Release Notes
E-Learning Lab 1.6.3 — November 7, 2026
  • New 3D model generation with Stability AI (generate in as little as one second) and Blender through AI, plus Meshy and Tripo updates
  • Per-slide summaries in the data files
  • Biopac averages added to the slide summary data file
  • Updates to headless generation
  • Avatar replay in the WebXR version
  • Face tracking for HTC or Meta headsets
  • Fixed all assets appearing at once after a session was repeated
E-Learning Lab 1.6.2 — October 24, 2026
  • Added Pocket TTS for text to speech
  • Fixed issue where Edge and Kokoro TTS would not play back in Multi-User
  • 360 backdrops now work for images as well as video
  • Uses the new SightLab Sync, in addition to Syncthing, for synchronizing multi-user assets (SightLab 2.9.3 and higher)
E-Learning Lab 1.6.1 — October 17, 2026
  • New Proximity Sensors: make something happen when a learner reaches a spot in the scene, such as playing a chime, showing a label, or moving on to another slide. Set them up in the Scene Editor, with no code needed
  • Branching logic from proximity sensors: an Advance slide action can go to the next slide or jump to any slide you chooses)
  • Swapped PyQt5 for PySide6 in the GUI's underlying code
  • Fixed issue where some .glb files were missing geometry in WebXR (Stand Alone Mode)
  • Updates to the headless runner
E-Learning Lab 1.6.0 — October 2, 2026
  • New Avatar Replay: drag a session replay file (.rply) onto a slide in the Preview window, and the recorded head and hand movements play back as an avatar each time that slide starts
  • New Record Microphone option on the Advanced tab records your voice alongside the session replay; dropping that replay onto a slide brings the voice with it, playing in sync with the avatar
  • New Avatar Replay row in the Scene Info panel, with right-click options for Loop Playback, Remove Voice and Remove from Scene
  • Option to store session data and quiz responses per project, set with the dropdown next to Data Saving on the Advanced tab
  • Added the number of retries to the quiz data file (new Attempts column)
  • Added an option to prompt before looping Single User sessions: with loop on, the user is asked whether to repeat instead of the session looping automatically
  • Updates to headless mode
  • Fixed DPI scaling being off on some machines
  • Disabled the back button while on a quiz, as it caused rendering issues
  • Fixed grabbed objects added via the Scene Editor not showing in Session Replay
E-Learning Lab 1.5.4 — September 18, 2026
  • Fixed issue with number of quiz questions shown on generated presentations
  • Added checkbox to use local hardware configurations, with a button to open the configurations folder (helpful for using custom hardware configurations, such as Projection VR)
  • Ability to be run in headless mode via a command line prompt
  • Updated OpenAI image generation to gpt-image-2.5 (higher quality, roughly half the latency, 4K 360° support)
  • Removed deprecated image generator Imagen (Nano Banana 2 is the default for Gemini)
  • Updated Gemini image models to their current release versions (the preview models were retired by Google)
  • Updated Claude model to Sonnet 5 (newer and lower cost than Sonnet 4.6)
  • Improved AI tutor response speed by disabling extended thinking on spoken replies
  • Added token usage and estimated cost logging for OpenAI image generation
  • Added ability to set all API keys from the Options tab
  • Fixed issue with quizzes and API key lookups when generating with AI
  • Added option to disable VBO from the Advanced tab (for certain Quadro cards that fail to display textures properly due to the VBO setting)
  • Beta Stand Alone Device support (beta preview of being able to run scenes in WebXR)
E-Learning Lab 1.5.3 — August 28, 2026
  • You can now add new custom avatars to be the AI Agent Tutor. Simply drag an avatar into the scene via the scene editor and select "Use Scene Avatar" then choose from the dropdown your added avatar
  • If there are no slides left (i.e. deleting the only slide) it now properly goes back to the blank/placeholder scene
  • Fixed issue where custom dragged start points for AI agents, clients and Instructors (ones dropped directly into the scene editor) were not being recognized
