Latest Updates
The latest highlights across SightLab 2.9, E-Learning Lab 1.6, and the External Data Recorder 2.0. See the Release Notes for the full list of changes.
Anam AI Agent
An Anam video avatar on a screen in a SightLab living-room scene, speaking to the participant
A new example puts a photorealistic Anam streaming avatar into a SightLab scene as the face and voice of the AI Agent. The avatar streams live onto a video screen in VR and speaks its replies with lip sync, while SightLab records eye tracking as usual.
  • Your choice of AI: replies come from ChatGPT, Claude, Gemini or an offline Ollama model such as gemma3, with prompt files like the AI Agent's
  • Your own avatar and voice: make an avatar from a photo, and a voice from a 10 to 15 second recording or an ElevenLabs, Cartesia or Fish Audio voice, in a window that comes with the example
  • 24 languages: one dropdown sets the language the avatar speaks, the AI replies in and speech recognition listens for
  • Voice follows the avatar: picking a different avatar pre-selects the voice with the same name
  • Knowledge (optional): add course notes, manuals or FAQs as documents, and the AI is given the passages that match each question
  • Full screen or in the scene: on a desktop, the avatar can fill the window like a video call. A plain-colour background can be made see-through, so the 3D scene shows behind the avatar
  • Replay with the avatar: the avatar's video and voice are saved for each trial, and Anam_Replay.py plays the avatar on its screen in sync with the gaze data
You need an Anam account (there is a free plan): paste your API key into keys\anam_api_key.txt, run AI_Agent_Anam.py, then hold C to talk to the avatar (or press T to type) and press Space to start and end a trial.
Learn more about the Anam AI Agent and download the example
AI 3D Model Generation
A dark leather sofa and a cream loveseat generated with AI and placed in a virtual apartment by the AI 3D Model Spawner
New in the SightLab Dashboard, E-Learning Lab 1.6.3: more ways to generate 3D models and avatars with AI, and a new example, the AI 3D Model Spawner, that creates models inside a running VR scene.
  • Stability AI: your prompt is turned into a picture, then Stable Fast 3D builds the model in seconds. The fastest option, good for quick props and stimuli
  • Speed or quality for Meshy and Tripo: one setting switches between a fast set of models and a higher-quality one, and the dialog shows which models will be used. With Meshy Image to 3D on our test PC, quality made a 100,000-triangle model with 4K textures in about 100 seconds, against 50–70 seconds for speed
  • Tripo image to 3D: turn a photo, or a picture made from your prompt, into a Tripo model
  • Choose the image generator: when a text prompt is turned into a picture first, choose Gemini, OpenAI, Stability AI or Meshy to make it. The picture is shown while the model builds and becomes the thumbnail when the provider has none
  • Blender (experimental): an AI (OpenAI, Claude or Gemini) writes a Blender script that builds the model. Best for simple, man-made objects such as furniture and props. Needs Blender installed
  • Blender avatars (experimental): build a rigged avatar with Mixamo bone names, which SightLab's full-body avatars recognise, plus idle and walk animations. Results vary from run to run
  • Tripo avatars: the same speed or quality setting, with Mixamo bone names on the rig
  • See the progress: each generation shows its current step and how long it has been running
Each provider needs your own API key. Paste it into the dialog and click Save Key, or set it once with setx (for example setx MESHY_API_KEY "your-key").
In the Dashboard, click 🤖 Generate with AI in the 3D Env, Objects or Avatars tab. See Generating Assets with AI Tools, or AI Content Generation for E-Learning Lab.
AI 3D Model Spawner example
Type or speak a prompt in VR, or drop in a picture, and the model appears in front of you, ready to grab, move, scale and save. It uses the same generators, and logs how long each step takes so you can compare them on your own PC.
  • Speak, type or drop an image: hold the right grip (or C on desktop) to speak a prompt, press N to type one, or drag an image onto the window
  • Watch it build: a placeholder shows the current step and the picture being turned into 3D. Grab it to choose where the model appears
  • Switch generators as you go: press V to change generator, and run several requests at once
  • Build a scene: delete a model with Delete and undo with Ctrl+Z, save placements, and reload them later with the Model Loader
The example is located in ExampleScripts\AI_3D_Model_Spawner.
