SightLab Assistant and Ask the Docs
Overview
The E-Learning Lab editor has two kinds of AI help:
  • SightLab Assistant opens an AI assistant on your E-Learning Lab folder. That's the
    ChatGPT / Codex desktop app or Claude Desktop, already told which project you have open.
    It can explain and change your lessons: writing quizzes, narration and AI agent prompts,
    adding 3D models, images and videos, building whole lessons, and summarizing session data.
  • Ask the Docs answers "how do I…" questions from this user guide, with links to the
    pages it used. It uses the AI model chosen in the Options tab, including offline Ollama
    models, so it also works without internet.
SightLab Assistant
Requirements:
  • The ChatGPT / Codex desktop app or Claude Desktop, with the SightLab plugin. See
    SightLab AI Kit.
  • In a web browser, SightLab Assistant can answer questions, but it can't open or change
    your project's files.
To open it:
  1. Open the project you want help with, or none for general help.
  2. Click SightLab Assistant at the top right of the editor, or choose
    Help > SightLab Assistant. Use the arrow to pick ChatGPT / Codex Desktop, Claude
    Desktop or the browser. The button remembers your choice.
  3. Each app opens differently:
  4. ChatGPT / Codex opens with a message already drafted, naming your E-Learning Lab
    folder and the open project.
  5. Claude Desktop: click Copy Prompt and Open Claude, then paste the prompt in the
    Code tab.
  6. Add your request and send it.
Things to ask:
  • "Write a five-question quiz for slide 3 from this chapter: C:\...\chapter7.pdf"
  • "Write narration and an AI agent prompt for every slide"
  • "Add a 3D model of a beating heart to slide 2"
  • "Summarize the quiz results from this week's sessions"
The assistant tells you what it will generate, and with which service, before it uses
paid credits (images, GIFs, videos and 3D models). It is told never to open your API key
files.
ChatGPT / Codex: images yes, your API services maybe not
Codex's own image generation works: it can make slide images and animated GIFs without
your API keys. Codex runs commands in a sandbox that can block internet access, though,
so services that use your API keys may not be reachable: Gemini, the OpenAI API, Tripo,
Meshy and Stability (3D models, videos, 360 media). For those, make the media with
Generate with AI in the Assets panel, then tell the assistant the file name.
Working While the Editor Is Open
You can keep the editor open while the assistant works.
- Switching back reloads. When you click back into the editor, it reloads the open
project and the global settings. The status bar then shows Reloaded changes made outside
the editor
- Reloading by hand. File > Reload Project From Disk does the same thing.
  • Don't change a slide in the editor while the assistant is working on that slide: the
    editor's change wins.
  • If the assistant changes the AI Model, Avatar Type or Speech Model, the change takes
    effect, but the Options tab shows the old choice until you restart the editor.
  • New lessons. A lesson the assistant creates appears in the Projects tab when you
    click back into the editor.
Ask the Docs
To open it: choose Help > Ask the Docs…, or click the arrow next to Help Docs at
the top right and pick Ask the Docs…. Clicking Help Docs itself still opens this
documentation in your browser.
  • Asking: type a question and click Ask. The answer comes from the user guide
    installed with E-Learning Lab.
  • Who answers: the AI model set in Options > AI Model (CHAT_GPT, CLAUDE, Gemini or
    OFFLINE_OLLAMA). The top of the window shows which model is answering.
  • Links: numbers such as [1] link to the page and section the answer came from. The
    On this PC links show that section inside the window, without internet.
  • Follow-up questions ("And for a 360 slide?") take the earlier question into account.
  • When the model can't be reached (no API key, or Ollama not running), you see the
    matching sections of the guide instead.
  • Asking for a change ("Add a quiz after slide 3"): if the ChatGPT / Codex desktop app
    or Claude Desktop is installed, Do it with SightLab Assistant hands the request to it.
To use Ask the Docs offline, install Ollama and set AI Model to OFFLINE_OLLAMA.
It uses the same offline model as the AI Intelligent Agent,
and answers take a few seconds.