  • If using embedded Blender, will launch as soon as clicking on the Blender tab
  • Can drag from the 3d environments to Blender
  • Clicking back to preview window auto-saves the scene in Blender and updates the preview/scene
E-Learning Lab 1.5.2 — August 22, 2026
  • New documentation location: https://help.worldviz.com/sightlab/e-learning-lab/
  • Added object selection in scene editor
  • Fixed issue where clicking refresh would remove custom objects in the scene editor
  • Fixed issue where duplicating a slide wouldn't carry over custom objects
  • Fixed text scaling for movement gizmos in scene editor
  • Clicking on one of the objects from the objects list in the scene editor and then clicking "Edit" will now open that object in either Inspector or Blender
E-Learning Lab 1.5.1 — August 18, 2026
  • Fixed issue with a TV stand being added to 360 media scenes
  • Fixed issue with positioning an object after it has been rotated in the scene editor
  • Updated the Single User Publish script for publishing as executables
E-Learning Lab 1.5.0 — August 16, 2026
  • New Scene Editor- You can now add Objects, Images, Videos, Avatars, directly to the main scene without needing to open a second Inspector window. Inspector can still be opened manually using “Edit”. Access tools for move, rotate, scale, delete and drop to nearest surface.
  • Slide reorder via right-click — "Move Up" / "Move Down" options in the slide sequence context menu, in addition to drag-and-drop.
  • Startup now automatically cleans up orphaned thumbnail images left behind by deleted media.
  • Guided tutorial overlay positioning fixes; tutorial now closes with Q instead of Escape (so Escape can still close the scene preview).
E-Learning Lab 1.4.18 — August 8, 2026
  • New Shared Tab to place projects you want to share (can use Syncthing to automatically sync)
  • Fixed issue with project options getting cut-off in the GUI (added resizing of window options in the globalConfig)
  • Ability to swap thumbnails of scene thumbnails
  • Fixed issue where Sketchfab results were only showing 24 results
  • Added model swapping environment names to trial data file
  • Added “Clean up orphaned media” under File menu to delete any unused media files in projects
  • New UI adjustment option with ability to adjust font sizes
  • Resize slider for scenes
  • Fixed issue where AI Agent would take a long time to respond on the first query
  • Fixed issue with preview window causing potential memory leak
  • Added check for no server and clients will automatically close
  • Fixed issue with Getting Started tutorial not working properly
  • Fallback client spawn offsets with golden angle spiral
  • Ability to swap thumbnails on assets
E-Learning Lab 1.4.17 — June 28, 2026
  • Fixed a memory leak issue
E-Learning Lab 1.4.16 — June 28, 2026
  • Added asset type filtering
  • Option to convert .osgb models to .glb and .mkv and .avi videos to .mp4
  • Fixed issue with deleting multiple assets causing the application to crash
  • Fixed issue with gpt-image
  • Brought minimum number of presentation generator slides down to 1
  • Fixed issue where couldn’t select multiple assets for 360 Media
  • Fixed issue where some thumbnails would not delete when deleting an asset
  • Added tooltip hover for 3d Environment assets
  • Added protection to not delete default environments
  • Fixed dialog missing text in AI Avatar Generation
E-Learning Lab 1.4.15 — June 21, 2026
  • Fixed issue with grabbing causing move and spin animations not working
  • Fixed issue with grabbing not working in certain conditions
  • Added multiple waypoints on the moveTo animations
  • Added support for 6 walled Projection CAVEs and Cluster CAVEs
  • Fixed issue where had to click on preview window to navigate using WASD (now will activate when hovering over the preview)
  • Fixed issue with the free/trial version locking up at the 5 minute free trial mark. Now it prompts a user to restart
  • Added ability to drop in multiple items to the scenes/sequence window
  • Video start where left off as a per project option
E-Learning Lab 1.4.14 — June 8, 2026