Learn more about the AI 3D Model Spawner, including setting up API keys and Blender
HeyGen AI Agent
A Session Replay of the HeyGen AI Agent example: the participant's head looking at the avatar's video screen in a room, with the gaze ray, scan path and heatmap on the avatar's face
A new example puts a photorealistic HeyGen LiveAvatar into a SightLab scene as the face and voice of the AI Agent. The avatar streams live onto a video screen in VR and speaks its replies with lip sync, while SightLab records eye tracking as usual.
  • Your choice of AI: replies come from ChatGPT, Claude, Gemini or an offline Ollama model such as gemma3, with prompt files like the AI Agent's. HeyGen's own AI can answer instead
  • Pick the avatar at startup: a dropdown lists every LiveAvatar avatar your account can use, alongside the prompt and AI model dropdowns, and remembers your last choice
  • Replay with the avatar: the avatar's video and voice are saved for each trial, and HeyGen_Replay.py plays the avatar on its screen in sync with the gaze data
  • Try it free: sandbox mode runs free, roughly one-minute test sessions with HeyGen's Wayne avatar. Regular sessions use your LiveAvatar credits (2 per minute)
You need a LiveAvatar account: paste your API key into keys\heygen_api_key.txt, run AI_Agent_HeyGen.py, then hold C to talk to the avatar (or press T to type) and press Space to start and end a trial. To run LiveAvatar in a browser instead, see Virtual Screencasting.
The example is located in ExampleScripts\Heygen_AI_Agent.
Learn more about the HeyGen AI Agent
SightLab VR Assistant in Codex or Claude and the Dashboard
The SightLab Dashboard's SightLab Assistant menu, with options to open it in the browser, ChatGPT / Codex Desktop or Claude Desktop, and links to install either desktop app
The SightLab VR Assistant is a free WorldViz plugin that teaches your AI assistant how SightLab works. Along with ChatGPT and Codex, it now also installs in the Claude desktop app and Claude Code, and the SightLab Dashboard can open it directly on a project.
  • Claude desktop app and Claude Code: add the worldviz/sightlab-ai-kit marketplace under Settings → Customize → Plugins, then add Sightlab. Updates arrive automatically. Step-by-step with screenshots
  • Open a project from the Dashboard: the new SightLab Assistant ▾ button in a project's actions opens ChatGPT / Codex Desktop or Claude Desktop on that project's folder, with the folder path ready in the prompt. Nothing is sent until you send it
  • Choose your app in the header: the SightLab Assistant button in the upper right opens the browser, ChatGPT / Codex Desktop or Claude Desktop, and links to both downloads
  • Checks and runs your experiment: in Codex or Claude Code on a PC with SightLab 2 and Vizard 8, it can check your script and run the experiment in desktop mode, driving the prompts and ratings like a participant, then report what happened
  • Plans, writes and troubleshoots: plan a study, learn the GUI, draft and fix Python for your SightLab version, and have your data files explained
To get started in ChatGPT or Codex, open the plugin link, add SightLab VR Assistant, then type @ in a chat and select it. In Claude Code, type /sightlab:new to start an experiment or /sightlab:check to check a script. Include your SightLab/Vizard version, headset, and whether you are using the GUI, Python, or both.
💬 Get the SightLab VR Assistant plugin for ChatGPT / Codex
Learn more about the SightLab VR Assistant
SightLab Sync
The SightLab Dashboard's Apps tab, with tiles for Vizard, Inspector, E-Learning Lab, SightLab Sync, and Syncthing
New in SightLab 2.9.3: SightLab Sync keeps projects the same on every PC in a multi-user session, for both multi-user SightLab and E-Learning Lab. It copies the Shared folders from one primary PC, usually the instructor's, to every other SightLab PC on the same network, with nothing to type on the client PCs.
  • One-click setup: open SightLab or E-Learning Lab once on each PC, then click Make this machine the primary on the instructor's PC. The other PCs start receiving within a few seconds
  • E-Learning Lab lessons: right-click a project and choose Add to Shared, and it appears in the Shared tab on every PC. Client PCs load lessons straight from Shared, with nothing to import
  • SightLab projects: save a project into the Shared projects folder on the primary, and it appears and runs on every PC
  • Changes copy automatically: edits and deletes on the primary reach the other PCs on their own, and after the first sync only changed files are copied
  • Server name filled in: multi-user SightLab clients automatically list the primary PC as the server, so a new client can click Connect straight away
  • Moving from Syncthing: folders already synced with Syncthing are left alone until you click Switch from Syncthing…
Open it from the SightLab Sync tile in the Dashboard's Apps tab, or from Advanced → Tools → SightLab Sync in E-Learning Lab.
