightlab.addSceneObject("avatar", avatar, gaze=True, avatar=True)
Stand In Avatar Method
You can also use the (legacy) stand-in avatar method with avatarPlacer for code-loaded avatars that need visual placement:
  1. Add standInAvatar.osgb (from sightlab_resources/objects) to your scene in Inspector
  2. Position the stand-in where you want the avatar
  3. In code, use avatarPlacer to place the real avatar at the stand-in's location:
from sightlab_utils import avatarPlacer
avatarPlacer.place(env, avatar, 'avatarStandin')
To hide the stand-in during replay:
def onTrialChanged():
    env = replay.getEnvironmentObject()
    env.getChild('avatarStandin').alpha(0)
viz.callback(TRIAL_LOADED_EVENT, onTrialChanged)
onTrialChanged()
More information on the Vizard documentation for Avatars