  • Fixed distortion correction on Projection vizconnects
  • Fixed issue with Projection not working for multi-user
  • Added 2d projection configuration
  • Added Pimax Dream Air to Multi-User selection
  • Added API lookup for AI models to also search, keys folder or if saved in Dashboard in addition to the environment variables
E-Learning Lab 1.4.13 — June 1, 2026
  • Added option to generate a barchart graph of objects viewed, average view time, etc. (similar to SightLab)
  • Added 360 backdrops to replay
  • Added checkbox to hide the Instructor Menu and Screen per project
  • Fixed issue with highlighting not working if an object is grabbable
  • Fixed issue where Desktop Height overrides were not being applied
E-Learning Lab 1.4.12 — May 25, 2026
  • Ability to set audio to play across all scenes (right click on audio file in the audio bin or Project- Scene options)
  • Support for 180 Side by Side video
  • Ability to set video start and end times
  • 360 Video backdrops option
  • Ability to optionally have videos resume where they left off on slide changes
  • Checkbox to mute selected videos
  • Support for animated .gifs
  • Support for dragging and dropping from Windows Explorer
  • New “Cinema” model available in default Environments
  • Added collision detection option for enabling falling or going up and down elevation
  • Added ability to loop audio (whole sequence or single scene)
  • Ability to set Desktop height offset in the GUI
  • New Scene/Env properties dialog (to set 360 backdrop, collision and Desktop height offset)
  • Fixed issue where some stereo images were not properly saving the thumbnails
  • Fixed issue where adding a stereo video would show two screens (one larger one smaller)
  • Fixed thumbnails not showing for .webp files
  • Added LargeScreen2 to scene objects for Cinema stereo videos
  • Added multisample setting to globalConfig
  • Added a checkbox to disable only rotation and teleport, while still allowing magic carpet that is guarded by a keypress
  • Added OpenXR eye tracking hardware selection
  • Right click to Play videos on the scene thumbnail added
  • Fixed issue with stereo images and videos not showing in the replay
  • Fixed issue with 360 videos and images not showing in the replay
E-Learning Lab 1.4.11 — May 20, 2026
  • Tripo 3D added to generate 3D environments, objects, and avatars with AI
  • Generate avatars with AI using Meshy and Tripo
  • Fixed speech recognition accuracy
  • Added Assets tab next to Projects
  • Changed ElevenLabs voice model to eleven_flash_v2_5
  • Added ability to change rating scale size in the globalConfig file
E-Learning Lab 1.4.10 — May 1, 2026
  • Fixed issue where textures would not show on Quadro card systems (should auto-detect, if not can set in the global_config)
  • Fixed issue where the API key for OpenAI was being set to the Gemini file
  • Added dropdown to choose between gpt-image-1 and gpt-image-2 for 360 images, standard images and Presentation Generation
E-Learning Lab 1.4.9 — April 30, 2026
  • Added ability to convert 360 mono images to stereo
  • Replay will now show TV textures, limited support for 360 media (can have varying results for 360 media)
  • Added OpenAI Image to 360 Image generation options
  • Added support for GPT-Image-2.0 (requires verification with OpenAI to use after putting in your API key)
E-Learning Lab 1.4.8 — April 20, 2026
  • Fixed issue where 360 media scenes were getting overwritten in the scenes panel
  • Fixed issue where animations were not playing on non-avatar objects
  • Non-avatar animations now play right away in the preview
  • Fixed issue where scene objects were not moving in the replay (still not moving in multi-user replays)
  • Fixed issue where grabbing may have been off in multi-user
  • Images and videos added to the virtual TV will now show in the replay
E-Learning Lab 1.4.7 — April 19, 2026
Slide & Project Management
  • Added a "+ Slide" button to create new blank slides
  • Added AI button with dropdown for AI slide options: generate new slides from content (title or uploaded content), create quizzes, upload your own material (PDFs, text files, images, etc.), and manage content/knowledge files