Learn more about SightLab Sync, or see Sharing Multi User Resources for E-Learning Lab
Pocket TTS for the AI Agent
Bar chart of the average time from the end of the user's turn to the avatar starting to speak: Piper 0.94 s, Eleven Labs 1.20 s, GPT Realtime 1.36 s, Pocket TTS 2.09 s, Edge TTS 2.59 s, OpenAI TTS 2.71 s, Kokoro 3.09 s
New in SightLab 2.9.3: the AI Agent can speak with Pocket TTS (by Kyutai), a natural-sounding voice that runs fully offline on the CPU. It needs no GPU, no API key, and no extra Python packages.
  • Voice cloning: make a new voice from a 10–20 second recording, using Kyutai's voice-cloning model (needs a free Hugging Face account and the speaker's permission)
  • Fast for an offline voice: about 2 seconds from the end of your turn to the avatar speaking on our test PC (it varies with the CPU), about a second slower than Piper but with much more natural voices
  • E-Learning Lab: the AI tutor can use Pocket TTS too. See Pocket TTS in E-Learning Lab
Choose Pocket TTS from the TTS dropdown, or set it in Config_Global.py and pick a voice in each avatar config:
SPEECH_MODEL = 'Pocket TTS'       # Config_Global.py
POCKET_TTS_VOICE = "bill_boerst"  # avatar config, e.g. configs/MyAvatar.py
Learn more about Pocket TTS, including adding voices and voice cloning
E-Learning Lab Proximity Sensors
The E-Learning Lab Scene Editor, with a translucent blue PROXIMITY_ZONE placed in a room and the PROXIMITY_ZONE item in the Objects tab
New in E-Learning Lab 1.6.1: proximity sensors make something happen when a learner reaches a spot in the scene. For example, walking to a station plays a chime, reaching into a box shows a label, or bringing a beaker to a tray moves on to the next slide. Sensors are set up in the Scene Editor, with no code needed.
  • Branching logic: an Advance slide action can go to the next slide or jump to any slide you choose, so where a learner goes decides what they see next. It still points to the right slide after you reorder or rename slides
Learn more about Proximity Sensors in E-Learning Lab. To build proximity sensors in your own SightLab scripts, see Proximity Sensors.
360 Moving Regions of Interest
The 360 ROI Path Tracer in a warehouse video, with regions following two forklift riders, the selected region's path drawn across the floor, and a timeline showing when each region appears
New in SightLab 2.9.1: regions of interest can now follow objects that move through a 360 video, such as people, vehicles, or a ball, so you can record gaze on them as they move.
  • Trace with the mouse: play the video in the new 360 ROI Path Tracer, hold the mouse on each object, and scroll to match its size as it gets nearer or farther. Objects that stand still, or stop and start, stay covered too. No headset, eye tracker, or recorded session is needed
  • Set up automatically: drag in a video and it's copied into your project, and the regions of interest are added to the trial with the names you give them
  • See exactly what you'll get: preview the regions as the experiment will show them, with the mouse acting as the participant's gaze
  • Data like any other ROI: dwell time, fixations, and time to first fixation for each moving region, under its own name
  • Stays on target: regions follow the video's own clock, so they stay on their objects even if playback starts late or stalls
  • Track any number of objects in each video, and watch the regions move in Session Replay
Session Replay of the warehouse video, with the Rider1 region following a forklift rider, a gaze heat map and fixations on the rider, and a dwell on Rider1 shown in the console
Run it from the SightLab Dashboard under Tools/Features, or find it in ExampleScripts\360 Moving Regions of Interest. The example follows two forklift riders in the built-in warehouse video.
Learn more about 360 Moving Regions of Interest
External Data Replay with AI-detected objects, including chairs, bottles, a clock, and a person, outlined in a painted café scene
The External Data Recorder 2.0 is now available.
Record eye tracking and physiological data while participants use external applications, including SteamVR, Unity, and Unreal apps, web experiences, standalone headset apps, and desktop games. Version 2.0 rebuilds the recorder with:
  • Add and manage objects of interest: detect everyday object classes (COCO), or use open-vocabulary detection to find exactly the objects you describe
  • Gaze data on objects and areas of interest: dwell time, fixations, and dwell counts for each detected object and class, saved to the data files
  • A real calibration stage: follow a short sequence of dots in the headset, with no need to manually move a virtual screen to line up the gaze
  • Angular accuracy reported every session: a validation round measures accuracy in degrees and prompts you to recalibrate if it's too low
  • An audit trail of gaze quality: each participant's calibration and validation results are saved with their data
  • Headset slippage check: an optional validation at the end of the session measures how much accuracy drifted during the test
  • Works out of the box with all supported hardware, with no manual adjustments. This includes Vive Focus Vision, Vive Focus 3, Vive Pro Eye, Meta Quest Pro, Varjo XR-3/XR-4, HP Omnicept, and screen-based EyeLogic trackers.
  • Pimax Dream Air support, with a step-by-step setup guide
  • Simpler, more stable recording: five video backends are replaced by OBS, recording over WebSockets, and the old "may crash after about 10 minutes" caveat is gone
  • Cropped recordings: for setups without eye tracking, crop the recording to the region you care about, such as cutting out a browser's toolbar
Learn more about the External Data Recorder 2.0, including the Eye Calibration Guide and Postprocessing Guide
AI - Computer Vision Object Detection
City street with AI-detected cars and a traffic light outlined in green boxes, each labeled with its class and confidence
AI Object Detection identifies the objects in a scene automatically while the participant looks around, and records gaze on each one, without having to set up or label scene objects ahead of time. It runs YOLOX object detection on the rendered view at a set interval and registers every detected object with SightLab as a gaze object.
  • Records dwell time, view count, average dwell time, and first view time for each detected object, saved to the data files with the rest of the session
  • Tracks each object of the same class separately, such as yolo_cup_1 and yolo_cup_2
  • Places a 3D collision volume at each detected object for gaze to hit, and shows bounding boxes and labels on the researcher's desktop view
  • Adjust the confidence threshold, detection interval, and display options in AI_ObjectDetection_Config.py
  • Works in Desktop mode, so you can test detection settings before running a VR session
  • An AR version detects real objects in a headset's passthrough view
AI Agent
Object detection is part of sightlab_utils, so it can be added to any SightLab script. Create the detector before each trial, then start and end detection with the trial. All settings have defaults, so it only needs viz and your sightlab instance:
from sightlab_utils.yolox_object_detection import YOLOXObjectDetection
def sightLabExperiment():
    while True:
        detector = YOLOXObjectDetection(viz, sightlab)
        yield sightlab.startTrial()
        detector.startDetection()
        # your experiment code here ...
        detector.endDetection()
        yield sightlab.endTrial()
The example is located in ExampleScripts\AI_ObjectDetection.
Learn more about AI Object Detection, including installing its dependencies
Steam Link logo with a wireless VR headset icon
The new Steamlink hardware configuration runs SightLab on a standalone headset streamed from the PC with Valve's Steam Link app, and records eye tracking on headsets that have it. For Meta Quest headsets, it's an alternative to Meta Horizon Link.
  • One configuration covers several headsets: Meta Quest Pro, Vive Focus Vision, Steam Frame, and Meta Quest 3 and 3S
  • Eye tracking on the Meta Quest Pro, Vive Focus Vision, and Steam Frame; the Meta Quest 3 and 3S record head direction
  • SightLab picks the gaze source automatically at startup: Steam Link eye tracking, then the OpenXR runtime's eye tracking, then head direction. If eye tracking starts arriving later, it switches to it
  • Records eye openness for blinks, with a separate value for each eye on the Meta Quest Pro
  • A gaze check tool shows what Steam Link is sending before you start a session
  • The External Data Recorder has its own Steamlink configuration, for recording eye tracking in other VR applications over Steam Link (see External Data Recorder - Steam Link)
Learn more about Steam Link
Avatar Playback
A playback avatar's head and hands, with a name tag, standing behind a table in a virtual office
Play back a participant's recorded head and hands, any objects they picked up, and their voice as an avatar inside a new, live SightLab session. Record a session as usual, then load the recording in a later session and start the avatar whenever you want it to repeat what was done.