  • You can now select multiple projects, scenes, and assets (click-and-drag, Ctrl+click individual, or Shift+click a range) to delete multiple at once
  • [NEW] Dragging a 3D environment or 360 media onto a blank slide now replaces it in-place rather than always creating a new slide
  • Dragging to the preview window with a 3D environment or 360 media now prompts to replace the current slide or add a new one; blank slides are replaced automatically
Preview & Navigation
  • The preview window now uses pivot navigation (orbit and rotate with left, right, and middle mouse buttons, plus WASD/QE keyboard movement). Press 'N' to switch to walk/fly mode
  • Added a placeholder environment for new projects (visible until the first scene is added)
AI Agent
  • Audio narrations added to the AI Agent prompt/context
  • Ability to toggle the visibility of the AI Agent avatar dynamically in a scene using the 'I' key (single user or instructor in multi-user)
  • Ability to pause and resume AI Agent narration sequences
Bug Fixes
  • Fixed guard against Vizard embedded preview window closing when pressing Escape on a Vizard subprocess/launched window
  • Fixed some start points that were referencing avatarPlacer
E-Learning Lab 1.4.6 — April 17, 2026
  • Added default placeholder environment
  • Changed default preview navigation to pivot (mouse/older method still available on the dropdown)
  • Fixed issue where “Edit” button would appear before any environments and crash if clicked
  • Added Kokoro TTS
  • Fixed issue where the interactive object info would cause the Instructor menu to not work
  • Fixed issue with image uploaded for presentation not working
  • Fixed issue where auto-advancing slides would sometimes skip narration
  • Fixed presentation generation to use OpenAI model from config (GPT 5.4) instead of being hardcoded
  • Fix for generating presentations from uploaded slideshows
  • Added a guard for when the Vizard embedded window closes (either due to the 5 min. Limitation of running the demo version, pressing escape or a Vizard crash). This brings up a pop-up window.
  • Fixed issue with stereo widescreen media looking squashed in the preview
E-Learning Lab 1.4.5 — April 14, 2026
  • Live preview will show object animations and properties (spin, highlight, moveTo, animations, etc.)
  • Avatars now will show the animation changes in the preview window
  • Added ‘n’ hotkey to toggle between mouse and walk navigation in the preview window
  • Fixed issue where adding an image to a slide would uncheck object properties on 3d objects
  • Fixed issue where couldn’t swap out images and videos on the same TV in the same slide
  • Fixed “Loop Session” to be a per project option instead of global
  • Fixed issue with “Replace Thumbnail” not working on the Projects
  • Fixed issue where the Wikimedia search window was not being fully removed when closed
  • Fixed issue where the AI Agent would respond with the extension in an object (i.e. heart.glb)
E-Learning Lab 1.4.4 — April 12, 2026
  • Fixed issue with interrupting the AI Agent in a presentation that is auto advancing causing the slides to keep advancing. Now interrupting the AI will then default to having to use the keypress to advance that slide.
  • Changed default animation state to 0 for non-avatar objects
  • Fixed issue with Auto-Refresh after adding an object
  • Changed Max Tokens in the AI settings down from 4096 to 2048 (can be changed in the AI config file)
  • Changed Max history exchanges from 30 to 15 (to increase response time)
E-Learning Lab 1.4.3 — April 11, 2026
New features and improvements
  • Added Object Properties, accessible by right-clicking in the Objects options panel.
  • Edited objects now display a bullet after their name.
  • Hovering over an edited object now shows a tooltip listing which properties were changed.
  • Added a Highlight option that can be applied to any object.
  • Added a Move To animation option, allowing objects to move from one point to another.
  • Added a Spin animation option.
  • Added animation states for non-avatar objects that contain animations.
  • Added the ability to manually designate an object as an avatar, useful when an avatar is not automatically detected or when a standard object uses a skeleton.