  • Use it for a pre-recorded confederate or demonstrator, to show an expert's movements (or the participant's own earlier ones) to follow or compare against, or to replay how an object was handled in front of a new participant
  • Works with any recorded session: it reads the same .rply file that Session Replay uses, so nothing extra needs to be recorded
  • Objects the recorded participant picked up move again during playback, matched by name to the objects in the new scene
  • Records the participant's voice and plays it in sync with the avatar, with keys to start, stop, pause, and loop the playback
  • The playback avatar is saved in the new session's data, so it appears in Session Replay, and it can be tracked as a gaze object to see when and how long participants looked at it
  • Add it to your own script in a few lines:
from sightlab_utils.avatar_playback import AvatarPlayback
playback = AvatarPlayback(sightlab = sightlab)   # choose a recording from a dialog
playback.start()
The example is located in ExampleScripts - Avatar_Playback, with GUI and non-GUI versions.
Learn more about Avatar Playback
Third Person Follow Mode in Session Replay
Session Replay in Third Person, following the participant's avatar head through an office with the gaze ray, fixations, heat map, and walk path shown, and Follow Mode and Third Person checked in the Replay Preferences panel
Session Replay can now follow the participant from just behind and above their head, so you can see their avatar along with what they were looking at, including the gaze ray, fixations, heat map, and walk path.
  • Check Third Person under Views in the Replay Preferences panel
  • Works with any recorded session in a 3D model scene, whether or not the experiment used a third-person view
  • The camera turns with the direction the participant faces but ignores head tilt, so the view stays level
  • Hold the right mouse button and drag to orbit around the participant; when you let go, the camera eases back behind them
  • Set where the camera sits with setThirdPersonOffset, for example further back to keep the whole car in view in the Driving Example
Learn more about Third Person in Session Replay
Third Person Desktop View
Third-person Desktop view during an experiment, showing the participant's avatar head in an office scene
Watch a participant in third person while the experiment runs. On a Desktop configuration, press b to switch between first person and two third-person cameras.
  • Cycles through first person, behind and above the participant, and over their right shoulder
  • Turning with the mouse swings the camera around the participant, and the camera moves in front of walls and objects instead of showing the inside of them
  • The participant's avatar head is shown in third person; with a full-body avatar, their body shows them instead
  • Only the view changes: gaze, head position, and everything else are still recorded from the participant's own eyes, so the data and replays are the same as in first person
  • Add it to any script with ThirdPersonView(sightlab), and customize the camera positions, the key, and objects the camera can pass through
The example is located in ExampleScripts\Third Person View, and the Street Walking Example uses it too.
Learn more about the Third Person View
Driving Example
Driver's view from the jeep at a city intersection, with a taxi, pedestrians, and the speed and gear display
The Driving Example now has realistic traffic and pedestrians, solid-world collision, and multi-user driving, while SightLab records gaze, vehicle data, and collisions.
New Advanced Traffic Management System
Traffic vehicles and traffic lights at a city intersection, seen from above
  • Vehicles follow the road, keep a safe following distance, stop at traffic lights, and yield to your car
  • Add traffic to any environment by driving the road with the in-app route recorder; no 3D modeling tool needed
  • Signalized intersections with configurable timing, with traffic lights recorded as gaze objects
  • Set the number of vehicles, their speed, traffic lights, and yielding for each trial from a spreadsheet
  • Records nearest-vehicle distance, vehicle hits, and dwell time and fixations on each vehicle
Pedestrian Configuration and Management
A pedestrian avatar at a crosswalk, with a taxi and other pedestrians in the background
  • Animated pedestrians walk the sidewalks, wait at signals, and pause when your car approaches their path
  • Generate sidewalk routes automatically from an environment's geometry
  • Set the number of pedestrians and their walking speed for each trial
  • Pedestrian hits are saved to the data files, sent as events, and marked in Biopac recordings
New Vehicles and Pedestrians
  • New traffic vehicle models, including a black sedan and a taxi, with wheels that spin with their speed
  • Seven animated pedestrian avatars
  • Add your own by dropping models into the vehicles or pedestrians folder
Collision System
  • Solid-world collision: the car can no longer drive through buildings, props, or other vehicles
  • Drive up hills, ramps, and curbs
  • Uses lightweight raycasts instead of a physics engine, so frame rate stays high even in large city models
  • Traffic can't drive through your car either, and impacts play a crash sound and vibrate the controller
Full Multi-User Support
  • Several drivers share the same city from their own computers, each seeing the others' cars
  • Each car is painted in its driver's assigned color, including in Session Replay
  • Drivers line up at the start and can't drive through each other
  • Every driver's data is saved on the server, and replay shows all of the cars together
Optimizations and Updates
  • Realistic acceleration, braking, and coasting, set in real-world units, with the true speed shown on the HUD
  • Steering that pivots around the rear axle and eases into and out of turns
  • Controller vibration on impacts and when pulling away, on Xbox controllers and VR controllers
  • Press r to put the car back at the trial's starting point
  • Car velocity and average speed saved for every trial
  • A non-GUI version where each trial's environment and traffic are set in a spreadsheet
Learn more about the Driving Example
Session Replay of a street crossing, showing the participant's head, gaze rays, and a heatmap on an approaching car, with EEG data graphed below
A new example for pedestrian research. Participants walk through a city street with live traffic while SightLab records their gaze, movement, and traffic events.