  • Added a per-project setting to disable session looping.
  • Added per project AI Agent Avatar settings
  • Added an option for the instructor to begin at the client start point.
  • Added release-event-specific object selection as an option.
  • Added auto-refresh when objects are added to a scene.
  • Made default in Presentation Generator to auto advance slides and show the avatar (can be changed on the Presentation Generator options window)
  • Changed default in preview window to not show start points (can toggle back on)
Fixes
  • Fixed an issue where unchecking the instructor extra Screen option caused it to reappear on each slide. It now remains hidden until re-enabled.
  • Fixed an issue where AI Agent interactions increased the time required to reach the hardware selection screen. AI Agent imports now occur after hardware selection.
  • Fixed an issue where AI Agent narration speech animations did not appear on clients.
  • Updated OpenAI image generation to use GPT Image 1 and GPT Image 1 mini instead of DALL·E 3, which is deprecated effective May 12, 2026.
  • Fixed an issue where grabbing did not work in duplicated scenes.
  • Fixed an issue where Hide Avatar on 360 did not work correctly for clients.
Version 1.4.2 4-5-26
Added Avatars to library bin
Added support for adding avatars including animation states and facial morphs
Changed default Chat GPT model to 5.4
Version 1.4.1 4-2-26
Fix for Augmented Reality with Virtual Screens (mono and stereo)
Fixed issue with the Edge TTS not speaking narrations for presentations
Fixed issue with On Media End not waiting long enough for TTS to kick in
Version 1.4.0 4-2-26
Support for offline Image Generation (mono, stereo and 360) with AI using Stable Diffusion and other offline models
Stable Diffusion improved side by side stereo image generation
When dragging a stereo image to the sequence/scenes window it automatically will create the proper stereo environment
Stereo proper scaling applied to preview scene
Fixed OpenAI stereo image generation
Last chosen AI generation model is remembered when opening dialogs
Sort options on asset bins
Added On Media End as an option to transition between slides
Ability to convert any mono image to stereo (right click in assets and choose “Convert to Stereo”)
Ability to set custom scene transitions to all slides
Version 1.3.10 3-25-26
Fixed issue with language dropdown not showing and Edge-TTS not being selectable
Version 1.3.9 3-23-26
Added releasing a grabbed object to the list of scene transitions items (so can create a training scenario to grab and interact with objects in a specific order).
Fixed issue with dragging objects to sequence window causing an error (now opens Inspector)
Instruction dialog when dragging object to sequence or preview
Dragging from Images to sequence/scenes window will now add a default Theater environment with the Image (dragging to the preview window stays the same)
Dragging from Videos to sequence/scenes window will now add a default Theater environment with the Image (dragging to the preview window stays the same)
Added edge-tts to the text to speech models
Auto-switching of languages when changing default language for AI Agent
Added scroll bars when items in the Project/Options/Advanced panel
Version 1.3.8 2-27-26
Can now add custom content to the AI Agent knowledge (PDFs, markdown and text files), this is in addition to the custom content that can be added in the Presentation Generator. Drag and drop from any Windows explorer window with the tag "_knowledge" added to your file
Added a “Discussion” slide mode for the Presentation Generator to initiate an open discussion with the AI Agent
Changed default image model to Nano Banana 2, which will now ground images from online information and provide much better text and diagrams and image content for presentations
Fixed issue where pressing Enter after searching Sketchfab would pop-up with “API Saved”
Adjusted size of Presentation Generator window to not cut off text
Version 1.3.7 2-19-26
Fixed AI Agent avatar from having neck turn too far
Added option (set to True) for Images added to retain aspect ratio
Version 1.3.6 2-10-26
Fixed dependency on pywin32 from breaking being able to run the E-Learning Lab
Version 1.3.5 2-10-26
Brought up Desktop Starting Position
Version 1.3.4 2-4-26
You can now upload documents, images, pdfs and text files to use as context for the presentation generator. This is in addition to uploading Powerpoints and Presentation Plans as this can directly analyze any information including images, textbooks, notes, charts and more
Projects can be sorted by Alphabetical or Last Modified
Version 1.3.3 2-2-26
Quizzes can now give immediate feedback
Quizzes have option to skip
Quiz data saves number of attempts
Auto generate new quiz questions on any lesson
Fixed hardware selection to only show full body ones when full body is selected and vice versa
Fixed issue where using the 'v' key or nextModel in single user with quizzes would not skip the slide
Fixed issue with full body tracked avatars appearing at ground level
Version 1.3.2 1-21-26
Added feedback/bug report submission form (under Help or on top right button)
Version 1.3.1 1-20-26
Fixed issue that was causing the GUI to scale too large
Version 1.3.0 1-15-26
Added ability to upload powerpoint or pdf slides and have the Presentation Generator use AI vision to automatically generate content
Ability to upload custom lesson plan content to the Presentation Generator
Fixed issue where creating a new project while one is open didn’t clear the preview window
Removed description from Projects tab and added ability to input in the Scene Info tab
Version 1.2.9 1-14-26
Powerpoint and pdf Slideshows start at the last slide
AI Agent now pronounces measuring values correctly (i.e. “centimeter” instead of “cm”)
Fixed issue with Interactive Object Info (made it more concise)
Fixed issue where Interactive Object Info speech wasn’t able to be interrupted
Made Start Points First Slide only checked by default
Presentation Generator now cleans up added quizzes
Updated the Getting Started Tutorial
Version 1.2.8 1-13-26
Fixed issue with OFFLINE_OLLAMA not using context properly
Fixed issues with CHAT_GPT model
AI Agent optimizations
Version 1.2.7 1-12-26
Language now an option in the AI Avatar GUI
Improved support for multiple languages
Presentation Generation will now generate in the language used
Changed info button for Desktop to the ‘T’ key
Fixed Wikimedia causing cursor to not respond
Automatically generated scenes do not override Y position (so user is seated correctly for Desktop mode)
Fixed issue with switching languages
Added single user script for Publishing as an Executable
  • Requires updating to SightLab 2.6.10 for updated object interactions
Version 1.2.6 1-06-26
Added default to not override Y position
Added some extra tooltips
Changed start points for Lecture_Hall
Added ability to drag and drop existing zip files from the online browser and automatically show in the Projects browser
Fixed issue with text panels
Made default button to activate the interactive object info the RH A button (as trigger press is the same as grabbing)
  • Requires updating to SightLab 2.6.9
Version 1.2.5.1 1-05-26
Made default selection for Presentation Designer to be mono (can switch to stereo in the selection box)
Default selection AI Agent Assistance toggled off (can turn on under Options)
Version 1.2.5 1-04-26
Added 360 Image generation with AI
360 image or video generation added to Presentation Generator
Option added to generate stereoscopic images with AI
Stereoscopic images added to Presentation Generator (made default)
Walk Navigation in the Preview window can now go up and down with Q and E
Added ability to override Y position for setting start points higher in the air if desired
Reduces default number of slides in the generator from 5 to 3
Version 1.2.4 1-03-26
Interactive Object Info now also has option to show Text Labels
Fixed issue with MasterpieceX 3d Model generation
Version 1.2.3 1-02-26
Interactive Object Info (click on Target objects to have the AI Agent give information automatically)
Biofeedback ball added (single user) - ball that will react to physio from Biopac
Second screen for Instructor - An instructor facing screen that can show videos/images/slides (can be toggled with the menu or the '3' key)