  • Real traffic flow that stops at lights and brakes for the participant, with vehicle count, speed, and signals varied per trial
  • Optional animated pedestrians on the sidewalks
  • Measure attention to individual vehicles, signals, and hazards
  • Walk path, walking speed, nearest-vehicle distance, and vehicle hits on the same timeline as gaze
  • Replay walk paths, scan paths, fixations, and heatmaps inside the 3D street, alongside physiological data
  • End trials on a proximity event, timer, key press, or gaze event
  • Single-user, multi-user, and non-GUI versions included
Learn more about the Street Walking Example
AI Agent Updates
AI Agent avatar standing in a living room
New tools make the AI Agent ready for structured research studies:
  • Custom knowledge: add .txt or .pdf files, such as product information, a character backstory, or FAQs, and the agent draws on them naturally in conversation
  • Per-trial prompts and conditional prompting: give each trial its own prompt, or choose the prompt from a randomized condition, for studies with multiple conditions
  • Scripted responses: have the agent speak pre-written lines instead of the live AI model, optionally branched by condition
  • Interaction limits and a scripted closing line: end a trial after a set number of exchanges, with a fixed closing line from the agent
  • Session transcripts: save a timestamped transcript of every conversation
Each of these is a setting in Config_Global.py:
USE_KNOWLEDGE = True
USE_PER_TRIAL_PROMPTS = True
TRIAL_PROMPTS = { 2: "prompts/Job_Interview.txt" }
SET_NUMBER_OF_INTERACTIONS = True
NUMBER_OF_INTERACTIONS = 3
SET_LAST_MESSAGE = True
LAST_MESSAGE = "Thank you for your time today, now I must end this conversation."
SAVE_TRANSCRIPT = True
Learn more about the AI Agent
E-Learning Lab Updates
The E-Learning Lab Scene Editor, with a heart model being positioned on a stand using the move gizmo
  • Avatar Replay: record yourself presenting a slide, including your head and hand movements and your voice, and play it back as an avatar on any slide. Drag the recording onto the Preview window to attach it. Each time the slide starts, the avatar walks learners through the scene, points at objects, and talks them through the content, without an instructor in the session. See Avatar Replay.
  • New Scene Editor: add objects, images, videos, and avatars directly in the Preview window, then move, rotate, scale, delete, or drop them to the nearest surface, without opening a separate Inspector window. See Scene Editor.
  • Custom AI tutors: drag any avatar into the scene, check Use Scene Avatar, and choose it from the dropdown to make it the AI Agent tutor. See Placing the AI Agent in a Scene.
  • Blender integration: open an object from the Scene Editor in Inspector or Blender. Embedded Blender launches from its tab, you can drag environments into it, and changes save back to the preview automatically.
  • Shared projects: a new Shared tab for projects you want to share, which sync automatically across computers with SightLab Sync (SightLab 2.9.3 and higher) or Syncthing
  • Easier editing: reorder slides with right-click, adjust interface font sizes, and clean up unused media from the File menu
Learn more about E-Learning Lab, or see the E-Learning Lab Release Notes
SightLab Dashboard
The SightLab Dashboard gives you a single window to browse, search, launch, and manage all your SightLab content. Create new projects from templates, discover example scripts organized by category, access and organize assets, mark favorites, and launch apps like Vizard and Inspector — all without navigating folders. Customize cards with thumbnails and descriptions, attach videos and documentation, manage multi-user scripts, and sort projects by name or date. Available as a standalone executable with light and dark theme support.
  • New: a Shared directory under Projects, which can sync across computers with Syncthing
  • New: an option to embed Inspector in the Dashboard (turn it on in settings; still being integrated)
See here for more details
New Projects Workflow and Management
With the new dashboard you now have an easier way to create and manage projects across multiple folders, including the ability to easily edit code, view replays, and more
AI Agent
See the Release Notes for Full List