Fixed issue with server playing double audio on 360 videos
Per Project Settings
Added option for start points to only lock on first slide
Added Instructor menu button to toggle freezing the client transports
Added instructor menu button to toggle instructor screen
Version 1.2.2 12-30-20**25
Removed start point objects from being found as child objects for targetting
Reduced number of items in target objects per page from 8 to 5
Version 1.2.1 12-26-25
Added the ability to add Powerpoint slideshows or pdf slideshows to a scene
Added connection to new online presentation browser
Fixed issue with Multi-User Narrated Sessions
Version 1.2.0 12-26-25
Direction Integration with Sketchfab to search and download models right into your project
Direct integration with AI 3D Model Generation with Meshy and MasterpieceX (use text or image to 3d directly into your project)
Direct Integration with Gemini to create 360 videos using Veo3
Direct Integration with Gemini to create videos and images using Imagen
Direct Integration with Dall-e-3 for images
Direct integration to search Wikimedia for Images and Videos
New Presentation/Lesson Generator - Use AI to automatically generate presentations given any topic. Creates environment, audio narration, images, quizzes, AI prompts, slides and more. Outputs suggested media and options for adding additional content
Added name of project to quiz response csv files
Loop video option
Audio text files read from text to speech with ability to interrupt
Support for stereo images as well as video
Transitions and timer values added per slide
Toggle Transport for client and single user
Add check for correct or incorrect result on Quiz
Multilingual support - can modify the AI agent to use any language
Added separate animation checkbox to trigger animations on objects that contain them**
Version 1.1.12** Beta 12-9-25
Adjusted Syncthing launcher to start browser if syncthing starts without browser
Version 1.1.11 Beta 12-3-25
Added launcher tool to launch tools such as Syncthing, client launcher, mumble and Radmin (from the Advanced tab, requires installation of tools)
Version 1.1.10 Beta 11-30-25
Fixed issue with long connection times to server
Fixed multi-user avatar connection key error
Added ability to load .txt files for instructions
Version 1.1.9 Beta 11-30-25
Added multiple pages for scene items once more than 10
Questions asset contained changed to Quiz/Text
Support for multiple lines rating using
in Quiz csv. also can be used as text instruction
Toggle Controls fix for Instructor
Version 1.1.8 Beta 11-26-25
Full Body Multi User Avatars (with SightLab 2.6)
Added link to download new lessons on Projects tab (can be configured to be a custom URL in the globlConfig file)
Added Brain Lesson for online download
Added ability to toggle the start point visibility
Navigation Toggle
Added reset view tied to the ‘r’ key for the GUI
Removed extra Anatomy lessons (AI and Quiz) and added those to the online lesson downloader
Added start points all for 0 origin
Added start points all for classroom origin
Toggle controls function working
Added new lab classroom model
Version 1.1.7 Beta 11-17-25
Fixed issue with single user not starting Bioipac Acqknowledge
Removed client start points from showing in replay
Added sending of events to Acqknowledge on slide changes with name of slide
Session Replay now works for Multi-User
Added back animations to grabbable objects
Added checkbox for hiding the avatar with the AI Agent
Version 1.1.6 Beta 11-14-25
Updated encoding to use utf-8 for better compatibility
Version 1.1.5 Beta 11-6-25
Support for the Orchestrator plugin for launching client scripts automatically
Version 1.1.4 Beta 11-5-25
Added Piper TTS for faster speech interactions with the AI Agent
Added Faster Whisper for faster speech interactions with the AI Agent
Added Multi-User synchronization of speech animations and audio output
AI Agent side to side head animation when addressing groups
Added AI Prompts and Audio to Scene Panel in Projects Window
Auto highlighter for 3d Menu
Added vision for the AI models
Version 1.1.3 Beta 10-29-25
Added auto start clients for VR and Desktop mode
Added new method for setting client positions
Version 1.1.2 Beta 10-20-25
Updated icons
Updated a few included assets
Removed unnecessary print statements on replay
Version 1.1 Beta 9-17-25
Fully refactored code
Fixed issue where 360 videos and scenes with videos couldn’t be dragged and re-ordered
Fixed issues with midTrial Instructor
Added session replay for single user
Added Loading instructions for instructor
Changed mediaConfig.py to global_config/globalConfig.py (this makes it easier to synchronize in Multi-User)
General optimizations and bug fixes
Version 1.0.8 Beta 8-31-25
  • Added ability to add objects as grabbable, target for data collection or visible in the GUI
Version 1.0.7 Beta 8-30-25
  • Added ability to drag and drop to re-order scenes in the sequence window
  • Added automatic refresh when duplicating a slide
  • Fix for fixation saccade timeline being able to be turned off with Multi User
  • Adjustments for multi-user AI Agent
  • Fixed lighting issues on video screen for Anatomy Lesson and Lecure Hall Model
Version 1.0.6 Beta 8-25-25
  • Fixed issue with Server fixation logging causing server not to run
  • Syncthing included with installation for multi-user synchronization
Version 1.0.5 Beta 8-24-25
  • Instructor clicks past rating with RH Grip instead of triggerPress (to avoid switching slides)
  • AI Prompts and Questions now can be double clicked to open in default program like other assets
  • An audio icon appears on scenes that have audio files dragged to them (in scenes list)
  • Refreshing scene icon will also refresh entire scenes list
  • Added Scene Information on Projects Tab
  • Added ability to choose speech model for AI Agents in GUI
  • Changed start text on server to say to switch to instructor screen
  • Fixed TV screen to not have lighting issues
  • Adjusted Lecture Hall Models with TV
  • Added Theater2 model
  • Fixed issue with screencast not working for Browsers
  • Fixed issue where data was still being saved when data logging was off for fixation timeline
Version 1.0.4 Beta 8-22-25
  • Added Check for Updates Button
Version 1.0.3 Beta 8-19-25
  • Fixed issue with window being resized
  • Removed "New Scene" (not used anymore)
  • Added waiting dialog when opening large projects
  • Added Questions/Quizzes to be able to drop into Preview window
Version 1.0.2 Beta 8-16-25
  • Added drag and drop to preview window
  • Added some user instructions on the GUI
  • Updated Getting Started Tutorial
  • Added fix for faster speech with AI model
  • Added support for offline models
  • Fixed Elevenlabs AI support
  • No longer need vlc player for AI Agent
  • Fixed frame rate issue with AI Agent
Version 1.0.1 Beta 8-9-25
  • Fixed bug causing major performance issues (related to casting)
  • Drag and drop assets in order
  • Fixed some issues with renaming
  • Fixed issue with being able to accidentally change scene when scene controller was hidden
  • More bug fixes and updates
  • Added ability to select specific URL for screen casting
  • Added option for running slides on a timer
  • Added mid trial instructor option
Version 1.0 Beta 7-11-25
  • Added screencasting option
  • Optimizations to GUI
  • Bug fixes
Version 1.0 Alpha Preview 5-5-25
Added GUI interface
Version 0.4.1 3-31-25
  • Added sample blank project folder
  • Updated shortcut icons for Vizard 8 installation
Version 0.4- 3-1-25
  • Got rid of need to have keypresses to start single user lesson
  • Ability to place AI Agent in scene using START_POINT_AI_AGENT object
  • Can now place custom AI prompts per slide in a collection by creating a folder called "Prompts" and naming prompts the same as any slide
  • Optimized AI Agent
  • Chat window for AI Agent can be brought back up
Version 0.3- 3-1-25
  • Added Quiz Slides (_quiz)
  • Added _AI to use AI Agent
  • Multi User AI Agent Instructors
Version 0.2 - 10/16/24
  • Removed audio from playing automatically (with option to mute all)
  • Removed highlighter from single user
  • Removed augmented reality slide from sample anatomy lesson
  • Removed instructions from showing by default
  • Added observer camera object
Version alpha 0.1 - 1 10/7/24
  • Initial Alpha Version
